EcoFlow GLACIER Classic Portable Fridge Freezer | EcoFlow UK - 45L / / - EcoFlow UK
EcoFlow UK
12 payments of £54 08 at 0% interest with Splitit. Learn more
30 Days Price Guarantee
Regular price £649.00
Sale price £649.00 Regular price £649.00
Save up to £270.00
Days
Hours
Minutes
Seconds
Autumn Sale × EcoCredits Week:Earn Up to 2.5× EcoCredits!
Learn More
1. Dual-Zone Design (45L & 55L only): Keep fresh and frozen foods separate, with a maximum temperature difference of 20 °C maintained within ±1 °C for ultimate freshness.
2. High Capacity: Holds up to 58 cans (35L), 72 cans (45L), or 90 cans (55L) of 330ml soda.
3. Extended Off-Grid Operation: The 298Wh Plug-in Battery maintains items at 4 °C for up to 43 hours (35L) or 39 hours (45L/55L).
4. Enhanced Insulation: Featuring 2-inch foam and superior sealing to keep contents colder longer while minimising temperature fluctuations and leakage.
5. Efficient Cooling: A high-efficiency copper wire compressor cools more rapidly with less power, thereby extending battery life during off-grid use.
6. Smart App Control: Enjoy simple, one-click control.
7. Versatile Charging Options: Multiple charging methods ensure continuous, uninterrupted outdoor comfort.
8. 2-Year Warranty
Accessories
£299
£299
£299
£299
£299
£299
£299
£299
Gift
£649.00
Keep Fresh Here, Frozen There
Dual-zone flexibility*
The dual-zone design (45L & 55L only) lets you store fresh and frozen food simultaneously with a maximum temperature difference of 22°C. Advanced sensors maintain precise conditions (±1°C) to keep food perfectly fresh.
*The 35L model features single-zone cooling, switchable between fridge and freezer modes.
Sized Down, Packed Up
40%* more compact design, giving you more space in your car—a true home on the move.
The EcoFlow GLACIER Classic maximizes storage efficiency, fitting 58 cans (35L), 72 cans (45L), and 90 cans (55L) of 330ml soda while staying sleek and space-saving.
*Based on laboratory testing data, the external dimension is 40% smaller than that of standard electric coolers.
40% more compact than the industry average
Built for Every Scenario
Car Camping
RV Camping
Tent Camping
Tailgating
Grocery Runs
Up to 43 Hours of Fresh
298Wh plug-in battery*
The EcoFlow GLACIER Classic keeps your items chilled at 4°C for up to 43 hours (35L) or 39 hours (45L and 55L)**
*The EcoFlow GLACIER Plug-in Battery is sold separately.
**Tested at 25°C ambient temperature with a fully charged battery.
No melted ice, no soggy food
Max Performance, Minimal Effort Energy-saving cooling system
60% thicker insulation for better cooling*
53mm/2-inch insulation foam and superior sealing keep food cold longer by reducing temperature changes and minimizing leakage.
*Based on laboratory testing data, the insulation thickness is 60% thicker than that of standard fridges.
Efficient compressor for extended runtime
The high-efficiency copper wire compressor delivers powerful cooling with 40% lower power consumption than standard fridges, extending battery life for longer off-grid use.
Dual-Sided Door Access
Road-Ready
Effortless Slide Rail*
Access your items from either side, no matter how the cooler is positioned in your vehicle. The dual-sided door design ensures flexible, hassle-free access, making it suitable for any setup.
Available in 35L, 45L, and 55L capacities, the EcoFlow GLACIER Classic 35L is comparable to a standard 24-inch suitcase. It's an ideal fit for SUVs, Class B RVs, off-road vehicles, and more, saving valuable space while providing ample storage for your adventures.
Easily slide the GLACIER Classic out of your car, even in tight spaces. Perfect for narrow parking or camping setups, it reduces strain and makes loading and unloading effortless.
*The Slide Rail is an optional accessory.
Adventure-Ready Accessories
GLACIER Classic accessories >>
Detachable pegboard
Provides vertical storage for tools, condiments, or other essentials, enhancing outdoor convenience.
Storage bag
Keeps small items like cans, cutlery, or condiments neatly organized and easy to access.
Hidden Dual-Side Wide Handles
It's All on the App
Powered by EcoFlow Oasis
Max Mode
Eco Mode
Temperature Alert
Get notified if the internal temperature deviates by over 5°C for 10+ minutes, keeping items like meat and dairy safe.
Temperature History
Coolness That Never Stops
Multiple charging options
*For optimal performance, use the plug-in battery to avoid unstable power due to inconsistent sunlight. The EcoFlow GLACIER Plug-in Battery is sold separately.
*Compatible with EcoFlow 500W and 800W Alternator Chargers.
Doubles as a power bank
EcoFlow AC Power Adapter
Basket
Basket
EcoFlow Car Charging Cable
Temperature zone divider (for 45L and 55L)
Safety Instructions, Quick Start Guide, Warranty Card
What to Do After Receiving GLACIER Classic?
