EcoFlow STREAM AC Pro | EcoFlow UK - STREAM AC Pro / 2 × 450W Rigid Solar Panel + STREAM Microinverter - EcoFlow UK
EcoFlow UK
12 payments of £116 50 at 0% interest with Splitit. Learn more
30 Days Price Guarantee
EcoFlow STREAM AC Pro/AC
Regular price £1,398.00
Sale price £1,398.00 Regular price £1,798.00
Save up to £599.00
Days
Hours
Minutes
Seconds
Up to 47% off · Vote to unlock exclusive perks Learn More
  • Save up to £358 on your electricity bills
  • Compatible with EcoFlow STREAM Ultra/Pro
  • AI‑driven experience via the EcoFlow app for intelligent monitoring and control
  • Operate seamlessly with 99% of solar panels on the market
Please Note: EcoFlow STREAM is supplied with a power cable with stripped ends (no plug) and requires hardwiring. In accordance with UK safety regulations, it must be installed by a certified, registered electrician.
Auto-Applied Final Price £659
CODE: ACPROOFF
Stay Tuned!
Plug-in solar regulation is expected to be introduced in the UK in the coming months. EcoFlow STREAM Series are equipped with open-end cables and fully comply with existing regulations. Once the new regulation comes into effect, plug-in cables will be available for purchase to enable easier installation.
£1,398.00 £1,798.00 -£400.00
Perfect Solution For Extended Storage, Drive Bills To 0
Powered by AC-coupling technology, EcoFlow STREAM AC Pro integrates with any microinverter or connects directly to wall sockets, efficiently storing solar power and delivering uninterrupted energy throughout your home¹.
Works With All Microinverters
If you have installed a microinverter in your home and need more storage, there is no need to worry about compatibility with EcoFlow STREAM AC Pro. It connects to all microinverters via wall sockets with an AC-coupled solution. Just plug into your existing system for maximum power generation and lower power bills.
2300W AC Output
Run two appliances independently via dual AC outlets, with 1,200W output per battery and auto-boost up to 2,300W (on-grid). Pair with another STREAM AC Pro or STREAM Ultra for full 2300W (on-grid) AC output, while the built-in battery ensures off-grid use and backup during outages.
One Step Closer To 0 Bills
Build Your Home Solar Plant With EcoFlow STREAM AC Pro
Big or Small, Power It All
Go “Bills to 0” with 3 smart setups. From lights and routers to fridges and kettles, the EcoFlow STREAM Series powers appliance up to 2,300W (on-grid) — all powered by the sun.
2300W
2000W
1200W
Parallel Mode Up to 2,300W Solar Coverage
  • Device Setup: 1 × STREAM Ultra + 1 × STREAM Ultra or STREAM AC Pro
  • Connect two units with a parallel cable to power high-wattage appliances like ovens and dishwashers — all powered by solar.
  • Output:1,200W (main) + 1,100W (secondary) = 2,300W total output
Distributed Mode Up to 2,000W Solar Coverage
  • Solar powers up to 2,000W, with support for up to 2,300W total output when needed.
  • Output: 1,200W (main) + 800W (secondary) + 300W (grid) = 2,300W total output
Single Unit Mode Up to 1,200W Solar Coverage
  • Device Setup:1 × STREAM Ultra
  • One unit powers your everyday essentials — ideal for running TVs, cookers, fans, and more with ease.
  • Output:1,200W from a single battery
Longer Runtime with Scalable Capacity and Solar Input
EcoFlow STREAM AC Pro supports flexible DIY solar storage expansion from 1.92kWh to 11.52kWh³ with up to 6 connected units. Easily pair two units to double your capacity or integrate with EcoFlow DELTA Series batteries for even greater storage.
Power That Flows Where It’s Needed
The AI-powered system monitors all connected devices in real time, ensuring each unit receives enough solar energy to run your appliances. If the EcoFlow STREAM AC Pro in your kitchen runs low, AI-driven load balancing automatically redirects energy from nearby units—keeping your fridge running on solar without interruption.
More Savings, Fewer Calculations—Through Software⁴
Boost Your Savings with the TOU Model and Solar Forecasting⁵
Time‑of‑Use (TOU)  Dynamic Electricity Pricing
Charge when prices are low, supply when prices are high.
AI-TOU model offers you the optimal bill-saving strategy every 60 minutes, based on the analysis of tariff data from Nord Pool, Epex Spot, Rabot Energy, Octopus, and more.
High Accuracy Solar Forecasts, Maximize Your Savings All Year Round⁶
Powered by Solcast's world-leading solar and weather forecasting, processing over 100 million forecasts per hour—including geolocation, satellite imagery, historical data, and TMYs (Typical Meteorological Years) —to deliver real-time insights and savings.
Smart Meter × Smart Plug: Zero Feed-in. All Solar, All Yours⁷
EcoFlow works with leading smart energy brands like Shelly, Tibber, and more, managing your home's power with the Smart Meter, Smart Plugs, and the EcoFlow app. Automatically run appliances like your sprinkler, e-bike, or ventilation using surplus solar. Let every ray of sunshine stay yours.
