RAPID Wireless Qi2 MagSafe Charger | EcoFlow UK - RAPID 10000mAh / Black - EcoFlow UK
EcoFlow UK
Pice Guarantee
EcoFlow RAPID Magnetic Power Bank
Regular price £89.99
Sale price £89.99 Regular price £89.99
Save up to £54.99
Days
Hours
Minutes
Seconds
  • Qi2 15W Wireless Charging: Enjoy the convenience of 15W wireless charging, which is twice as fast as Qi1 7.5W charging, and backed by Qi2 certification, ensuring quick, safe, and efficient energy top-ups.
  • Ultra-Fast Charging with 30W/65W Built-in Cable: With the built-in 30W/65W cable, there's no need to carry an extra cable for ultra-fast charging. Experience the magnetic ease of maximum charging speed wherever you go.
  • Flash Recharging: With a 30W/65W input, charge from 0% to 70% in under 33 minutes, perfect for when you're getting ready to head out.
  • Built-in Stand for Versatile Use: The kickstand offers both upright and side-view modes, providing hands-free use and doubling as a desktop stand.
  • (Only 10,000mAh) Smart Digital Display: Experience complete control with the dynamic screen on our power bank. Using smart app control, you can view charging speed, power output, and even personalise your screen.
  • (Only 10,000mAh) Intelligent App Control: Along with more detailed charging insights, you can activate the "Healthy Charging Mode" to extend your battery's lifespan. You can also locate your power bank via the embedded buzzer in case it’s misplaced.
Colour
Silver
Light Blue
Black
Stay Tuned!
Be the first to know when RAPID (10000mAh) is available.
£31.99 £59.99
65W | 3 Ports | GaN Powered Technology | Universal Compatibility
£31.99 £59.99
£31.99 £59.99
£31.99 £59.99
£31.99 £59.99
£89 99
EcoFlow integrates cutting-edge battery and software technology into everyday portable use with RAPID, the new magnetic charging experience.
X-Stream
Flash charge and recharge with RAPID power
RAPID uses patented X-Stream technology for flagship smartphone-level energy density and fast charging capability. Plus, it works with the PD3.0 protocol for flash charging and recharging. Paired with Qi2-certified wireless charging and a built-in cable design, RAPID ensures snap-on charging convenience with maximum charging speeds.
Versatile and universally compatible
Rely on RAPID for power on the go.
With a high output power and multiple charging protocol compatibility, RAPID charges most portable devices, including MacBooks, iPads, Kindles, fitness bands, and earbuds.
Remote Work
On-the-go
Socializing
Give your 14-inch MacBook Air a boost with RAPID 10000mAh for an extra 8 hours of power.
Perfect as a travel charging hub for your iPhone, AirPods, and other essentials, as well as recharging itself at the same time.
Share power with your friends and charge two phones simultaneously.
Intelligent app and display
Charge and showcase your style
Experience ultimate control with our power bank's dynamic screen. View battery status, charging speed, and power output, plus, add a personal touch by customizing your screen via the EcoFlow app.
Stay informed with a smart digital display
The TFT display lets you view battery capacity, output and time to recharge, so you're always informed and in control of your power.
Charge
Recharge
Customize your display
Personalize your RAPID power bank boot screen display with your name or favorite DIY pattern using the EcoFlow app.
Intelligent control using the EcoFlow app
RAPID includes an Energy Management System that helps the battery health. Turn on 'Healthy Charging Mode' in the app for longer battery lifetime of the power bank
View Status
Gain comprehensive insights into your power bank's performance, including port voltage, current, power, and even temperature.
Find My Device
You'll never have to worry about misplacing your power bank. With 'Find My Power Bank', you can easily locate your device.
Built-in stand and strong magnetic connection
Hold or go hands-free
The EcoFlow RAPID combines a sleek design with practicality. Highly magnetic and anti-slip, ensuring a strong grip when in use, reducing movement. The built-in stand offers hands-free use, doubling as a desktop stand.
Anti-slip magnetism
Kickstand for upright/side view
With N52 magnets for a powerful bond and anti-slip components, the power bank and the phone connect smoothly. The power bank holds firmly in place without sliding when the phone is in use.
1. Place it vertically on a desk, to use your phone as a digital clock or make video calls.
2. Lay it horizontally to comfortably watch movies.
An intelligent power health guardian delays degradation
Double protection for healthy, long-lasting charging
EcoFlow's double cooling protection uses a heat dissipation structure, and 500-times-per-second temperature monitoring, to reduce heat and slow battery aging.
Exclusive structure maintains a low temp
Advanced vehicle-quality tech minimizes electrical resistance with a unique internal cooling system to reduce heat from magnetic charging.
Always ready
The battery maintains more than 95% of energy for a month. Even if it isn't used for a while, you won't need to recharge it.
