EcoFlow DELTA 3 Max Series Portable Power Station | EcoFlow UK - DELTA 3 Max Plus (2048Wh) / DELTA 3 Max Plus Smart Extra Battery - EcoFlow UK
EcoFlow UK
EcoFlow DELTA 3 Max Series (2048Wh) Portable Power Station
Regular price £1,898.00
Sale price £1,898.00 Regular price £2,198.00
Save up to £399.00
Days
Hours
Minutes
Seconds
Autumn Savings Start Now 🍂
Up to 60% Off | Limited-Time Flash Deals
Learn More
Referral Reward: 10% Discount for your friend, 5% Cashback for you! Refer Now
Learn more
Referral Reward: 10% discount on our New DELTA 3 Max Series and get 5% Cashback!
- Coupon Reward: Each referred new user receives 10% off coupon for their first purchase of the EcoFlow DELTA 3 Max Series. The discount cannot be combined with other coupons or discounts.
- Referral Leaderboard Prizes: The top referrer by number of registrations will receive one EcoFlow DELTA 3 Max Smart Extra Battery. The top referrer by total referred order amount will receive one EcoFlow DELTA 3 Max.
- Industry-leading 3000W AC output, 6000W surge output
- Industry-First Full-Tab LFP Cells, exclusive smart BMS with 24/7 protection
- 5 fast recharging methods: AC, Solar, Alternator Charger, Smart Generator, and Multi-charging
- <10 ms UPS Auto-Switch
- Intelligent energy management system
- Expandable 2-10 kWh capacity with DELTA 3 Max Plus Extra Battery, DELTA 3 Extra Battery, DELTA Pro 3 Extra Battery, or DELTA 2 Max Smart Extra Battery.
Model
Accessories
£1,898.00 £2,198.00 -£300.00
PayPal
Always Ready. More Power.
Industry-First 2kWh Solar Battery with Max 3000W Output (DELTA 3 Max Plus)
25% More Power [3]: 3000W Output, 2kWh Capacity
A New Era of Power Performance
Next-level energy for next-level peace of mind.
3000W Output, 6000W Surge — Powerful. Stable. Built to Handle It All.
DELTA 3 Max Plus delivers 3000W AC rated output (6000W surge). With X-Boost™ 3.0 technology, it supports devices up to 3900W—effortlessly taking on your heavy-duty appliances. The inverter samples AC voltage and current every 33μs with high precision using a DSP chip, ensuring pure sine wave output with beyond grid-level stability—ideal for powering sensitive electronics reliably.
Kitchen
Living Room
RV Camping
Office
Garage
Laundry Room
Kitchen
Kitchen
Living Room
Living Room
RV Camping
RV Camping
Office
Office
Garage
Garage
Laundry Room
Laundry Room
All Your Essentials. All at Once.
DELTA 3 Max Plus delivers a powerful 3000W output—enough to run your microwave, kettle, fridge, and blender all at once without a flicker. Lunchtime? Go full throttle. No unplugging, no interruptions—just seamless power. [4]
Pick Your Priority Outputs, Extend What Matters Most
Smart Remote Switching | Reduce waste to increase runtime for essentials
DELTA 3 Max Plus introduces Smart Output Priority Tech. This convenient new feature lets you choose which circuits stay powered via the app. Prioritize what matters—like your fridge, Wi-Fi—and extend runtime when it counts most, even when you're away.
Smart Power Reserve | Set your desired battery threshold (%) to automatically shed non-essential loads during outages
With app-based presets, DELTA 3 Max Plus automatically follows your priority settings during outages—shutting off lights while keeping your fridge running. Wake up to fresh food and plenty of power left—just like nothing happened.
Automotive-grade full-tab LFP cells
Automotive-grade Full-Tab LFP Cells: Next-Level Battery Reliability
DELTA 3 Max Plus is equipped with automotive-grade full-tab LFP cells. The full-tab design reduces resistance, enhances efficiency and safety, and provides higher capacity with less heat, resulting in a longer battery lifespan.
