EcoFlow RIVER 3 Portable Power Station | EcoFlow UK - RIVER 3 (UPS) - EcoFlow UK
EcoFlow UK
30 Days Price Guarantee
Regular price £179.00
Sale price £179.00 Regular price £199.00
Save up to £80.00
Days
Hours
Minutes
Seconds
Autumn Savings Start Now 🍂
Up to 60% Off | Limited-Time Flash Deals
Learn More
  • 245Wh capacity, 300W rated output, X-Boost up to 600W
  • Up to 2x runtime for light-wattage appliances
  • 30% more compact than the industry average
  • <20/10 ms UPS for uninterruptible backup
  • <30 dB whisper quiet for 24/7 use
  • 1-hr fast charging, without battery damage
  • IP54 waterproof-rated battery pack
  • Charge up to 5 appliances at the same time
Power Station
£179.00 £199.00 -£20.00
PayPal
An ideal starter battery that is compact yet delivers powerful performance
Compact design with powerful performance
Easily extend your outdoor stays and handle power outages with GaN
With groundbreaking X-GaNPower, RIVER 3 taps into superior energy efficiency to extend the operating time of low-wattage devices witha compact design and quieter running volume.
30% more compact for on-the-go use
RIVER 3 minimises heat loss, requires less cooling space, and supports a compact design. It easily fits into small spaces like closets, or a bag for easy storage and portability.
Up to 2x light and network runtime
RIVER 3 revolutionises energy efficiency, delivering double runtime for appliances under 100W, extending use at home and in the great outdoors.¹
< 30 dB whisper quiet for 24/7 backup
With X-GaNPower’s enhanced heat dissipation, RIVER 3 operates on a library-like quiet level, with a volume of less than 30 dB at a distance of 0.5 m.² You'll have peace day and night guaranteed, even when it's running nonstop.
AC charging
Solar charging
Car charging
Generator charging
RIVER 3 fast-charges in 1 hour with X-Stream, without causing battery damage due to vehicle-grade cells and trickle charge technology.
Power up RIVER 3 in as fast as 2.6 hours with 110W solar input. Go even more portable with our 45W Portable Solar Panel (Type-C), which folds to the size of a laptop and charges electronics directly.
Charge RIVER 3 using your car battery while you drive, making it an ideal choice for on-the-go.
Recharge RIVER 3 in just 1 hour with a gas generator for a full day of quiet, safe, and efficient power.
Extremely durable for worry-free outdoor use
With IP54 battery protection, water damage is minimised.³ Its robust fire-retardant shell survives rough conditions. Even after a 1 m fall, RIVER 3 won't get damaged.
RIVER 3 has a lifespan of 3000 charging cycles. That's around 10 years of everyday use before its capacity drops to 80%.
Featuring an advanced algorithm for cloud-based battery monitoring with 40+ safety measures, RIVER 3 protects against various current, voltage, temperature, and circuit risks.
Power up to 600W appliances
Your reliable companion in the wild or during an outage
RIVER 3 keeps 90% of your must-have appliances running smoothly with 300W of power. With X-Boost technology, it can power 600W heating devices without breaking a sweat.
<20 ms UPS solution for uninterrupted daily living
When a power outage occurs, your AC outlet will switch to the RIVER 3 supply in a barely noticeable 20 ms. It keeps vital home appliances running, maintaining food storage, security, and communication. Experience a seamless, automatic switchover for continuous peace of mind
Upgraded smart control
Convenient, intelligent, customized power control
Product Details
245Wh
25.5 x 21.2 x 11.3 cm
3.55 kg
UPS
RIVER 3:<20 ms
RIVER 3 UPS:<10 ms
Noise
<30 dB
1 outlets, 300W total (Surge 600W, X-Boost 600W)
2 ports, 5V=2.4A, 12W max per port, total 24W
1 port, 5/9/12/15⎓3A max, 20V⎓5A Max,100W max per port
Car Output
AC Input
200~240V, 3A, 50/60Hz, 305W, 0-100% in 60 min
Solar Input
11~30V, 8A, 110W, 0-100% in as fast as 2.6 hr
Car Input
11~30V, 8A, 100W, 0-100% in 2.8 hr
Generator Input
200~240V, 3A, 50/60Hz, 300W, 0-100% in 60 min
Optimal Operating Temperature
20℃-30℃ (68°F-86°F)
Charge Temperature
0℃-45℃ (32°F-113°F)
Discharge Temperature
-10℃-45℃ (14°F-113°F)
Storage Temperature
20℃-30℃ (68°F-86°F)
Footnote:
The RIVER 3 Series revolutionizes energy efficiency, delivering up to double runtime for light-wattage appliances, extending use at home and in the great outdoors. Data was tested in a controlled laboratory environment and actual user experience may vary.
1. The "double runtime" claim specifically refers to tests using a 3W light or Wi-Fi router.
3. The IP54 water-proof rating applies only to the battery pack, not the entire package. It does not prevent water immersion but can prevent fire or explosion in the event of a short circuit if the battery is splashed with water or rain, ensuring user safety and property protection
Thanks for subscribing!
Explore More
