Buy EcoFlow DELTA Portable Power Station — EcoFlow UK - EcoFlow UK
EcoFlow UK
30 Days Price Guarantee
Summer Sale 🏖️
Regular price £549.00
Sale price £549.00 Regular price £1,299.00
Save up to £750.00
Days
Hours
Minutes
Seconds
• The new standard of battery-powered generators
• Charge from 0%-80% within 1 hour
• 6x AC Outlets (Total 1800W) & 1260Wh capacity
• Fast charge via solar and car
• Power 11 devices simultaneously
£549.00 £1,299.00 -£750.00
Stay in charge of any situation with DELTA and keep your devices powered at all times. DELTA has a huge 1260Wh capacity that's perfect for power outages, outdoor adventures, and professional work.
High Capacity
X-Stream Fast Charge
4 x AC Outlets (Pure Sine Wave)
More Ports Than You'll Need
Never lose power again
DELTA has a huge 1260Wh capacity that keeps your home devices fully charged during power outages and emergencies.
The world's fastest charging portable power stations
EcoFlow have the world's fastest charging power stations. DELTA charges from 0-80% in under an hour, giving you a quick boost of power even during the worst situations.
Power your essential devices
With 4 x AC outlets (1800W total rated output, pure sine wave outlets), DELTA lets you power essential devices when you're at home and heavy-duty power tools when you're working outdoors.
One device to rule them all
DELTA can power up to 11 devices at the same time. That's enough juice for brewing a cup of coffee, listening to your favourite radio station, or journeying into Middle-earth again.
Title
Light 10W
Fridge 150W
Microwave Oven 1000W
Washer (500-1000W)
Television 110W
Hair Dryer 1600W
Coffee Maker 600W
Electric Fry Pan 1500W
Phone 3Ah
Laptop 60W
Camera 18Wh
Drone 60Wh
Electric Vehicle 1800W
Blender 400W(850W)
Electric Grill 1650W
Circular Saw 1400W
Drain Cleaner 250W
Welding Machine 1800W
Drills 1080W
Bench Grinder 1400W
Concrete Vibrator 840W
Air Compressor 975W
Hammer 1260W
DELTA can be recharged to 0%~80% in 1 hour, and be fully recharged within 1.6 hours.
Under perfect sunlight conditions, DELTA can be fully charged with the following solar panel setups: 1x 110W solar panel: 14-28 hrs; 2x 110W solar panel (in series): 7-14 hrs; 3x 110W solar panel (in series): 5-10 hrs; 4x 110W solar panel (in parallel): 4-8 hrs
Yes. During this situation, DELTA will prioritise AC charging, and default to DC charging when AC charging is not used.
DELTA supports an entry-level UPS function. We recommended testing your devices case-by-case.
DELTA can power essential devices whether you're at home or outdoors. Devices include lights, microwave ovens, fridges, hairdyers, laptops, phones, electric frying pans, and more.
DELTA does not support EcoFlow App.
30.9lbs (14kg)
Dimension
15.7 x 8.3 x 10.6 in (40 x 21 x 27 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
Color
Gray & black
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel
Full Recharge Time
1.6 Hours (AC) 13.5 Hours (12V Car Charger) 4-8 Hours (Using 4x 110W Solar Panels) 3.5-7 Hours (Using 3x 160W Solar Panels)
1260Wh (50.4V)
Cell Chemistry
Lithium-ion
Life Span
800 Cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection.
Testing and certification
UL CE FCC RoHS PSE
Cell Type
18650
AC Charge Input Power
X-Stream charge (1200W max)
AC Charge Input Voltage
220-240Vac
Solar Charge Input
400W 10-65V DC 10A max
Car Charger
12V/24V DC 8A max
AC Output (x4)
1800W (Surge 3300W) total, 230ac (50Hz)
USB-A Output (x2)
5V DC, 2.4A, 12W Max, per port
USB-A Fast Charge (x2)
5V/2.4A,9V/2A,12V/1.5A 18W Max, per port
USB-C Output (x2)
5V DC, 9V DC, 15V DC, 20V DC, 3A, 60W Max, per port
Car Power Output (x1)
108.8W, 13.6V DC, 8A max