Unrivaled Balance for Unmatched Battery Longevity
With 27% fewer cells per kWh, [7] our 16-cell design runs cooler, lasts longer, and delivers greater stability. Each cell is rigorously tested for capacity, voltage, and internal resistance—resulting in a highly uniform pack that protects against overcharging, imbalance, and premature wear.
Built to Last
From battery chemistry to structural design, DELTA 3 Max Plus is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years. [2]
Ultra-versatile 5 charging options, 47-minute fast charge [1]
A New Level of Fast
Remote charging control for added peace of mind.
5 Ways to Charge Up — Ready in Just 47 Mins [1]
AC Charging
Alternator Charging
Generator Charging
Solar + Alternator Dual Charging
2300W Input, 0-80% in 47-min fast charging with X-Stream technology. [10] Stay one step ahead with EcoFlow's exclusive Storm Guard Mode, [11] which monitors severe weather alerts and automatically triggers AC charging remotely.
1000W solar input, 0-80% in 96 mins, gives you a faster and more flexible solar setup.
1000W Input, 0-80% in 95 mins. With the EcoFlow Alternator Charger Plus 1000, [12] get ready in just 95 minutes while on the move—10× faster than conventional solutions. [13]
Hybrid Power with Generator, 0-80% in 47 mins with 2400W AC Input.Stay powered even without sunshine, with app control and compatibility with third-party generators.
Go from 0-80% charged in just 51 minutes—dual input from 1000W solar and 1000W alternator charging keeps you powered faster than ever, even on the go.
Monitor your energy usage, savings, and solar generation—all with one intuitive dashboard. Easily track battery status, solar forecasts, real-time electricity rates, and financial savings.
Cut Costs, Not Comfort
Charge During Low-Cost Periods to Save BigDELTA 3 Max Plus intelligently optimizes energy usage to help lower your electricity bills while powering your home sustainably. Set automated tasks to charge during off-peak evening hours and discharge during the day.
2–10kWh expandable capacity
Easily Scales Up—From Hours to Days
Half-Day Power Usage
1-Day Power Usage
2-Day Power Usage
3-Day Power Usage
Covers essential power needs during a 4–8 hour outage—keeping food fresh, heat running, lights on, and communication devices charged. [15]
Delivers 1 day of outage protection—ensuring uninterrupted cooking, heating, lighting, and connectivity. [15]
Powers home essentials for up to 2 days [15] with 6kWh capacity—keeping your kitchen running, lights on, and devices connected. [16]
*Require connecting 1 × DELTA 3 Max Plus + 2 × DELTA 3 Max Plus Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
Supports a family of four through 3 days of everyday living [15] with 10kWh capacity——keeping food fresh, heat running, lights on, and entertainment devices charged. [17]
Compact, Portable, Lighter than Ever - Works Anywhere
Lightweight and easy to carry, DELTA 3 Max fits into any setting from home to the great outdoors. Weighing just 20.3 kg, it's 13% lighter [3] for effortless portability while still packing serious power.
Comparison
What's in the Box
What's in the Box
What's in the Box
What's in the Box
What's in the Box
What's in the Box
DELTA 3 Max
DELTA 3 Max Plus
Color
DELTA 3 Max - Black and Gray
DELTA 3 Max Plus - Silver
2048Wh
DELTA 3 Max - Approx. 20.3 kg
DELTA 3 Max Plus - Approx. 22.1 kg
DELTA 3 Max - 494 × 239 × 305 mm
DELTA 3 Max Plus - 494 × 242 × 305 mm
Total Output Ports
DELTA 3 Max - 9
DELTA 3 Max Plus - 10
Number of AC Outlets
4
Output Priority
DELTA 3 Max - NO
DELTA 3 Max Plus - YES
Max AC Output
DELTA 3 Max - 2400W
DELTA 3 Max Plus - 3000W
Surge Output
DELTA 3 Max - 4800W
DELTA 3 Max Plus - 6000W
Max Output by X-Boost
DELTA 3 Max - 3200W
DELTA 3 Max Plus - 3900W
X-Fusion
DELTA 3 Max - NO
USB-A
1 × 18W Max
USB-C
DELTA 3 Max - 1 × 100W Max(HID); 2 × 30W Max(Total 30W)
