RAPID Power Bank: 25,000 mAh & 170W | EcoFlow UK - Silver - EcoFlow UK
EcoFlow UK
Pice Guarantee
EcoFlow RAPID Power Bank (25,000mAh, 170W)
Regular price £72.99
Sale price £72.99 Regular price £99.99
Save up to £27.00
Days
Hours
Minutes
Seconds
Autumn Savings Start Now 🍂
Up to 60% Off | Limited-Time Flash Deals
Learn More
  • 170W Fast Charge: Simultaneous multi-port output up to 170W, supports charging up to 3 devices at the same time. 140W max for single-port charging.
  • 140W Max Input Power: The power bank can be recharged from 0% to 50% capacity in approx. 20 minutes.
  • 25,000mAh Capacity, Air-Travel-Friendly*: Can fully charge a MacBook, meeting remote work needs for 1-2 days. Can charge your phone 4-5 times, eliminating battery anxiety.
  • Multi-Device Power Bank: 2 × USB-C ports, 1 × USB-A Port
  • Smart TFT Screen, Clear and Dynamic Display
* Airline regulations vary by region and carrier. Please confirm battery restrictions with your airline before travel.
Colour
Black
Silver
£72.99 £99.99 -£27.00
Multi-Functional Fast Charging for Everyday Convenience
Premium Fast Charging
Fast Recharging
Premium and Compact Design
170W Max Charging with EcoFlow X-Stream Tech
When devices need power, it gets a maximum 140W boost through the USB-C port. With smart distribution, it can deliver a total 170W power across your laptop, phone, tablet, and earbuds—three devices all at the same time.
140W Recharge in a Flash
Low on power before your commute or flight? This power bank recharges up to 50% in just 20 minutes—perfect for two full phone charges or a quick laptop top-up to last the day.
With 140W USB-C port input:
- Recharge from 0% to 80% capacity (20,000mAh) in 37 minutes
- Recharge from 0% to 100% capacity (25,000mAh) in 64 minutes
Massive 25,000mAh Capacity in a Compact Size
90Wh air-travel-friendly*, while high-density cells maximize capacity in a travel-ready design.
- Charge a MacBook Pro 1 time, extending battery life by 24 hours
- Charge an iPhone 16 4.6 times, extending battery life by 115 hours
- Charge a Steam Deck 1.75 times, extending battery life by 10 hours
Superior Safety
Smart Screen Display
Universal Compatibility
Advanced Protection, Maximum Performance
Protected by EcoFlow's X-Guard
Features pro-grade battery technology found in electric car batteries. EcoFlow RAPID's Battery Management System continuously monitors the charging process with quadruple protection to prevent overcharging, over-discharging, overheating, and short circuiting, ensuring safe and stable operation.
Smart TFT Screen with a Dynamic Display
Enhance your charging experience with an intelligent power display. You can view your real-time capacity, port power, battery health, temperature, charging cycles,emojis, and more. The crystal-clear TFT display screen lets you check your data at any angle, in any lighting condition.
Compatible with 99% of Daily-use Electronic Devices
Fits in anywhere you go.
Remote Work
Travel
Entertainment
The Office
Remote Work
Remote Work
Remote Work
Remote Work
Remote Work
Remote Work
Travel
Travel
Travel
Travel
Entertainment
Entertainment
Entertainment
Entertainment
The Office
The Office
The Office
The Office
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Single-Port Charging
Two-Port Charging
Three-Port Charging
Specs - EcoFlow RAPID Power Bank (25,000mAh, 170W)
Total Cell Capacity
25000mAh
Battery Capacity
14500mAh (5V/3A discharge)
157 × 53.8 × 48.8 mm, dimensional tolerance ± 0.5 mm
565 g (approx.)
Appearance
Black, silver grey
Ternary Lithium
300 cycles to 80% capacity
Total Output Ports
1 Type-C1 port: 140W
1 Type-C2 port: 140W
1 USB-A port: 33W
Total 170W
Built-In Cable Output
1 USB-A port: 33W
1 USB-C port: 140W
1 USB-C port: 140W
Input
140W
USB-C Recharge
Multi-port input is not supported, the maximum power of a single port input can reach 140W.
Type C1 port: 140W input
Type C2 port: 140W input
USB-A Recharge
APP
Not compatible
Screen
TFT
Drop-resistant
1 m
Fireproof
Housing V0 Fireproof
2 Years
Charge Temperature
20℃–30℃ (68℉–86℉)
Discharge Temperature
0℃–45℃ (32℉–113℉)
Storage Temperature
–10℃–45℃ (14℉–113℉)
Wich devices are compatible?
Compatible devices are laptops, phones, tablets, headphones, smartwatches, game consoles and other devices with USB-C ports such as MacBook Pro/Air, iPhone,iPad, Dell XPS and Samsung Galaxy.
BC1.2/Apple2.4A/QC3.0/FCP/SCP/AFC/UFCS/PD3.0/PPS
How to keep the power bank charging and discharging quickly?
To ensure fast and stable charging and discharging performance when using the power bank, we recommend the following.
1. Choose the Right Charger:
Use a charger that supports fast charging protocols and has a high output power (such as PD 65W or 100W). Avoid using low-power chargers (such as 5V/1A).
2. Use a Good Charging Cable:
Select original or high-quality fast charging cables. Keep connectors clean and secure, and avoid excessively long cables.
3. Device Compatibility:
Make sure the connected devices support fast charging protocols; otherwise, fast charging will not be achieved.
Battery life and temperature FAQs
The power bank retains over 80% of its battery capacity after 300 charge cycles. It supports charging and discharging at altitudes below 3000 meters and in environments with temperatures between 0°C and 40°C. If not used for an extended period, it is recommended to store the power bank in an environment between -20°C and 40°C and to recharge it at least once every three months.
Can the RAPID Pro power bank be taken on the plane?
Yes, according to regulations by the International Civil Aviation Organization (ICAO) and most airlines, carrying a power bank with a capacity under 100Wh is allowed. The RAPID Pro, with a capacity of 25000mAh (90Wh), meets this requirement and can be carried on board without concern.
Why is there a difference rated capacity and nominal capacity?
Nominal capacity refers to the total capacity of the battery cells inside the power bank, while rated capacity refers to the actual amount of power the power bank can deliver under standard output conditions (such as 5V/3A). Nominal capacity is a theoretical value, whereas rated capacity accounts for energy conversion efficiency, circuit losses, and other factors, and is therefore lower than the nominal capacity.
Thanks for subscribing!
Explore More
