EcoFlow GLACIER Portable Refrigerator | Off-Grid Solar Fridge - GLACIER - EcoFlow UK
EcoFlow UK
EcoFlow GLACIER Portable Fridge
£1,348.00
Regular price £1,348.00
Sale price £1,348.00 Regular price £1,348.00
This item is no longer available on the official EcoFlow website. We recommend subscribing to EcoFlow's marketing emails to be the first to receive new product information or check out other promotional items.
• Dual zone, dual control
• 38L large capacity
• Detachable suitcase design
• Smart app control
Accessories
Free Gift for EcoCredits Member
£1,348
Wherever your adventures take you.
Pick-up trucks
RVs
Truck sleepers
Boats
Outdoors
Industry's first integrated ice maker.
120W compressor
Equipped with a powerful 120W compressor, it brings you 18 solid ice cubes in 12 minutes.[1] For all the spine-tingling moments along your journey, spice them up with chilled sodas.
A fridge-freezer at its best.
Dual zone, dual control.
Equipped with a removable divider separating it into two zones, and independent temperature control, both sections can refrigerate and freeze from 50°F (10°C) to -13°F (-25°C). Steak, cheese, or soft drinks......whatever you want to stock up on, it shape-shifts to meet your needs.
Single-zone
Dual-zone
The fastest cooling in the industry.
Cooling at the optimum speed when empty, Glacier rapidly refrigerates from 86°F (30°C) to 32°F (0°C) in around 15 minutes.
Cooling for up to 40 hours wire-free.
298Wh plug-in battery
Designed for absolute portability, Glacier can be powered by the Plug-in Battery[2] and free from messy, limiting cables.With a large battery capacity of 298Wh, savor up to 40 hours[3] of easy access to frozen meals, fresh fruit, and ice-cold beverages.
Charge laptops and more on the go.
100W max USB-C
With 100W max USB-C charging, it even powers up your phones and laptops so you'll never lose touch with your loved ones.
38L large capacity Maximize the use of space.
60 × 330ml
Go for a whole fridge with veggies and fruit when out for a picnic. If you're off-roading in the desert, the 38L of steaks fuels you up for any thrill.
Detachable Lever and Wheels
Chilling on the move.
One lever and one set of wheels, all detachable.[4] Wheel the fridge-freezer to wherever your adventures take you. Detach these accessories and fit Glacier right on your RV's countertop, in the passenger seat, and in other compact spaces.
* GLACIER's accessories (Plug-in Battery and Detachable Wheels and Lever) are sold separately.
Control at your fingertips.
EcoFlow app
The EcoFlow app allows the intelligent temperature control of Glacier via Wi-Fi or Bluetooth.
EcoFlow app
EcoFlow app
EcoFlow app
Fridge
Freezer
Fridge-Freezer
Freezer-Fridge
Nothing's cooler than going green.
We're all about guarding both the green planet and your user experience.
The VIP technology.
Glacier sports vacuum insulation panels (VIPs). With a low thermal conductivity, these panels help optimize energy efficiency, reducing energy consumption, carbon footprint, and the environmental impact of refrigerant production and disposal.
Eco mode
Under Eco mode—the energy-saving mode—Glacier uses only 0.18kWh per day[5].
Multiple charging methods
Charge up anywhere.
Solar charging
Fully charged by solar energy [6] (up to 240W)in as fast as 2.1 hrs
AC Charging
Fully charged by AC in 2.2 hrs
DC Charging
Fully charged by DC (12V) in 4 hrs or DC (24V) in 2,1 hrs.
EcoFlow GLACIER
EcoFlow GLACIER
Ice shovel
Ice shovel
Left zone basket
Left zone basket
AC power adapter + cable (varies by region)
Car charging cable
Car charging cable
Quick Start Guide
Quick Start Guide
Warranty Card
Warranty Card
AC Input
100-240V, 50/60Hz, 180W
Solar Charging Input
240W (11-60V, 13A Max)
Car Charging Input
96W/192W (12/24V, 8A Max)
Battery Pack Power
100W (USB-C)
Operational Volume
Single zone: 38L (40 qt.); Dual zone: 36L (38 qt.)
23 kg
Dimensions (wheels and handles not included)
776 × 385 × 445 mm
IP Rating
IPX4
Refrigeration Temperature Range
–25°C to 10°C (–13°F-50°F) (ambient temperature at 25°C)
Noise Level (stable operation)
Ice making: <52dB; Refrigeration: <42dB
Refrigerant type/Amount
R600a, 32 g
Quick Freezing Mode (30℃ to 0℃)
15 minutes
Refrigeration Power Rating
120W
Bluetooth
Wi-Fi
This product supports 2.4G Wi-Fi only
1. The test result was gained with the ambient temperature of 77℉ (25°C) and water temperature of 59℉ (15°C). The first round of ice making might take longer than 12 minutes.
2. Plug-in Battery is sold separately.
3. The test result was gained with the fridge empty, its temperature set to 39℉ (4°C), and the ambient temperature of 77℉ (25°C).
4. The detachable wheels and lever are sold separately.
5. The test result was gained with the ambient temperature of 77℉ (25°C) and Glacier's temperature set to 39℉ (4°C).
6. Solar charging applies only when Glacier is connected to the Plug-in Battery.
Customer Reviews
Based on 1 review
0%
(0)
100%
(1)
0%
(0)
0%
(0)
0%
(0)
A
Anonymous
Perfect for what I needed
Great product as with all the EcoFlow stuff I have. Very quick to reach temperature and very flexible with the ability to have split sections with different temps, or one big area.
Only negative worth noting is that when it’s split into two compartments. The smaller side must always be the lower temperature, so you can’t have the bigger side as freezer and smaller side as fridge.
