Top up 1kWh in only 1.3 hours
Charge while you drive with our EcoFlow 800W Alternator Charger and top up your power station in only 1.3 hours. The EcoFlow 800W Alternator Charger charges 8 times faster than traditional vehicle auxiliary power outlets simply by using the excess energy generated by your vehicle.
Triple the value with a 3-in-1 design
The 3-in-1 charger, maintainer, and jump starter saves time, money, and precious in-vehicle space. With its smart and efficient fast charging capabilities, you'll stay powered no matter how long you're on the road.
*The reverse charging and battery maintenance functions require the XT150 cable and must be used with EcoFlow DELTA Series products.
Charging Mode
Reverse Charging Mode
Battery Maintenance Mode
Extend your RV house battery runtime
Conveniently adapts to 12V/24V RV house batteries. Connects to EcoFlow portable power stations and protects RV house batteries while expanding energy storage capacity by up to 7.2kWh*.
*With EcoFlow DELTA Pro and DELTA Pro Extra Battery
Compatible with all EcoFlow and most third-party power stations
Compatible with an XT60 connection, designed to charge EcoFlow RIVER, DELTA Series, and most third-party power stations. The charger's 800W fast-charging is compatible with most SUV, Pickup, and RV alternators, meeting diverse short-trip car camping power needs.
*The 800W Alternator Charger comes with an XT150 cable to pair with EcoFlow DELTA Series products. An additional purchase of XT60 cable is required for wider compatibility.
With a high thermal resistance, Gallium Nitride (GaN) technology ensures safe charging every single time. The 800W Alternator Charger offers multiple safety features, including undervoltage protection that prevents excessive energy use and damage to the starting battery. A 2-year warranty ensures your experience and peace of mind.
Reverse polarity protection
Overcurrent protection
Short circuit protection
Overvoltage protection /Undervoltage protection
Connect the Fuse Cable
Connect the Input Cable
Start Charging
1. Connect the fuse cable to the input cable on one end. 2. Connect the fuse cable to the vehicle battery on the other end.
1. Connect the black cable to the chassis terminal. 2. Thread the other end of the input cable through the car body towards the charger. If the input cable is bulky or difficult to pull through, disconnect the cable ends before threading. 3. Plug the other side of the input cable into the EcoFlow 800W Alternator Charger.
Plug in the output cable from the EcoFlow 800W Alternator Charger to the portable power station.
EcoFlow Alternator Charger
Installation board
Cable puller
M6 nut
M5*40
M5*12
Input cable
XT150 output cable
M6*20
Fuse cable
ST5.5*25
Manual & warranty card
Specifications
Model
EF-FC-301-1
4.9 lb (2.2 kg)
Dimensions (W × D × H)
242×194×35 mm
Wi-Fi
Frequency: 2412MHz-2472MHz Maximum output power: <20dBm
Bluetooth
Frequency: 2402MHz-2480MHz Maximum output power: <10dBm
Great piece of kit has revolutionised our Motorhome.
G
Gordon F.
Ecoflow 800W Alternator Charger
This is a game changer. So easy to install into my motorhome and it performs faultlessly, just plug and forget. Ecoflow have built a top quality item that just opens a new world of ease regarding self reliant energy while travelling. I have used this for about a month now on the road to charge my Ecoflow Delta 2 Max and I have managed to top it up to 100% each time I have driven. Even on engine tickover I am able to get 800w out of the charger efficiently. I have much less power anxiety that I had before and now find that I hardly ever use my fold out solar panels and just don’t seem to use site power when stopping on a camp site. My roof solar and DC to DC charger maintains my habitation and cab batteries and my Ecoflow alternator charger maintains my Delta 2 Max.
By far, one of the most innovative hi impact devices on the market today and an absolute must have if you are travelling with a compatible Ecoflow power bank.
Choosing a selection results in a full page refresh.
Press the space key then arrow keys to make a selection.
Shopping Cart
My Shopping Cart
