EcoFlow BLADE Robotic Lawn Mower | Automate Your Landscaping - BLADE - EcoFlow UK
EcoFlow UK
12 payments of £154 08 at 0% interest with Splitit. Learn more
Pice Guarantee
Regular price £1,849.00
Sale price £1,849.00 Regular price £1,849.00
Days
Hours
Minutes
Seconds
Power Up Your Autumn 🍂
Flash Deals & Autumn Savings All Week Long
Learn More
This item is no longer available on the official EcoFlow website. We recommend subscribing to EcoFlow's marketing emails to be the first to receive new product information or check out other promotional items.
• Industry's First Robotic Lawn Sweeping Mower
• Wire-free Boundaries
• X-Vision Obstacle Avoidance
• Wide Cutting Range
• Anti-theft
• Rain Sensor
• Comprehensive After-sales Services
£1,849.00
Checklist
EcoFlow BLADE
Let it Mow!
Leaf the hard work to us.
BLADE offers the complete lawn treatment, from a quick trim to an entire restyle. Attach the Lawn Sweeping Kit to remove unwanted debris, such as leaves, sticks, and waste, from your yard. You'll have the best-looking lawn in the neighborhood without any of the effort.
Virtually magic.
With our virtual boundary-setting technology, save time and energy without the need to lay pesky wire barriers. Set BLADE's mowing limits using the EcoFlow app within minutes, whether it's to stay within the confines of your yard, avoid specific objects, or even link two lawns. We've even got you covered if you move home or do some landscaping with easy-editable boundaries at the tap of a button.
Keep on Mowing With X-Vision Tech
Smart obstacle avoidance.
BLADE harnesses EcoFlow's newest cutting-edge tech, X-Vision. Combining visual sensors and LiDAR, BLADE intelligently recognizes and avoids obstacles big and small, from your lawn furniture to your neighbor's prize-winning begonias.
Automatic route planning.
With Real-Time Kinematic (RTK) positioning tech, BLADE re-routes around rogue debris within an inch of the original plan, so it never gets stuck or misses a cut.
Industry-first Design for Enhanced Cutting Performance
20 cm omnidirectional front wheels.
Wide cutting width.
Cuts between 20-76 mm.
With its wide, sturdy design, BLADE effortlessly traverses rough terrain, maneuvering rocks of up to 40 mm and ascending 27° slopes.
BLADE's additional width offers a cutting distance of over 26 cm, cutting more in less time.
To top it off, BLADE has a vast 20-76 mm grass-cutting range, adjustable in seconds using the app.
Anti-theft & Waterproof
Built to last.
Built to last.
Built to last.
Anti-theft.
Rain sensor.
Easy to clean and maintain.
With 4G, GPS, and an integrated eSim, you can track BLADE's location wherever it goes.
Its built-in rain sensor detects showers or bad weather, automatically sending BLADE back to its charger, keeping your lawn mud and furrow-free.
With an IPX5 water-resistance rating, hose down BLADE with a low-pressure water jet to dislodge debris or soil from the wheels.
Comprehensive Suite of Services
Extensive warranty of up to 4 years
Dedicated 1-1 service team
Replacements instead of repairing
Free accessories for life
With the EcoFlow Lawn Sweeper Kit*, BLADE can sweep the lawn while mowing and collecting leaves/waste/sticks, etc. automatically.
No AC outlet nearby, no problem. Use the Smart Extra Battery to power your BLADE Charging Station no matter where you are. Plug in your solar panels and run BLADE using clean, renewable energy.
EcoFlow BLADE
EcoFlow BLADE
Charging Station
Charging Station
Power Adapter (varies by region)
GNSS Antenna
GNSS Antenna
Quick Start Guide
Quick Start Guide
Other Accessories
Other Accessories
Product Type
Robotic Lawn Mower
16.2 kg / 36 lbs
<660*440*310 mm
IP Rating
IPX5
Sensor
IMU Sensor, Lift Sensor, Rain Sensor, Wheel Encoder, Lidar, Camera
Fully-Charged Working Time
240 min
Cutting Width
260 mm
Cutting Height
20-76 mm
Climbing Ability
27°
Vertical Obstacle Climbing
40 mm
Recharging Time
130 min
GNSS Working Mode
GPS, Beidou, Galileo, GLONASS
Bluetooth Channel
2400-2483.5MHz
Charging Station Input Voltage
36V
Charging Station Input Current
5A
Charging Station Output Voltage
25.2V DC Max
Charging Station Output Current
7A Max
Thanks for subscribing!
Explore More
