12 payments of £54 66 at 0% interest with Splitit. Learn more
Power. Never Been This Easy
Charge 0-100% in 70 mins
Fastest charging speeds ever.
RIVER 2 Pro beats the industry charging speed standard, fully charging in only 70 minutes. That's 5x faster than other portable power stations on the market and 27% quicker than previous generations. Fully charge RIVER 2 Pro while you pack your bags, so you'll always be ready for a last-minute trip.
LiFePO4 Battery Chemistry
With upgraded long-lasting LFP battery chemistry at its core, charge and empty RIVER 2 Series over 3000 times. That's pretty much 10 years of everyday use[1] and 6× longer than the industry average. With LFP cells, RIVER 2 Series is safe, durable, and highly efficient, even in warm temperatures.
RIVER 2 Series is a cut above the rest as the first portable power station in the world to earn the TÜV Rheinland certification for safety. With it’s high safety standard, the TÜV Rheinland certification means the security and reliability of your RIVER 2 Pro is guaranteed.
Our state-of-the-art Battery Management System (BMS) constantly monitors the voltage, current, and temperature of RIVER 2 Pro with multiple aspects of protection, extending its life to the max.[2]
4 Ways to Charge
Charge anywhere
AC Charging
Car Charging
USB-C Charging
The easiest-to-use independent solar power system. Take it on camping or RV trips for stable, durable, and reliable energy on hand whenever you need it. Join hands with us in this energy-sharing world and live green.
The RIVER 2 Pro Solar Generator produces up to 1.8kWh daily, sufficient energy to run your essential appliances smoothly for almost half a day. Using the RIVER 2 Pro Solar Generator every day decreases your whole-year carbon emissions by about 143 kg. That's like planting 8 trees in a year!*
*Based on an average carbon emission of 0.736 kg/kWh and an average sunshine duration of 6 hours per day.
X-Boost Up to 1600W
Small size. Big power.
Lightweight at only 7.8 kg
With a compact portable design, taking travel-friendly power off-grid has never been this easy. With a light-weight, RIVER 2 Pro is ready to power all your outdoorsy escapades, from camping to beach trips.
Monitor, control, and customize your power usage intelligently with the EcoFlow app.Monitor
View battery status live anytime, anywhere.
Control
Easily turn on/off output and the connected appliances remotely.
Customize
By tuning the charging speed to suit various charging environments, it's safe to use, preventing overloading and prolonging its lifespan.
Customize
When the power's down, AC Always-On ensures a seamless transition from the grid to backup power and unwavering protection of your fridge and other mission-critical appliances.
Constant Updates
Regular upgrades to offer you industry-leading energy management.
Power. Anywhere. Anytime.
1. RIVER 2 Pro 2. AC Charging Cable 3. Quick Start Guide
BATTERY INFO
Capacity: 768Wh
Cell Chemistry: LFP
PORTS
Solar Input: 11-50V, 13A, 220W Max
RECHARGE TIME
Car charging: 9 hours
USB-C charging: 9 hours
Solar charging (1 × 220W portable solar panel): 3.5 hours
GENERAL
Net Weight: Approximately 7.8 kg
Dimensions: 270×260×226 mm
App Control: Wi-Fi, Bluetooth
3. When charging and discharging at high wattage, RIVER 2 Pro may make a noise up to 62 dB.
