EcoFlow DELTA 3 Classic (1024Wh) Portable Power Station | EcoFlow UK - DELTA 3 Classic (1024Wh) + 100W Flexible Solar Panel*2 - EcoFlow UK
EcoFlow UK
Regular price £564.00
Sale price £564.00 Regular price £777.00
Save up to £213.00
Days
Hours
Minutes
Seconds
Autumn Savings Start Now 🍂
Up to 60% Off | Limited-Time Flash Deals
Learn More
- 1800W Powerful Output: 3600W surge output. With X-Boost™ tech, supports high-demand devices up to 2400W such as portable fridges, camping kettles, laptops, and power tools.
- 3 Ways to Charge, Ready in Just 45 Mins: Charges from 0–80% in just 45 minutes with AC charging.
- Lightweight, Compact, Portable: Fits seamlessly into outdoor, mobile, and professional setups.
- 10ms Fast Emergency Power Switching: Maintain continuous operation of critical outdoor and mobile equipment during power transitions.
- 30dB Whisper-Quiet Operation: Ultra-low noise ≤30dB at 600W.
- Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport.
- OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. Storm Guard Mode automatically activates backup power before extreme weather hits. Self-Powered Mode and Scheduled Tasks save you money daily.
- Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
£564.00 £777.00 -£213.00
PayPal
EcoFlow’s Best-Value 1 kWh Portable Power Station
Smart choice for your outdoor adventures and work
3 Ways to Charge—Anytime, Anywhere
AC Charging
Alternator Charging
Fully charged in 2.5 hours with 500W solar input. Clean, renewable energy—wherever the sun shines.
Charge to 80% in 1.8 hours or 100% in 2.5 hours using the EcoFlow 500W Alternator Charger. [5]
1800W Output, 3600W Surge
Power Essentials Without Compromise
EcoFlow DELTA 3 Classic delivers a steady 1800W pure sine wave output with grid-level stability—enough to handle high-demand appliances like microwaves and power tools. [6] With X-Boost™ mode, it supports devices up to 2400W without tripping or slowing down—giving you seamless power for the moments that matter.
Camping
Fishing
Photography
Camping
Camping
Fishing
Fishing
Photography
Photography
10ms Auto-Switch. Zero Interruptions.
When the power drops, DELTA 3 Classic responds in just 10 milliseconds—fast enough to keep critical devices like NAS systems and servers running smoothly. No data loss. No downtime. Just uninterrupted peace of mind.
10-Year Lifespan, Built to Last
From battery chemistry to structural design, DELTA 3 Classic (1024Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years. [1]
Compact, Portable — Works Anywhere
Lightweight and easy to carry, DELTA 3 Classic (1024Wh) fits seamlessly into any setting, from your road trips to the great outdoors.
Monitor your energy usage and solar generation—all with one intuitive dashboard. Set timed charging/discharging missions so that you can charge during off-peak hours and discharge during peak rate periods to save costs.
Explore EcoFlow 1kWh Power Stations
DELTA 3 Classic
Best Value for Outdoor Adventures
£399.00
£499.00
DELTA 3
Versatile Power for Home & Outdoor
£649.00
£649.00
DELTA 3 Plus
High-Performance Power for Home & Outdoor
£599.00
£699.00
1024Wh
1024Wh
1024Wh
Dimension
398mm × 200mm × 283mm
Approx. 397.6 × 202 × 283.6mm
Weight
12.1kg±0.3kg
Approx. 12.5kg
Approx. 12.5kg
1800W
1800W
1800W
USB Ports
USB-A: 1 × 18W Max
USB-A: 2 × 18W Max
USB-C: 2 × 100W Max
USB-A: 2 × 36W Max
USB-C: 2 × 140W Max
12V DC Output Port
NO
YES (Car Power Output
and DC5521)
and DC5521)
Outlets
5
13
13
AC Input (Charge Only)
1400W
1500W
1500W
Maximum PV Input Power(W)
500W
500W
1000W
Storm Guard Mode
YES
YES
YES
Expandable Battery
NO
YES. 1-5kWh
YES. 1-5kWh
What's in the Box
What's in the Box
What's in the Box
DELTA 3 Classic
Color
Light Gray
1024Wh
12.1kg±0.3kg
398*200*283mm
Total Output Ports
5
Max AC Output
1800W230V~50Hz
Surge Output
3600W
Max Output by X-Boost
2400W
Output Voltage
230V
UPS
10ms, UPS
Number of AC Outlets
2
USB-A-Fast
1*12W
USB-C
1*100w+1*30W
12V DC Output
None
Utility Power Charging
1400W
Generator Charging
1400W
0-80% Charge Time
Fast Mode: 45min
0-100% Charge Time
60 min
Input Voltage
220-240V~50/60Hz
500W Max
Alternator Charging
PV-based XT60 Port, 500w Alternator Charger
10 years
IP Rate for Battery Pack
IP20 for complete product
CTC Craftsmanship
YES
Extra Battery Port
NONE
Extra Battery
NONE
Max Capacity with Extra Battery
NONE
Wi-Fi
YES
Bluetooth
YES
App
YES
3+2 years
Noise
600W <30dB
200W <40dB
Maximum capacity 50dB
Operating Altitude
≤3000m
Discharge Temperature
-10 to 45°C
Charge Temperature
0-45℃
Storage Temperature
-10 to 45°C
User Guide
When using the DELTA 3 Classic for the first time, we recommend performing a simple battery calibration immediately after unboxing to ensure optimal battery performance. Follow these steps:
1. Use the device until the battery is out of power to 0%, then charge it to 100%;
2. Repeat this process for 1-2 complete charging-discharging cycles (100% → 0%);
3. If you find the above steps difficult, you can also update your device to the latest firmware version using the EcoFlow app.
