EcoFlow DELTA Pro Remote Control - Default Title - EcoFlow UK
EcoFlow UK
£99.00
EcoFlow 2025 Members' Festival 🎉
Regular price £99.00
Sale price £99.00 Regular price £99.00
The first of its kind: The first remote control for a portable power station, designed for DELTA Pro. Ideal for storing your DELTA Pro in the garage, storage bay, or below deck. Connect over Bluetooth or an ethernet cable and get a second screen right where you need it.
Monitor your energy: The display shows how much energy you’re using, the remaining battery time, and everything else DELTA Pro’s screen shows. It’s also a convenient place to turn on/off the AC outlets, DC outlets, or entire unit.
Two ways to connect: Move the screen around when connected with Bluetooth; set it and forget it with a wired connection that works over longer distances.
Control at a distance: Once set up, you can monitor & control your portable power station from afar. Ideal when your DELTA Pro is set up with solar panels, or at a charger.
Note: This accessory is only compatible with the EcoFlow DELTA Pro.
£99
1. Remote Control 2. User Manual
Internal Battery
Non-rechargeable AAA
USB-C Input
5V⎓
Wired Connection
12V⎓ (standard ethernet cable)
Customer Reviews
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
