EcoFlow Solar Angle Guide - Default Title - EcoFlow UK
EcoFlow UK
30 Days Price Guarantee
Prime Day ⚡
Regular price £15.00
Sale price £15.00 Regular price £15.00
Catch Every Ray of Light
Keep sunlight at a 90° angle and concentrate the sun’s rays onto the surface of your solar panel. The Solar Angle Guide gives you a way to maximize solar exposure.
Seriously Simple to Use
Clip to the edge of your solar panel. Next, align your solar panel to the sun’s rays using the shadow. Once aligned, you’re good to go.
Built to Last
The Solar Angle Guide will be on the front line when it comes to the sun’s rays. Its UV resistant properties mean you’ll be able to increase solar intake and shorten solar charging times for years to come.
Get Your Angles Right
Thanks to its transparent shell, you can line up the sun’s shadow to the center of the Solar Angle Guide. This ensures you’re perpendicular to the sun’s strongest rays.
How to Use Solar Angle Guide ?
1. Clip the guide to the edge of your solar panel.
2. Angle your solar panel so the sun is shining through the transparent shell of the guide.
3. Once the sun is shining through a transparent shell, adjust the angle of your solar panel until the shadow hits the middle of the guide.
4.Aim to get as close to the middle as possible. The closer the angle of sunlight to 90°, the higher solar intake and a shorter solar charging time you’ll get.
Specifications
Dimensions: 1.97*2.12*1.18 in /50*54*30mm
Weight: 0.06lb / 25g
£15.00