DELTA 3 Max Plus - 1 × 140W Max(HID); 2 × 45W Max(Total 45W)
12V DC Output
DELTA 3 Max - 126W Max; Car Power Output × 1:12.6V⎓10A
DELTA 3 Max Plus - 378W Max; Car Power Output × 1:12.6V⎓10A; Anderson Output × 1:12.6V⎓30A
AC Charging
2300W (68 min)
DELTA 3 Max - 500W
DELTA 3 Max Plus - 1000W
Generator Charging
2400W Max
Alternator Charging
DELTA 3 Max - 500W Max (Through XT60 Port)
DELTA 3 Max Plus - 1000W Max (Through 4+8 Port)
Car Charging
12V/24V⎓8A
Number of Extra Battery Ports
DELTA 3 Max - NO
DELTA 3 Max Plus - 1 (expandable to 2)
Type of Extra Battery Ports
DELTA 3 Max - NO
DELTA 3 Max Plus - 4+8
Compatible Extra Battery
DELTA 3 Max - NO
DELTA 3 Max Plus - DELTA 2 Max/DELTA 3 Max Plus/DELTA Pro 3/DELTA 3 Extra Battery
Max Capacity with Extra Battery
DELTA 3 Max - NO
DELTA 3 Max Plus - Up to 10kWh
UPS
DELTA 3 Max - 10ms
DELTA 3 Max Plus - 10ms + HID
Wi-Fi
YES
Bluetooth
YES
App
YES
3+2 years (Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration)
Noise
600W ≤ 25dB
Operating Altitude
≤3000m
Discharge Temperature
-10 to 45°C
Charge Temperature
0-45℃
Storage Temperature
-10 to 45°C
1. 0-80% in 47 minutes was measured in optimal conditions using X-Stream AC charging.
2. Based on proper product usage, DELTA 3 Max Plus is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
3. Compared with EcoFlow DELTA 2 Max.
4. The conclusion that multiple appliances can be powered simultaneously is based on internal testing. Actual performance may vary in real-world use.
5. Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
6. A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
7. Compared with the previous usage of EF #C33 Battery Cell.
8. Unless otherwise noted, all above data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
9. Noise levels measured at 0.5m under 25°C ambient: ≤25dB (600W) for charging/discharging.
10. All charging speed data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
11. Feature requires preset activation via the EcoFlow App.
12. EcoFlow Alternator Charger Plus 1000 will be launched soon and is sold separately.
13. Compared with car cigarette port charging.
14. Certain features in the EcoFlow app will be available soon. Please refer to the EcoFlow app for details on feature availability.
15. Multiple appliances' backup time based on ideal conditions; actual results may vary.
16. Require connecting 1 × DELTA 3 Max Plus + 2 × DELTA 3 Max Plus Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
17. Require connecting 1 × DELTA 3 Max Plus + 2 × DELTA Pro 3 Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
EcoFlow DELTA 3 Max Series Gift Promotion Terms & Conditions
The EcoFlow DELTA 3 Max Series Gift Promotion runs from 28 November 2025, 8 AM (BST) to 28 January 2026, 8 AM (BST) (hereinafter referred to as the "Promotion Period"). EcoFlow reserves the right to shorten or extend the campaign period at its sole discretion without prior notice.
Eligibility
The promotion is open to all European residents aged 18 years old and above as of 28 November 2025, 9 AM (CET).
Promotion Details
Free Gift with Purchase
1. The EcoFlow DELTA 3 Max Series orders placed between Promotion Period will receive a free NextGen 220W Bificial Portable Solar Panel or a EcoFlow 500W Alternator Charger. Each order is limited to one (1) free gift.
2. The promotional gift (EcoFlow NextGen 220W Bificial Portable Solar Panel or 500W Alternator Charger) will be automatically added to your cart when you add the standalone EcoFlow DELTA 3 Max and DELTA 3 Max Plus.
3. The promotional gift is non-transferable, and cannot be substituted for any other item, cash or credit.
4. If a refund is issued for the original order, the promotional gift must be returned.
Get 50% Off Solar Panel
1. Customers who place a DELTA 3 Max or DELTA 3 Max Plus order during the Promotion Period will have a chance to add one EcoFlow 400W Solar Panel at 50% off discount in the same bundle.
