12 payments of £291 41 at 0% interest with Splitit. Learn more
An astonishing 8 days run time under GLACIER's Eco mode with EcoFlow DELTA 2 Max and the Plug-in Battery connected! Fresh food and cold sodas within reach for more than 7 days.Whether you're in an SUV, pick-up truck, RV, or tent, you can never get hangry!
Industry's first integrated ice maker.
120W compressor
Equipped with a powerful 120W compressor, it brings you 18 solid ice cubes in 12 minutes*. For all the spine-tingling moments along your journey, spice them up with chilled sodas.
* The test result was gained with the ambient temperature of 25°C and water temperature of 15°C. The first round of ice making might take longer than 12 minutes.
A fridge-freezer at its best.
Dual zone, dual control.
Equipped with a removable divider separating it into two zones, and independent temperature control,
both sections can refrigerate and freeze from 10°C to -25°C.
Steak, cheese, or soft drinks......whatever you want to stock up on, it shape-shifts to meet your needs.
The fastest cooling in the industry.
Cooling at the optimum speed when empty, GLACIER rapidly refrigerates from 30°C to 0°C in around 15 minutes.
Cooling for up to 40 hours wire-free.
298Wh plug-in battery
Designed for absolute portability, GLACIER can be powered by the Plug-in Battery* and free from messy, limiting cables.
With a large battery capacity of 298Wh, savor up to 40 hours* of easy access to frozen meals, fresh fruit, and ice-cold beverages.
* Plug-in Battery is sold separately.
* The test result was gained with the fridge empty, its temperature set to 39℉ (4°C), and the ambient temperature of 25°C.
Charge laptops and more on the go.
100W max USB-C
With 100W max USB-C charging, it even powers up your phones and laptops so you'll never lose touch with your loved ones.
10-year long-lasting LFP battery
Durable, Safe, Lightweight
Experience the industry's fastest AC outlet and solar recharging
80% in 43 Min*
With DELTA 2 Max's upgraded tech, AC charge to 80% in only 53 mins. Combine up to 1000W solar input with AC for a super-fast 43 min charge.
*When combined solar and AC input is 2400W.
400W Portable Solar Panels
Our 400W portable solar panel offers high solar output, conversion efficiency rating,
and a convenient folding design so it’s ready to grab and go at any time.
Charge faster,wherever you go.
A single solar panel with a unique folding design,our 400W solar panel combines powerful energy production with portability. To achieve a highersolar conversion efficiency of up to 23%, we use multi busbar monocrystalline cells, so you get evenmore energy to recharge your portable power.
Specs of GLACIER
AC Input
100-240V, 50/60Hz, 180W
Solar Charging Input
240W (11-60V, 13A Max)
Car Charging Input
192W (12/24V, 8A Max)
Battery Pack Power
100W (USB-C)
Operational Volume
Single zone: 38L (40 qt.); Dual zone: 36L (38 qt.)
23 kg
Dimensions (wheels and handles not included)
776 × 385 × 445 mm
IP Rating
IPX4
Refrigeration Temperature Range
–25°C to 10°C (–13°F-50°F) (ambient temperature at 25°C)
Noise Level (stable operation)
Ice making: <52dB; Refrigeration: <42dB
Refrigerant type/Amount
R600a, 32 g
Quick Freezing Mode (30℃ to 0℃)
15 minutes
Refrigeration Power Rating
120W
Bluetooth
Wi-Fi
This product supports 2.4G Wi-Fi only
Specs of DELTA 2 Max
2048Wh
Extra Battery
AC Input
X-Stream 2300W, 10A
3100W
Cycle life
3000 cycles to 80%+ capacity
Connectivity
Wi-Fi + Bluetooth
49.7×24.2×30.5 cm
NET Weight
Approx. 23 kg
Specs of 400W portable solar panel
Cell Type
Monocrystalline silicon
106.8*239*2.4 cm
Open Circuit Voltage
48V (Vmp 41V)
Short Circuit Current
11A (Imp 9.8A)
Weight(Solar Panel)
16 Kg
Weight (with Kickstand Case)
Approx. 19kg
