Buy EcoFlow 110W Solar Panel — EcoFlow UK - 110W Solar Panel - EcoFlow UK
EcoFlow UK
£119.00
30 Days Price Guarantee
🎄 Xmas EcoCredits: Up to 60% Off | EcoFlow Power Trio
Regular price £119.00
Sale price £119.00 Regular price £149.00
Save £30.00
Foldable Power: Command Home & Wild:
With up to 23% conversion rate, keep the lights on during your outdoor adventrue or sudden outage
Extremely compact: With its folding four-panel structure, the portable solar panel significantly reduces to 16.5*18.9*1.0 in in size when folded. approximately the size of two A4 sheets, fits in any compact space.
Adventure-Proof, Rain or Shine : With an IP68 rating, our panels can withstand water spray and dust during your getaway trip.
Flexible Setup: Panels can be split or combined to suit your needs.
Versatile Power Anywhere: Ideal for home backup, off-grid cabins, and outdoor adventures.
Perfect for Camping: Lightweight, space-saving, and easy to pack and store.
También te puede interesar
£119 £149 -£30
Get off the grid with EcoFlow’s 110W Solar Panel for renewable energy wherever you end up.
Powerfully portable
With an industry-leading 23% conversion rate, it’s far lighter and approx. 10% smaller than similar portable solar panels on the market. That means a faster, easier charge wherever you are.
Self-supportable
Take it camping, on a road trip or in your backyard with a case that doubles as a stand. Unzip and prop up your panel at just the right angle to ensure maximum solar coverage.
Waterproof & Durable
Designed to withstand your adventurous lifestyle, this panel is IP68 certified. That means we dunked it underwater for 72hrs in lab conditions. Just to make sure*. Built with a high-strength composite, it can take a beating too. That’s an all-weather ready panel designed to stand the test of time.
* Water and dust resistance were tested under controlled laboratory conditions with a rating of IP68 under IEC standard 60529 (maximum water depth of 1 meter for up to 72 hours.)
It comes with a carry case too.
On the go? Keep your panel folded up and protected while you hit the road. Save valuable trunk space and go easy knowing your panel is safe. Once you arrive, simply unfold, prop up and start generating clean, green electricity.
110W Portable Solar Panel
Solar to XT60i Charging Cable
110W Portable Solar Panel Bag
Snap hook*4
Snap hook*4
User Manual & Warranty Card
Unfolded Dimensions
178.5 × 42.0 × 2.5 cm
Folded Dimensions
42.0 × 48.0 × 2.5 cm
Weight
4 kg
24 months
Rated Power
110W (±5W)
Efficiency
22% – 23%
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
6.5A (Imp 6.0A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−20°C to 85°C