Inspect the packaging for damage. Open the box and confirm all parts are included.
Plug the fridge into a household power outlet, turn it on, connect to Wi-Fi via the EcoFlow app, and update the firmware.
⚠️ Keep it plugged in during updates!
Usage Tips
1.Avoid direct sunlight – it weakens cooling performance.
2.Close the lid properly – if reversed, it won’t seal tightly and will trigger an alarm.
3.For 45L & 55L models: Ensure the inner divider faces the correct direction to maintain dual-zone cooling.
How to Power the GLACIER Classic?
1.Shore Power outlet (via XT60 port).
2.Solar panel
3.Battery pack (supports Type-C direct charging).
How to Charge the Battery Pack?
1.Charge through the fridge’s host port.
2.Use a Type-C cable (direct charging).
GLACIER Classic Won’t Turn On – How to Fix?
1.Check power connection:Plug it into a shore power outlet first. If it starts, the battery was fully drained.
2.Low battery discharging limit:If the battery is below the discharging limit, plug it in to charge.Optional: Set the discharging limit to 0% in settings. This gives you 1 extra minute of runtime before shutdown.
3.Future improvement:A firmware update will soon improve low-battery handling for smoother operation.Still stuck? Contact support for help! 😊
First-Time Use Tips
1.Wipe the interior with clean water before first use (removes dust from shipping).
2.Let it sit 2 hours upright before turning it on.
Dimensions of GLACIER Classic
35L: 27.8×15.7×15.9 inches (706×400×405 mm)
45L: 27.8×15.7×18.9 inches (706×400×480 mm)
55L: 27.8×18.3×18.9 inches (706×466×480 mm)
Temperature Range
-4°F to 68°F (-20°C to 20°C)
Noise Level
Quieter than a library – under 38.5dB.
Power Input Specs
AC Input: 100-240V~50/60Hz, max 95W
Solar Input: 11-30V--8A, max 110W
Car Charger: 12/24V=8A, max 100W
Specs - GLACIER Classic 35L
Dimensions- external
706×400×405 mm /
27.8×15.8×15.9 in
Dimensions- internal
487×284×298.5 mm /
19×11×11.7 in
20,5kg
Usable Volume
35L
Number of 330ml Cans
58 cans
Temperature Zone
Variable Dual Temperature
AC Input
AC Adpater: 95W max,14.5V;
100-240V 50/60Hz
DC Input
Solar Charging: 11-30V, 8A /110W max
Battery Runtime
43 hr
(Tested @ Ambient temperature: 25°C, Eco mode)
Rated Power
55W
Noise
< 38.5 dB
Protection Level
IPX4
(-20°C) ~ (20°C)
(-10°C) ~ (50°C)
Storage Temperature
(-20°C) ~ (60°C)
Temperature Accuracy
Eco mode: ±2~3°C; Max mode: ±1°C
Refrigeration(4°C): 165wh/24h; 0.57 Ah/h
Freezing (-18°C): 520wh/24h; 1.8 Ah/h
App
Suppported
2 Years(ES 3 Years)
Refrigerant
R600a
What's in the Box
1. EcoFlow AC Power Adapter
2. Basket
3. EcoFlow Car Charging Cable
Specs - GLACIER Classic 45L
706×400×480 mm /
27.8×15.8×18.9 in
487×284×373.5 mm /
19×11×14.7 in
23,2kg
Usable Volume
45L
72 cans
Temperature Zone
Dual Temperature Zone
AC Input
100-240V 50/60Hz
DC Input
Battery Runtime
39 hr
Rated Power
55W
Noise
< 38.5 dB
Protection Level
IPX4
(-20°C) ~ (20°C)
*The left and right temperature zones support a 22°C temperature difference
(-10°C) ~ (50°C)
Storage Temperature
(-20°C) ~ (60°C)
Refrigeration(4°C): 190wh/24h; 0.67 Ah/h
Freezing (-18°C): 750wh/24h; 2.6 Ah/h
App
Suppported
2 Years(ES 3 Years)
Refrigerant
R600a
What's in the Box
2. Basket
4. Temperature Zone Divider
Specs - GLACIER Classic 55L
706×466×480 mm /
27.8×18.4×18.9 in
487×350×373.5 mm /
19×13.8×14.7 in
25,2kg
Usable Volume
55L
72 cans
Temperature Zone
AC Input
100-240V 50/60Hz
DC Input
Battery Runtime
39 hr
Rated Power
55W
Noise
< 38.5 dB
Protection Level
IPX4
(-20°C) ~ (20°C)
(-10°C) ~ (50°C)
Storage Temperature
(-20°C) ~ (60°C)
Refrigeration(4°C): 190Wh/24h;0.67 Ah/h
Freezing (-18°C): 750Wh/24h;2.6 Ah/h
App
Suppported
2 Years(ES 3 Years)
Refrigerant
R600a
What's in the Box
2. Basket
Thanks for subscribing!
Explore More