EcoFlow AI Assistant: No Math. Just Savings.⁸
Your AI Assistant simplifies energy management by doing the hard work for you—analyzing data, spotting inefficiencies, and giving clear, actionable recommendations. No calculations, no guesswork—just smart, easy decisions.
Protecting Your Privacy, Always.
EcoFlow protects your data using top-level security measures certified by global standards including TRUSTe, NIST, ISO, and more.
Safety You Can Trust
Long-Lasting Power with LFP Technology
Equipped with advanced LFP battery cells, STREAM delivers up to 6,000 deep cycles with 70% capacity retention — lasting up to 3× longer than traditional batteries. That means up to 15 years of reliable use, backed by a 10-year warranty.
Silent Operation — as Low as 30 dB
Experience whisper-quiet performance with noise levels as low as 30 dB.The advanced self-cooling design dissipates heat efficiently — no disruptive fan noise, just silent, reliable power.
Ready For Any Weather
EcoFlow STREAM AC
1.92kWh
1.92kWh
1.92kWh
1.92kWh
1050W
800W
1050W
800W
1200W
800W
1200W
800W
Yes
No
Yes
No
2300W (10A)
2300W (10A)
21.5kg
21.2kg
21.5kg
21.2kg
255mm × 254mm × 458mm
What's in the box - STREAM AC Pro
STREAM AC Pro
STREAM AC Pro
STREAM DIY Cable (1.5m)
Mounting Bracket
Mounting Bracket
Locking Bracket
Locking Bracket
Safety Instructions
Safety Instructions
Installation Guide
Installation Guide
Warranty Card
Warranty Card
STREAM AC
STREAM AC
STREAM AC Cable (1.5m) × 1
Mounting Bracket
Mounting Bracket
Locking Bracket
Locking Bracket
Safety Instructions
Safety Instructions
Installation Guide
Installation Guide
Warranty Card
Warranty Card
Specs - STREAM AC Pro
1.92kWh
6000 cycles
AC Charging Input
1050W
1200W
AC Output-Grid Tied
800W
AC Charging Input
10A
Max Device Power Supported
2300W (10A)
Operating Temperature
-20~55°C
Battery Self-Heating
Connection
Wi-Fi/Bluetooth
Ingress Protection Rating
IP65
21.5kg
Acoustic Noise
<30 dB
10-Year
Specs - STREAM AC
1.92kWh
6000 cycles
AC Charging Input
800W
800W
AC Output-Grid Tied
800W
-20~55°C
Connection
Wi-Fi/Bluetooth
IP65
21.2kg
Acoustic Noise
<30 dB
10-Year
In the UK, local regulations require the EcoFlow STREAM DIY Cable to be wired into the distribution board, which must be done by a certified installer or electrician.
Each MPPT of the STREAM Ultra/Pro has a maximum power of 500W. Can I connect solar panels with more than 500W to each port?
Yes, as long as the solar panel meets the conditions of operating voltage (15-60V) and operating current (≤14A). This can optimize solar utilization during low sunlight conditions.
1. EcoFlow STREAM AC Pro collects 1,041kWh of solar energy annually. With Germany's average household consumption of 3,113kWh/year, this system covers 33.4% of total energy needs through continuous day-night solar supply. The electricity rate of £0.33/kWh translates to an annual savings of £351. Savings may vary based on consumption patterns and energy price fluctuations.
source:https://pvwatts.nrel.gov/pvwatts.php
2. EcoFlow STREAM Ultra delivers 2,218kWh of solar energy annually, achieving 71.3% coverage of Germany's average household consumption (3,113kWh/year) through 24/7 solar power supply. Based on the electricity rate of £0.33/kWh, this system provides annual savings of £953 . Actual savings may vary depending on usage behaviour and regional energy pricing.
3. With 100% solar capture and utilization, the EcoFlow STREAM Series System generates around 5,542kWh annually - covering Germany's average household consumption (3,113kWh/year). The electricity rate of £0.33/kWh results in an annual savings of £4,049. Actual savings may vary depending on usage behaviour, regional energy pricing and different bundles.
4. Certain AI features in the EcoFlow app require a premium subscription. Please refer to the EcoFlow app for details on subscription plans and feature availability.
5. The calculation is an estimate based on 10 kWh/day electricity consumption in Munich, Germany (representing Central Europe), using STREAM series products (6kWh batteries and 2800W PV). It is simulated by AI, factoring in fluctuations in electricity prices and usage for a closer reflection of real-world conditions. Actual results may vary depending on local conditions.
6. The EcoFlow app integrates weather data from Solcast, running over 100 million data operations per hour to deliver forecasts with up to 94% accuracy and horizons of up to three days. (https://solcast.com/)
7. After installing STREAM Series battery and compatible Smart Meter, users can connect appliances to wall outlets via compatible Smart Plugs, enabling remote on/off control and operation scheduling through the EcoFlow app—thereby minimizing solar energy waste.
8. Actual EcoFlow app functionality may vary; the screens shown are for illustrative purposes only.
