12 payments of £223 08 at 0% interest with Splitit. Learn more
Travel without limits.
Escape the grid, embrace the wild without worrying about how much power you've used. With a whopping 3.6-7.2kWh of expandable power, experience the ultimate freedom of off-grid living while powering all of your RV essentials with a clean and quiet energy source. Plus, use DELTA Pro as a mobile EV charger when you're on the road. DELTA Pro is the ultimate, portable power solution for RV road trips and outdoor adventures.
A true adventurer always seeking the next thrill. Connect DELTA Pro with an Extra Battery for a huge capacity of 7.2kWh, and stay powered for up to a week*. Run daily essentials such as a fridge, laptop, coffee maker, and even the air conditioner. You'll have the power to experience all that nature has to offer.
Traveller Kit : 3.6kWh
DELTA Pro + Grounding Adapter
Starlink Wi-Fi (50W): 72h
Fridge (20W) : 180h
Light (25W): 144h
Laptop (60W) : 60h
Air Conditioner (1200W) : 3h
*The data above is for reference only. Actual run times depends on the individual's RV electricity needs and may vary.
Overlander Kit : 7.2kWh
DELTA Pro + DELTA Pro Extra Battery + Grounding Adapter
Starlink Wi-Fi (50W): 144h
Fridge(100W) : 72h
Light (25W): 288h
Laptop (60W) :120h
Coffee Maker(1000W): 7.2h
Air Conditioner (1200W) : 6h
Bid farewell to noisy, fume-filled gas generators and relish peaceful, green, maintenance-free power wherever your RV adventures take you. Charge your RV essentials, or plug into a shore power outlet to directly power your RV's electrical system.
Whether you're on the road, at a campsite, or in your backyard, you're never left without power. Topup using MultiCharge in the time it takes to watch a movie. Fully recharge in only 1.7 hours at an EV charging station (3400W), 1.9 hours with dual AC + solar charging (3000W), 2.7 hours from an AC outlet (1800W), and 3.5 hours using solar (1600W).
Relieve EV range anxiety.
*Miles per kWh for a TESLA MODEL Y: 3.3-3.8 mi/kWh, DELTA Pro (3.6kWh) can extend the range of a MODEL Y approximately 13.68 miles.
