EcoFlow RAPID Mag Power Bank: 10,000 mAh & 7.5W | EcoFlow UK - Midnight Black - EcoFlow UK
EcoFlow UK
Pice Guarantee
EcoFlow RAPID Mag Power Bank (10,000mAh, 7.5W, Magnetic Charging)
Regular price £65.99
Sale price £65.99 Regular price £65.99
Save up to £42.00
Days
Hours
Minutes
Seconds
Autumn Savings Start Now 🍂
Up to 60% Off | Limited-Time Flash Deals
Learn More
  • Ultra-Slim 15.5 mm / 0.61 in: Around the same thickness as a stack of seven 2-Euro coins. Slides invisibly into pants pockets, a slim laptop bag, or a purse.
  • 38°C Cool Touch: Extend phone lifespan with X-Cooling tech.¹
  • 10,000mAh On-Demand Energy: No full charge? There's no need to panic. 10,000mAh can refuel an iPhone 16 2.06 times.
  • 11N Grip, Zero Drops: Military-grade N52 magnets withstand running, cycling, and subway chaos.
  • 30W Recharging, 50% in 49 Min
  • 60° Kickstand
  • Power Indicators: Four LEDs track battery levels in real time.
Color
Pearl White
Midnight Black
Stay tuned!
Be the first to know when Black models of EcoFlow RAPID Mag are available.
£65.99
Industry's Slimmest Magnetic Power Bank²
Ultra-Slim 15.5 mm
60° Kickstand and 11N Grip
Silk-Soft Touch
LED Power Indicator
Around the same thickness as a stack of nine 25-cent coins. A lithium cobalt battery packs 10,000mAh into a slimline design. Slides invisibly into pants pockets, a slim laptop bag, or a purse.
Adjust from desk work to movie watching with a multi-angled stand for convenient horizontal and vertical viewing. Military-grade N52 magnets withstand running, cycling, and subway chaos.³
Silky matte texture ensures a secure grip during workouts, commutes, or coffee runs. Sweat-proof, fingerprint-resistant, and lightweight.
Four LEDs track battery levels in real-time. Check remaining charge mid-flight, on hikes, or during outages, and plan your next recharge effortlessly.
38°C Cool Touch
Charge While Recharging
30W Recharging
X-Cooling tech maintains a surface temp of less than 38℃/100°F,¹ extending phone battery life.³
Experience the convenience of rapid recharging. Whether you're unwinding with your favourite movie or focused on a meeting, fully recharge at the same time.
* Fully recharge in 130 min
City Strolls
Café Hangouts
Trail Hikes
City Strolls
City Strolls
Café Hangouts
Café Hangouts
Café Hangouts
Café Hangouts
Trail Hikes
Trail Hikes
Trail Hikes
Trail Hikes
Model-by-Model Charging
Phone Case-Friendly
* Based on internal laboratory testing. A fully charged 10,000mAh power bank provides approximately 6000mAh to 6500mAh of usable power due to 35% to 40% energy loss.
Apple Device Charging
Compatible with iPhone 12-16 Series, AirPods with wireless charging case.
Snap-on a magnetic case for instant coil alignment during workouts or busy commutes.
Specs - EcoFlow RAPID Mag Power Bank (5000mAh, 7.5W, Magnetic Charging)
Total Cell Capacity
10000mAh(7.6V)
Battery Capacity
6500mAh(5V⎓2A)
Dimension
103 × 71.6 × 15.5 mm
187 g
Appearance
Skin-friendly material; 2 colours
Lithium cobalt oxide
Ports
1C, 30W Max
Wired Charging Output
30W
Wireless Charging Output
7.5W Max
Wired Charging Input
30W
APP
Not compatible
Compatible Devices
iPhone 12 Series and later
Samsung S24 Series and later
AirPods with a wireless charging case
Screen
5 LED lights
Drop-resistant
1 m
1.5 years
Optimal Operating Temperature
15°C–40°C
Charge Temperature
0–40°C
Discharge Temperature
0–40°C
Storage Temperature
-10 to 45°C
Can I use it while charging?
Supports simultaneous charging and discharging. Wireless charging up to 7.5W Max.When discharging simultaneously, wireless charging is disabled by default, but can be enabled by pressing and holding the button for 3 seconds.
Why does my phone get hot when charging with a power bank? Is there any impact?
It is considered normal for a smartphone to generate heat while being charged by a power bank.This may be caused by factors such as energy conversion losses, simultaneous charging and usage, and elevated ambient temperatures.To prevent overheating, ensure that both the smartphone and the power bank are placed in a well-ventilated environment.In cases of excessive heat, the device may reduce its power output. Charging may be paused and resumed once the device has adequately cooled down.Please rest assured that our product has obtained multiple regulatory safety certifications and meets strict compliance standards.
Is our power bank compatible with android phones?
Our power bank is compatible with most android phones, but does not support the proprietary wireless charging protocol of android phones. And we recommend that you choose a phone case that supports magnetic attraction for a better experience.
What is the function of the button?
A single press will wake up/display the remaining battery level.Double click to switch between wireless charging fast mode( green light on) and low temperature mode( blue light on).Press and hold for 3 seconds to turn on/off wireless charging.
Why does my power bank stop charging my device at 80%?
As part of the iOS system thermal management strategy, if the temperature gets too high during charging, your iPhone may automatically stop charging at 80% to prevent its battery from overheating. After waiting for the device to cool down, charging will resume. Moving it to a cooler place can help speed up this process.
Can I take a power bank on the plane?
Yes, the RAPID Mag has a capacity of 38.7Wh for 10000mAh and 19.5Wh for 5000mAh. According to the international civil aviation organization(ICAO) and most airlines, power bank with a capacity of less than 100Wh are allowed and can be used with confidence.
Usage environment and storage requirements for power banks
The battery capacity of the power bank is greater than 80% after 300 cycles. It supports charging and discharging at an altitude below 3000m and an environment of 0~40℃. If it is not used for a long time, it is recommended to store it in an environment of -10~40℃ and charge the power bank at least once every 3 months.The battery capacity of the power bank is greater than 80% after 300 cycles. It supports charging and discharging at an altitude below 3000m and an environment of 0~40℃. If it is not used for a long time, it is recommended to store it in an environment of -10~40℃ and charge the power bank at least once every 3 months.
How to charge your device wirelessly more effectively?
Do not use a phone case or choose a thin phone case with a magnetic design that is less than 2.5mm thick and align it with the wireless charging position of the power bank.
Is the charging cable includes in the package?
Yes, it comes with a 30 cm C to C charging cable that supports 60W.
Why is there a difference between the rated capacity and the nominal?
Nominal capacity refers to the total capacity of the internal battery cells of the power bank, while rated capacity refers to the actual amount of the power that the power bank can output under standard output conditions( such as 5V/2A). The nominal capacity is a theoretical value, while the rated capacity takes into account factors such as energy conversion effiencicy and circuit loss, it will be lower than the nominal capacity.
Can the USB-C port of the power bank be used for charging and discharging?
Yes, the USB-C port is bidirectional port that can be used for both charging or discharging.
¹ Verified in lab conditions
² Benchmark is EcoFlow RAPID 10K
³ Phone model dependent
Thanks for subscribing!
Explore More
