EcoFlow DELTA Max Solar Generator (Flexible PV100W) - EcoFlow UK
EcoFlow UK
30 Days Price Guarantee
Summer Sale 🏖️
Regular price £867.00
Sale price £867.00 Regular price £977.00
Save up to £370.00
Days
Hours
Minutes
Seconds
DELTA Max Portable Power Station
Home emergency power - DELTA Max expands up to 6kWh with Smart Extra Batteries, keeping your home powered on in any emergency.
Rapid dual charging - Charge up from 0-80% in 65 minutes. Or get up to 3400W speeds by combining AC charging and the EcoFlow Smart Generator.
Power multiple devices - Looking for something to power heavy-duty devices like your AC and dryer? With X-Boost, DELTA Max handles devices up to 3400W with ease.
Stay powered on no matter what. - Connect up to 8 x100W EcoFlow Solar Panels to deliver 800W of solar input. Charging DELTA Max in as fast as 5.5 hours.
100W Flexible Solar Panel
Extremely Light - At only 2.3kg, this flexible solar panel is easy to move and install, barely adding any weight to your vehicle. Flexible solar panels are perfect for roofs that can only support a light load, such as tents and awnings.
Flexible - Its adaptable design can fit a multitude of curved surfaces, making it ideal for mounting on RVs, van roofs, and boats.
Weatherproof - With a waterproof level of IP68, the flexible solar panel can be used in all weather and can withstand dirt, dust, debris, and low-pressure water jets.
Universally compatible - The 100W flexible panel includes a 1m charging cable that gives you plenty of space to position each panel, maximizing solar input. With an all-inclusive solar connector, the 100W rigid panel works with other 3rd party solar systems and power stations.
Model
Number of Solar Panels
£867 00 £977 00 -£110 00
Next Level Capacity
Dual Charging
More Ports Than You'll Need
800W max Solar Input
Expandable home backup power.
With EcoFlow's X-Boost technology, DELTA Max can power heavy-duty devices up to 3000W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That's the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 8x 100W flexible solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the solar connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Multiple ways to charge.
1. DELTA Max 2. AC Charging Cable 3. Car charging cable 4. DC5521 to DC5525 cable 5. User Manual and Warranty card 6. 100W Flexible Solar Panel* 8. Solar to XT60 Charging Cable 9. Support Brackets
*The number of Solar Panels depends on the bundle you order.
*An additional Solar Parallel Cable will be provided with the bundle of 6 solar panels.
It depends on the total voltage and watts of solar panels you choose. As long as the solar panels use MC4 connector and its voltage and current are under 11-100V, 13A max range.
When charging DELTA Max and its extra battery together, you can reach 3600W max charging speeds by combining any two methods of AC, solar and Smart Generator. For DELTA Max single unit, you can recharge it at standard wall outlets (1800W max), or combine AC and solar charging to reach max 2000W charging speeds.
When your portable power station is plugged into the wall, any electronics plugged into it are powered from the grid and not its battery. When power from the grid stops, as in a blackout, the power station automatically switches to battery power within 30ms.
DELTA Max is not water-resistant, so it should be kept away from liquids. Or if you're looking for water-resistance solution, you can purchase the DELTA Max case to water-resistance protection.
Specs of DELTA Max (2000)
Approx. 48 lbs (22 kg)
Dimension
19.6 x 9.5 x 12 in (49.7 x 24.2 x 30.5 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel, Smart Generator, Smart Extra Battery
Full Recharge Time
1.6 Hours (AC) 21 Hours (12V Car Charger) 5.6-11.2 Hours (Using 4x 110W Solar Panels) 4.2-8.4 Hours (Using 4x 160W Solar Panels) 3.2-6.3 Hours (Using 2x 400W Solar Panels)
2016Wh
Cell Chemistry
NCM
Cycle life
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certification
CE WEEE CTP RCM KC
AC Charge Input (Power)
X-Stream charge (2000W max)
AC Charge Input (Voltage and Amperage)
220-240V~50Hz/60Hz, 10A
Solar Charge Input
11-100V 13A Max, 800W max
Car Charge Input
Supports 12V/24V Battery, Default 8A
AC Output (x4)
Pure Sine Wave, 2400W total (surge 4600W), 230V~ (50Hz/60Hz)
3000W
USB-A Output (x2)
5V 2.4A, 12W max, per port
USB-A Fast Charge (x2)
5V/2.4A, 9V/2A, 12V/1.5A, 18W Max
USB-C Output (x2)
5/9/12/15/20V 5A, 100W max
Car Charger Output (x1)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Supports up to 2 DELTA Max Smart Extra Batteries (sold separately)
Smart Generator
Supported (sold separately)
Wi-Fi
Supported
Specs of DELTA Max (1600)
Dimension
Charge Temperature
24 months
Charge Method
Full Recharge Time
1.6 Hours (AC) 16.8 Hours (12V Car Charger) 4.5-9 Hours (Using 4x 110W Solar Panels) 3.4-6.8 Hours (Using 4x 160W Solar Panels) 2.5-5 Hours (Using 2x 400W Solar Panels)
1612Wh
Cell Chemistry
NCM
Cycle life
500 Cycles to 80%+ capacity
Management Systems
CE WEEE CTP RCM KC
X-Stream charge (1600W max)
Solar Charge Input
Car Charge Input
AC Output (x4)
Pure Sine Wave, 2000W total (surge 4600W), 230V~ (50Hz/60Hz)
2500W
USB-A Output (x2)
USB-C Output (x2)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Smart Generator
Wi-Fi
Supported
Car charger shares power with the DC5521 output port offering maximum output of 126W.
Whether the product can be charged or discharged depends on the actual temperature of the battery pack
DELTA Max (2000) needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