Firmware updates may include system optimizations that further improve battery performance and overall stability. The specific steps are as follows:
1. Search for "Ecoflow" in the App Store or Google Play Store and download the app named "Ecoflow";
2. After opening the app, log in or register a new account, then click the "+" icon in the upper-right corner to go to "Add Device". Select DELTA 3 Classic from the device list displayed;
3. Press and hold the Power button on the DELTA 3 Classic unit until the screen turns off and then back on; then, click "Next" in the app;
4. After selecting the device, the Wi-Fi connection settings interface will appear. Please enter the SSID and password for the Wi-Fi network, then click Next; on the next screen, please wait for all three connection steps to complete;
5. Once the network connection is established, you will be taken to the Space selection interface; you can select an existing Space or create a new one by clicking "Add Space";
6. Once the Space allocation is complete, you will be taken to the device management interface. Please click the Settings button in the upper-right corner to enter the Settings interface;
7. In the Settings interface, click "Other" → "Firmware Upgrade", then click the "Upgrade" button to begin the firmware upgrade.
EcoFlow DELTA 3 Classic Promotion Terms & Conditions
The EcoFlow DELTA 3 Clasic Promotion runs from 16 March 2026, 8 AM (BST) to 15 April 2026, 8 AM (BST) (hereinafter referred to as the "Promotion Period"). EcoFlow reserves the right to shorten or extend the campaign period at its sole discretion without prior notice.
Eligibility
The promotion is open to all European residents aged 18 years old and above as of 16 March 2026, 9 AM (BST).
Promotion Details
Get 50% Off Solar Panel and EcoFlow 500W Alternator Charger
1. Customers who place a DELTA 3 Classic order during the Promotion Period will have a chance to add one EcoFlow 160W Solar Panel or a EcoFlow 500W Alternator Charger at 50% off discount in the same bundle.
2. Full-priced items cannot be cancelled or returned separately. You must cancel and return the discounted products at the same time. If you need to keep the accessories, you will be charged at the original price.
General
(1) If you encounter any problems during the promotion, please contact support.eu@ecoflow.com for assistance.
(2) To the extent permitted by applicable law, we may decide to modify these rules or cancel the promotion at any time. If there is any fraud or abuse related to the promotion, we reserve the right to exclude any customer from the promotion. Fraudulent activities includ but not limited to automated entries, multiple registrations under different accounts, or fraudulent behaviour.
(3) Participants in the sale agree to be bound by the terms and conditions set forth herein and understand that EcoFlow's decisions are final and binding. No correspondence or appeals will be entertained. EcoFlow reserves the right to make the final and ultimate interpretation of this campaign.
(4) During the Campaign Period, all orders must comply with EcoFlow's purchase agreement and return policy.
(5) The sale promotion is not applicable to wholesale or distributor orders.
(6) Any unauthorized or fraudulent behaviour will result in disqualification of participants.
(7) Participants must comply with all applicable laws and regulations.
(8) EcoFlow reserves the right to stop, cancel, or change the promotion at any time during the promotion. Any changes will be announced on the EcoFlow official website.
(9) All prizes in this promotion are limited in quantity and are available on a first-come, first-served basis. Any matters not covered herein will be handled according to EcoFlow's final interpretation.
(10) EcoFlow will assume no responsibility for late entries, which may occur for any reason, including but not limited to network transmission failure.
(11) EcoFlow will not be responsible for any direct or indirect losses or damages incurred by any party, including the participants, in connection with, or arising from acts or omissions, or any way related to this campaign.
(12) EcoFlow shall not be liable for indirect or consequential losses arising from participation, except in cases of willful misconduct, gross negligence, or where liability cannot be excluded by law.
(13) EcoFlow reserves the right to cancel any order in case of pricing errors or fraudulent use.
(14) EcoFlow reserves the right to withdraw any benefits or discounts obtained.
(15) Employees of EcoFlow, its affiliates, and their family members are not eligible to participate.
Thanks for subscribing!
Explore More
