2×130W RVMax Solar Panel Kit for Motorhomes - EcoFlow UK - EcoFlow 130W RVMax Rigid Solar Panel (2 pieces) - EcoFlow UK
EcoFlow UK
30 Days Price Guarantee
Regular price £39.99
Sale price £39.99 Regular price £339.00
Save £299.01
Days
Hours
Minutes
Seconds
1. Perfectly tailored for RV use, size suitable for various RVtypes
2. 12 mm ultra-thin panel effectively reduces 60% of driving wind resistance
3. Connect up to 10 panels in parallel (1300W)
4. NEW LFB-40 port with enhanced stability - stays firmly connected even during movement
5. Up to 25% conversion efficiency rate
6. TOPCon solar cells perform well in low light and high temperatures
7. Built to last with an IP68 waterproof rating
8. Up to 5-year warranty and 30-year lifespan
solar panel
£39 99 £339 00 -£299 01
Perfectly Tailored for RV Use
Aerodynamic Solar Solution That Fits Any RV Roof
With a 30-year lifespan, this durable, low-maintenance solar panel is ideal for RV use.
Size fits various RV types
The narrow, rectangular design fully utilizes the roof space of almost any van, from Class B to Class A, from trailers to fifth wheels.
Ultra-thin design for low wind resistance
At only 12 mm, this slimline panel significantly reduces wind resistance by more than 60% when you're on the road, effectively improving fuel efficiency and saving on fuel costs. Our RVMaX solar panel is almost 23 mm slimmer than traditional models.
Modular Design
Connect Multiple Panels with Plug-and-Play Simplicity
EcoFlow 130W RVMax Rigid Solar Panel features an innovative modular design, delivering up to 130W power, 50V, and 3A current output, and connects up to 10 panels within a safe range. Works seamlessly with various power stations.
50v High Voltage Design
Safe and Simplified LFB-40 Connection
State-of-the-Art N-Type TOPCon Solar Cells
Maximum Power, Extended Lifespan
With N-Type TOPCon technology, achieve up to 25% conversion efficiency.
Coated with Protective Lamination & Tempered Glass
Engineered to Withstand the Elements
Built for the road ahead, TOPCon solar cells with ultra-slim 2 mm tempered glass maximize light transmission while providing solid protection against debris, storms, or hail during your journey. RVMax's reinforced corners help prevent impact damage and hidden cracks common in standard panels. Complete with an IP268 rating and the waterproof LFB-40 connector, this panel delivers reliable power through rain, dust, and challenging weather conditions.
Universally Compatible Solar Cable
Plug and Play with Your Power System
Easily connect to third-party solar systems using the includedphotovoltaic connector (MC4 compatible)⁴. Safely charge yourpower systems and portable power stations with XT60 connectors, featuring waterproof, anti-leak technology that's touch-safe and reliable.
Adapts to various RV power systems
Power Kits
EcoFlow DELTA & RIVER Series
Third-party portable power stations
Adapt to RV power system
Rated Power
130W(+/-3w)
Dimension (mm)
1345x524mm(12mm)
Net Weight (kg)
5.82kg
Waterproof & Dustproof Rating
Cell Type & Efficiency
TopCon 25%
Open Circuit Voltage
50V
Optimal Operating Voltage
43V
Optimal Operating Current
3A
Short Circuit Current
3.2A
-0.3%/C
5 Years
