Buy EcoFlow NextGen 220W Bifacial Solar Panel — EcoFlow UK - NextGen 220W Bifacial Portable Solar Panel (Refurbished) - EcoFlow UK
EcoFlow UK
30 Days Price Guarantee
EcoFlow NextGen 220W Bifacial Portable Solar Panel (Refurbished)
Regular price £289.00
Sale price £289.00 Regular price £349.00
Save up to £60.00
Days
Hours
Minutes
Seconds
Autumn Sale Is Coming | Sep 7–13 | Find the Hidden ⚡
Learn More
· Collect up to 25% more energy with a two-in-one bifacial design
· Durable tempered glass & ETFE coating; built to last
· IP68 rating protects against water and dust
· The solar to XT60i charging cable is included in EcoFlow portable solar panels
>>>User Manual
£289.00 £349.00 -£60.00
PayPal
Ultra-Portable Design
Engineered with advanced lightweight materials, this next-gen solar panel weighs 4.4kg, 46% lighter than the 220W Bifacial Portable Solar Panel, enabling effortless transport and compact storage.
Built-in XT60
The integrated XT60 cable makes it easier to store and connect to portable power stations for a faster setup.
Capture More Energy with a Bifacial Design
With primary and rear-side panels for ambient light, output power reaches up to 243W under BNPI test conditions, generating more power from the same amount of sunlight compared to traditional monofacial panels. With industry-leading TOPCon solar technology, the portable solar panel achieves a top-level conversion rate of up to 25%, recharging your power station even faster.
Suitable for Various Environments
The folding integrated bracket offers a convenient and compact design. Adjustable from 30°-60°, it's ideal even for most high-latitude areas.* If you need to hang solar panels for extended periods, please use rigid solar panels. Lightweight portable solar panels are not recommended for this scenario.
Integrated Solar Angle Guide
Keep sunlight at a 90° angle and concentrate the sun's rays onto the surface of your solar panel to get the most light at all times.
Durable and Water-Resistant
Rated Power
STC 220W/ BNPI 243W
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25%
Weight (Solar Panel)
5.1kg±0.3kg
Unfolded: 2270mm*598mm*26mm
Folded: 603mm*598mm*36mm
Connector Type
XT60
2 years
Open Circuit Voltage
STC Voc 21.4V (Vmp 18.8V)
BNPI Voc 21.4V (Vmp 18.8V)
Short Circuit Current
STC Isc 12.2A (Imp 11.7A)
BNPI Isc 13.5A (Imp 12.9A)
Waterproof & Dustproof
Thanks for subscribing!
Explore More
