Buy EcoFlow 110W Solar Panel — EcoFlow UK - EcoFlow UK
EcoFlow UK
🔥Black Friday Sale
Regular price £19.99
Sale price £19.99 Regular price £19.99
• Portable and lightweight
• Up to 23% conversion rate
• Self-supporting
• One-piece folding design
También te puede interesar
Get off the grid with EcoFlow’s 110W Solar Panel for renewable energy wherever you end up.
Powerfully portable
With an industry-leading 23% conversion rate, it’s far lighter and approx. 10% smaller than similar portable solar panels on the market. That means a faster, easier charge wherever you are.
Self-supportable
Take it camping, on a road trip or in your backyard with a case that doubles as a stand. Unzip and prop up your panel at just the right angle to ensure maximum solar coverage.
Waterproof & Durable
Designed to withstand your adventurous lifestyle, this panel is IP68 certified. That means we dunked it underwater for 72hrs in lab conditions. Just to make sure*. Built with a high-strength composite, it can take a beating too. That’s an all-weather ready panel designed to stand the test of time.
* Water and dust resistance were tested under controlled laboratory conditions with a rating of IP68 under IEC standard 60529 (maximum water depth of 1 meter for up to 72 hours.)
It comes with a carry case too.
On the go? Keep your panel folded up and protected while you hit the road. Save valuable trunk space and go easy knowing your panel is safe. Once you arrive, simply unfold, prop up and start generating clean, green electricity.
110W Portable Solar Panel
Solar to XT60i Charging Cable
110W Portable Solar Panel Bag
Snap hook*4
Snap hook*4
User Manual & Warranty Card
Unfolded Dimensions
178.5 × 42.0 × 2.5 cm
Folded Dimensions
42.0 × 48.0 × 2.5 cm
Weight
4 kg
24 months
Rated Power
110W (±5W)
Efficiency
22% – 23%
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
6.5A (Imp 6.0A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−20°C to 85°C
Customer Reviews
Based on 63 reviews
87%
(55)
13%
(8)
0%
(0)
0%
(0)
0%
(0)
A
Anonymous
It does the job nicely, very helpful!
A
Andrew W.
10 outta 10 from me arrived well packaged I have used it a couple of times and charges my river mini fine took between 4 -5 hours for full charge
On a cloudy sunny day in Scotland so it's got my approval
That impressed I wanna upgrade
A
Angela A.
Seems well made and have got it up to around 110w on occasions. However not sure about the stand design as it leaves the end pannels quite floppy and can be difficult to keep it all aligned with the sun. Just some lightweight support struts on each end pannel would do, with a hole in the end so you can peg down in windy weather would be great.
M
MTN4RNR
Customer support is always great. This solar panel is compact and extremely well built with high quality material. IP67 waterproof is an asset. Way better charging wattage than Jackery. Can't wait to take an detail video soon. Thank you ecoflow.
g
gwen b.
Doesn't charge as stated, charged mine and after 6 hours full sun it didn't fully charge my eco flow
T
Tyrus W.
The portability of this solar panel is awesome! Comes with a totabal bag that can be used as a stand for the panels. Awesome product.
