EcoFlow DELTA Solar Generator (PV160W) - UK / 1 - EcoFlow UK
EcoFlow UK
£848.00
EcoFlow 2025 Members' Festival 🎉
Regular price £848.00
Sale price £848.00 Regular price £1,598.00
Save up to £1,800.00
EcoFlow DELTA is the first of its kind when it comes to smart portable power stations. With colossal output and the ability to power almost all electronic devices, you’ll have more power no matter where you are.
Industry-leading recharge speeds Thanks to X-Stream technology, you can charge DELTA at 2-3 times the speed of industry-standard power stations. Go from 0-80% in 60 minutes or less. Reach 100% in 1.6 hours.
More ports & more power DELTA has a staggering 1800W Output, 1260Wh Capacity and 4x AC power outlets. Harness enough power to use all your home essentials and even some high-wattage power tools.
Multiple recharge methods DELTA comes with a sustainable recharge option. To charge in 4.9 hours link up 2x160W solar panels. Only have the 110W solar panels? No problem. 2x110W solar panels fully charges DELTA in 7.2 hours. If you’re looking to add juice on the move, connect DELTA through a 12V car socket and reach 100% in 13.5 hours.
Charge 11 devices at once With a variety of ports, all your favourite devices can remain charged and powered.
Socket Type
Number of Solar Panel
£848 £1,598 -£750
The world's fastest charging portable power stations
EcoFlow have the world's fastest charging power stations. DELTA charges from 0-80% in under an hour, giving you a quick boost of power even during the worst situations.
So Much More Sun
Premium monocrystalline silicon cells provide a high conversion efficiency of 21-22%. Recharge even faster by chaining multiple panels in a series or in parallel.
Better Together
Recharge freely and naturally when you link EcoFlow's 160W Solar Panel to a DELTA portable power station.
DELTA can be recharged to 0%~80% in 1 hour, and be fully recharged within 1.6 hours.
Yes. During this situation, DELTA will prioritise AC charging, and default to DC charging when AC charging is not used.
DELTA supports an entry-level UPS function. We recommended testing your devices case-by-case.
DELTA can power essential devices whether you're at home or outdoors. Devices include lights, microwave ovens, fridges, hairdyers, laptops, phones, electric frying pans, and more.
DELTA does not support EcoFlow App.
Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
Yes, if the only thing between it and the sun is transparent, but it won't charge as well compared to being outside. You can compare the difference by looking at the input section of your power station's LCD screen.
30.9lbs (14kg)
Dimension
15.7 x 8.3 x 10.6 in (40 x 21 x 27 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel
Full Recharge Time
1.6 Hours (AC) 13.5 Hours (12V Car Charger)
10.5-21 Hours (Using 1x 160W Solar Panel)
5-10 Hours (Using 2x 160W Solar Panels)
3.5-7 Hours (Using 3x 160W Solar Panels)
1260Wh (50.4V)
Cell Chemistry
Lithium-ion
Life Span
800 Cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection.
Testing and certification
UL CE FCC RoHS PSE
Cell Type
18650
AC Charge Input Power
X-Stream charge (1200W max)
AC Charge Input Voltage
220-240Vac
Solar Charge Input
400W 10-65V DC 10A max
Car Charger
12V/24V DC 8A max
AC Output (x4)
1800W (Surge 3300W) total, 230ac (50Hz)
USB-A Output (x2)
5V DC, 2.4A, 12W Max, per port
USB-A Fast Charge (x2)
5V/2.4A,9V/2A,12V/1.5A 18W Max, per port
USB-C Output (x2)
5V DC, 9V DC, 15V DC, 20V DC, 3A, 60W Max, per port
Car Power Output (x1)
108.8W, 13.6V DC, 8A max
Customer Reviews
Based on 23 reviews
87%
(20)
13%
(3)
0%
(0)
0%
(0)
0%
(0)
a
alun h.
Great product and excellent service from ecoflow
M
Michael S.
For the type of work I'm in this is a fantastic buy . Have recommend to several people at work. Worth the price and saves me a bunch headaches in the future
J
JoJo R.
Had to purchase when Governor Cuomo, closed April 30, 2021 the Nuclear plant that provided 25% of power for New York State with no replacement and backups. So we got backup
C
Cowdog
Are still testing it out but so far has powered everything I've tried. (refer, freezer, small travel trailer) Havent used solar panels yet. Charges very quickly from a plug in either house or truck. Love it's quietness and portability
L
Lee0129Amazon C.
This is peace of mind for maintaining my food supplies and basic comfort if the power grid is down for any length of time. It can charge with household current, car battery or Solar. And is safe to use inside the house.
P
P. K.
It took me two afternoons to charge the battery, but I only used one solar panel. The most wattage I could get was 100W. I may buy a second panel. I am testing the battery on a refrigerator now to see how long it lasts. I think it will be good for emergency backup.
