Buy EcoFlow RIVER mini Portable Power Station — EcoFlow UK - RIVER mini (Standard) - EcoFlow UK
EcoFlow UK
12 payments of £16 58 at 0% interest with Splitit. Learn more
30 Days Price Guarantee
Regular price £199.00
Sale price £199.00 Regular price £299.00
Save up to £100.00
Days
Hours
Minutes
Seconds
Autumn Sale × EcoCredits Week:Earn Up to 2.5× EcoCredits!
Learn More
This item is no longer for sale on EcoFlow official website. We recommend you to check out our RIVER 2 Series and other promotional items.
• 210Wh of Power at Hand
• Includes a variety of ports to power up to 7 devices at once
• 1.5 hours X-Stream fast charging
• Lightweight and portable: 2.8 kg, easy to carry
• 100W solar input, recharge in 2 hrs
• App control
£199.00 £299.00 -£100.00
Fast Charging
Multiple Ports
Power Multiple Devices
Lightweight & Portable
Power the big stuff.
Packing a 300W (600W surge) output you can power laptops, tablets and even projectors with ease.
Fast, convenient charging.
Looking for a power source that charges faster than a powerbank? Go from 0-80% in 1 hour using a standard plug socket. If you’re on the road add juice using solar or by connecting it to your car.
All the ports you’ll need.
Designed to charge several devices at once. RIVER mini comes with an AC wall outlet, DC car outlet, 3 USB-A slots and a USB-C rapid-charging port so you can keep multiple devices charged, powered or both. If you’re getting the wireless model, you’ll have all of that and a wireless charging pad.
* USB-C fast-charge port and wireless charging pad are exclusive to the wireless version of RIVER mini.
Take hold of power.
RIVER mini is a portable, powerful power source that you can pick up and take on your outdoor adventures without breaking a sweat.
Built with safety at its core.
The sophisticated battery management system regulates current, temperature and voltage so you can rest assured your RIVER mini will work safely for years to come.
Ground-breaking charging speeds.
Simply plug your RIVER mini into a standard wall socket and charge to full in just 1.5 hour.
Charge on the road.
Need to add juice whilst you travel? Link up your RIVER mini to your car and get a full charge in 3.5 hours.
AC Charging
Charge from AC wall outlets in 1.5 hour.
RIVER mini has a 210Wh capacity. That’s roughly 58400mAh. In other words, it's much larger than a powerbank, and much more portable than most power stations. The goldilocks zone.
RIVER mini is 2.85kg, light enough to throw in your backpack and take anywhere.
RIVER mini has a 300W output (600W surge); that means it can power 99% of your devices such as phones, laptops, lights, and fans. However, you can check what wattage your device uses to confirm compatibility.
RIVER mini supports solar charging, ideal for camping and the outdoors. It supports up to 100W of solar input charging to full in 3–6 hours. Just make sure your solar panel hits these specs: 11–39V, 8A, up to 100W.
Approximately 2.85kg
24.9*14.0*13.3cm
210Wh
DC Input
11-39V 100W, 8A Max
AC Input
220-240V~ 50Hz/60Hz, 1.4A Max
Pure Sine Wave, 300W total (Surge 600W), 230V~(50Hz/60Hz)
Wireless Output (Only for RIVER mini Wireless)
15W Max
USB-C Output (Only for RIVER mini Wireless)
100W, 5A Max
5V 2.4A
DC Output
12.6V 10A
Cell Chemistry
NCM
80%+ capacity after 500 cycles
Discharge Temperature
-20°C to 45°C
Charge Temperature
0°C to 45°C
Optimal Operating Temperature
20°C to 30°C
Storage Temperature
-20°C to 45°C
Shelf Life
1 year (after a full charge)
Thanks for subscribing!
Explore More