2. Full-priced items cannot be cancelled or returned separately. You must cancel and return the discounted products at the same time. If you need to keep the accessories, you will be charged at the original price.
Refer Your Friends
1. Duration:
- Start: 28 November 2025, 8 AM (BST)
- End: 28 January 2026, 8 AM (BST)
Participation Portal: https://www.ecoflow.com/uk/referral-delta-3-max-series
2. Referral Reward – New User Discount
3. Referral Leaderboard Prizes
3.1 Participants who successfully refer new users will be ranked on a referral leaderboard.
3.2 The top referrer by number of registrations will receive one (1) EcoFlow DELTA 3 Max Smart Extra Battery. The prize will be automatically issued as a redemption discount code at the end of each month. However, we will review the authenticity of the registrations, and any fraudulent invitation activity will result in cancellation of the prize.
3.3 The top referrer by total referred order amount will receive one (1) EcoFlow DELTA 3 Max unit. The prize winner will be determined based on backend sales data and issued before 7 December 2025, and 7 January 2026, for the previous month’s results. The prize winners will receive an email notification along with the redemption discount code.
3.4 Prizes are non-transferable, non-exchangeable, and cannot be redeemed for cash or other alternatives.
Please note
1. A Referrer's unique referral link may not be shared, sold or used in any way unless the Referrer is using it alone to obtain a Qualified Referral; Referrers are limited to one (1) Qualified Referral per Referred Client, and will not be credited for additional Qualified Referrals. Referral links shared with or obtained through other sources (e.g., links posted through third-party intermediaries or websites) will not be accepted.
2. If the Referrer and the Referee share an IP/device, only the Referee will be eligible for rewards. If EcoFlow determines that a Referrer has attempted to participate in the Program or receive Points or Rewards through cheating, hacking, spoofing, or any other unfair gaming practices or with the intent to annoy, abuse, threaten, or harass any other Referrer or any representative of EcoFlow, EcoFlow may, in its sole discretion, prohibit the Referrer from participating in the Program or receiving Points or Rewards.
General
(1) If you encounter any problems during the promotion, please contact support.eu@ecoflow.com for assistance.
(2) To the extent permitted by applicable law, we may decide to modify these rules or cancel the promotion at any time. If there is any fraud or abuse related to the promotion, we reserve the right to exclude any customer from the promotion. Fraudulent activities includ but not limited to automated entries, multiple registrations under different accounts, or fraudulent behaviour.
(3) Participants in the sale agree to be bound by the terms and conditions set forth herein and understand that EcoFlow's decisions are final and binding. No correspondence or appeals will be entertained. EcoFlow reserves the right to make the final and ultimate interpretation of this campaign.
(4) During the Campaign Period, all orders must comply with EcoFlow's purchase agreement and return policy.
(5) The sale promotion is not applicable to wholesale or distributor orders.
(6) Any unauthorized or fraudulent behaviour will result in disqualification of participants.
(7) Participants must comply with all applicable laws and regulations.
(8) EcoFlow reserves the right to stop, cancel, or change the promotion at any time during the promotion. Any changes will be announced on the EcoFlow official website.
(9) All prizes in this promotion are limited in quantity and are available on a first-come, first-served basis. Any matters not covered herein will be handled according to EcoFlow's final interpretation.
(10) EcoFlow will assume no responsibility for late entries, which may occur for any reason, including but not limited to network transmission failure.
(11) EcoFlow will not be responsible for any direct or indirect losses or damages incurred by any party, including the participants, in connection with, or arising from acts or omissions, or any way related to this campaign.
(12) EcoFlow shall not be liable for indirect or consequential losses arising from participation, except in cases of willful misconduct, gross negligence, or where liability cannot be excluded by law.
(13) EcoFlow reserves the right to cancel any order in case of pricing errors or fraudulent use.
(14) EcoFlow reserves the right to withdraw any benefits or discounts obtained.
(15) Employees of EcoFlow, its affiliates, and their family members are not eligible to participate.
Thanks for subscribing!
Explore More
