EcoFlow 175W Rigid Solar Panel - Default Title - EcoFlow UK
EcoFlow UK
£149.00
30 Days Price Guarantee
SKU: EFSOLAR175W-1-AKIT-1
🔥Black Friday Pre-Deals: subscribe & win from a £7,000 prize pool!
Regular price £149.00
Sale price £149.00 Regular price £149.00
- Cutting-edge solar conversion efficiency of up to 25%.
- TOPcon solar cells for high power in low-light and high-temperature environments.
- IP68 waterproof rating ensures durability.
- Suitable for Class B vans (camper vans) and home use.
- Easy and quick to install.
- Enjoy a 5-year warranty and a lifespan of up to 30 years.
También te puede interesar
£149
*The service life depends on the actual use.
Generate even more energy
Utilizing Revolutionary N-Type TOPCon Solar Cells
With N-Type TOPCon solar cell technology, we've raised the bar on conversion efficiency to 25%. This allows us to generate and store more sunshine than ever before.
*When the surface of the solar panel reaches 55℃, the TOPCon Solar Cell temperature coefficient is 23% less than that of the Monocrystalline Silicon Solar Cells.
Designed to weather any storm
Coated With Highly Protective Lamination and Tempered Glass
Built with a robust anti-corrosive aluminum frame, it's designed for years of solar-ray collection. Its TOPcon cells are coated with highly protective lamination and tempered glass and comes with an IP68 waterproof rating to enhance performance and offer long-lasting durability.
With just the right specs to maximize roof space
Industry-first design exclusively for Class B vans (camper vans)
With these specially designed Class B solar panels, you can quickly charge your RV house batteries and power your van for days.
With a shortened length of 46.3 in, it's just the right length to use every inch of your van's roof without affecting the awning.
It is perfectly sized for installation on a 59-63" × 39" SUV roof, optimizing solar energy collection.
Long-lasting solar solution for your home
Perfectly Tailored for Home Use
With a 30-year lifespan, it's a durable, low-maintenance solar solution ideal for home use.
Pair it with a 28" Tilt Mount Bracket to capture solar right from your garden.Fully charge EcoFlow DELTA 2 as fast as 3.7 hr using two solar panels. Even on cloudy days, it can fully charge in a single day.
Ready to install on any surface
Pre-Drilled Slots for Secure Mounting
With pre-cut holes along the panel's perimeter, the 175W rigid panel is ready to mount on your van or off-grid build. Pair with the Rigid Solar Panel Mounting Feet for a secure attachment to any surface.
Just plug and play with your power system
Universally Compatible Solar Cable
Using an all-inclusive solar connector, connect with any existing third-party solar system. Charge 48V power systems and portable power stations with single or multiple panels.
EcoFlow 175W Rigid TOPCon Solar Panel Charging Times
*Calculated at 80% of solar panel power, the time interval takes into account various weather conditions
**The data includes weather factors, such as rain, throughout the year
How to choose your solar panel
The solar to XT60i charging cable is not included. Click here to get a solar to XT60i charging cable.
Rated Power
175W (+/-3W)
Cell Type
N Type TOPCon Monocrystalline Silicon
Efficiency Rating
Up to 25%
Weight (Solar Panel)
9.3 kg (20.5 lb)
46.3×30×1.2 in (117.6×76.2×3 cm)
Connector Type
Photovoltaic Connectors (Adaptable to MC4 Connectors)
5 Years
Open Circuit Voltage
25.5V
Short Circuit Current
8.3A
Maximum Operating Voltage
22.3V
Maximum Operating Current
7.85A
Waterproof & Dustproof Rating
Can I use solar panels of different specifications for mixed-use?
Yes, but it is not recommended. Different energy storage controllers have requirements and restrictions on the output of solar panels. When solar panels with different current values are used in series, they will be limited, resulting in the inability to release the output power and even the short-board effect of 1+1<2
What features and advantages does the EcoFlow TOPcon solar panel have compared to other solar panels?
EcoFlow TOPcon solar panel has a next-level solar conversion efficiency rate of 25%, significantly higher than the 18%-20% conversion efficiency of many traditional solar panels. It maintains high power output even in low-light and high-temperature environments, making it perform better in various weather conditions. It has an IP68 waterproof rating, ensuring greater durability and reliability, and it has a lifespan of up to 30 years.
What is the power range that a 175W solar panel can typically achieve?
On a sunny day without clouds and direct sunlight, the power range of a 175W solar panel is between 130–145W (this data is obtained under the conditions of irradiance of 800–900W/m2 and the panel surface at 60°C). The nominal data of the solar panel is obtained by testing under the conditions of AM1.5, meteorological conditions of 1000W/m2, and panel surface temperature of 25°C. A power close to the nominal value can usually be reached at midday on a sunny day in winter.
Do I need to clean the 175W Solar Panel regularly?
Yes. There can be a lot of dust and foreign objects on the surface of the solar panel after the panel has been used outdoors for a long time, which blocks the light to a certain extent, reducing the power output. Regular cleaning can help keep the surface of the solar panel clean and free from obstructions and generate a higher power output. However, when cleaning, carefully wipe the surface with soft materials to prevent hard materials from scratching the panel's surface and affecting the production.
