EcoFlow DELTA Max Solar Generator (Rigid PV400W*2) - DELTA Max 2000 / Without Extra Battery - EcoFlow UK
EcoFlow UK
30 Days Price Guarantee
Regular price £1,168.00
Sale price £1,168.00 Regular price £1,588.00
Save up to £420.00
Days
Hours
Minutes
Seconds
Autumn Sale Is Coming | Sep 7–13 | Find the Hidden ⚡
Learn More
DELTA Max
Home emergency power - DELTA Max expands up to 6kWh with smart extra batteries, keeping your home powered on in any emergency.
Rapid dual charging - Charge up from 0-80% in 65 minutes. Or get up to 3400W speeds by combining AC charging and the EcoFlow Smart Generator.
Power multiple devices - Looking for something to power heavy-duty devices like your fridge and dryer? With X-Boost, DELTA Max handles devices up to 3400W with ease.
400W Rigid Solar Panel
Fast Charging - With a high conversion efficiency rate of up to 23%, the 400W panel charges your LFP batteries faster than similar-sized solar panels.
Weatherproof & Durable - The rigid panel balances design with robust materials allowing the panel to weather any storm while offering the same excellent performance and aesthetics for years.
Off & On-grid Solution - This high-wattage panel works for both on-grid and off-grid solar-powered setups, storing energy for outages, reducing power bills, or powering an off-grid home.
Universally Compatible - The 400W solar panel includes a 300mm charging cable that gives you plenty of space, maximizing solar input. With an all-inclusive solar connector, the 400W rigid panel works with other 3rd party solar systems and power stations.
DELTA Max Smart Extra Battery
More of DELTA Max - Double runtime with this add-on battery that plugs into any DELTA Max portable power station. Add up to two Extra Battery units for a total capacity of 6048Wh.
Convenient recharging - DELTA Max and its Extra Battery charge and discharge in unison. Whether you're recharging DELTA Max from solar panels, AC outlets, a vehicle, or our Smart Generator, the DELTA Max Extra Battery will recharge alongside.
Model
Option of Extra Battery
£1,168.00 £1,588.00 -£420.00
PayPal
Thanks for subscribing!
Explore More