EcoFlow RAPID Magnetic Power Bank (5000/10000mAh)
Instruction Manual
Instruction Manual
Warranty Card
Warranty Card
Color
Silver/Light Blue/Black
5000mAh
Ports
C1: USB-C built in cable (input/output)
C2: USB-C port (input/output)
Wired Charging Input
30W
Wired Charging Output
30W
Wireless Charging Output
Qi2.0 15W
Bluetooth
No
Digital Display
No
App
No
108mm×70mm×14.4mm/4.25×2.76×0.57 inch
Weight
180g/6.35oz/0.4 lb
EcoFlow RAPID Magnetic Power Bank (10000mAh)
Color
10000mAh
Ports
65W
65W
Qi2.0 15W
Bluetooth
Yes
Digital Display
Yes
App
Yes
108mm×70mm×22.9mm/4.25×2.76×0.9 inch
Weight
258g/9.1oz
Please Note:
1. All the test results displayed on the page are based on our internal testing, subject to different conditions, including temperature variations, humidity levels, and equipment calibration standards. Please note that these results are provided for informational purposes only and should not be considered as conclusive evidence for all scenarios.
2. This power bank is compatible with iPhone 12 Series and later, iPad Series, MacBook Series and AirPods Series. While it can charge Android devices such as Samsung and Google phones, they cannot utilse the magnetic feature or achieve the 15W wireless charging speed, and have a lower charging efficiency.The EcoFlow RAPID Power Bank Gift Campaign runs from 12 August 2024, 9 AM (CET) to 31 December 2024, 9AM (CET). EcoFlow reserves the right to shorten or extend the campaign period at its sole discretion without prior notice.
EcoFlow RAPID Power Bank Gift Campaign Terms & Conditions
The EcoFlow RAPID Power Bank Gift Campaign runs from 12 August 2024, 9 AM (BST) to 31 December 2024, 9 AM (BST). EcoFlow reserves the right to shorten or extend the campaign period at its sole discretion without prior notice.
Eligibility
The campaign is open to all UK citizens aged 18 years old and above as of 9 AM on 12 August 2024, 9 AM (BST).
Campaign Details
By entering your email address and subscribing, you agree to email marketing Terms & Conditions, subscribe to EcoFlow marketing emails, and receive updates from EcoFlow.
Rapid Power Bank Gift CampaignProducts eligible include:
EcoFlow RAPID Magnetic Power Bank (5000/10000mAh) and its bundles
Dedicated Gift: 1 × EcoFlow Shoulder Bag
Available Quantities of Gift: 50
Note
1. The start time of the campaign is when the product is available for sale, subject to the sale information on the official website.
2. The above-mentioned first 50 orders are counted within the official EcoFlow website: uk.ecoflow.com. A total of 50 gifts will be given away. The start of the count is based on the website's announcement. The eligible orders are sorted in the chronological order of payment. If the gifts run out, the offer will be discontinued without further notification from the website. The gift will be automatically added to the order within 24 hours of payment. The customer will be able to view the gift in the order by logging into the account (https://account.ecoflow.com/login?return_to=uk.ecoflow.com/) through the official website where the purchase was made.
3. If a refund is issued on the original order, the gift must be returned upon refund.
General
1. If you encounter any problems during the promotion, please contact support.eu@ecoflow.com for assistance
2. To the extent permitted by applicable law, we may decide to modify these rules or cancel the promotion at any time. If there is any fraud or abuse related to the promotion, we reserve the right to exclude any customer from the promotion.
3. Participants in the Sale agree to be bound by the terms and conditions set forth herein and understand that EcoFlow's decisions are final and binding. No correspondence or appeals will be entertained. EcoFlow reserves the right to make the final and ultimate interpretation of this campaign.
4. All orders must comply with EcoFlow's purchase agreement and return policy during the sale promotion.
5. The sale promotion does not apply to wholesale on distributor orders.
6. Any unauthorized or fraudulent behaviour will result in the disqualification of participants.
7. Participants must comply with all applicable laws and regulations.
8. EcoFlow reserves the right to stop, cancel, or change the promotion at any time during the promotion. Any changes will be announced on the EcoFlow official website.
9. All prizes in this promotion are limited in quantity and are available on a first-come, first-served basis. Any matters not covered herein will be handled according to EcoFlow's final interpretation.
10. EcoFlow will assume no responsibility for late entries, which may occur for any reason, including but not limited to network transmission failure.
11. EcoFlow will not be responsible for any direct or indirect losses or damages incurred by any party, including the participants, in connection with or arising from acts or omissions or any way related to this campaign.
12. Participants agree to release and discharge EcoFlow from any liabilities and claims, including breach of contract, tort, negligence, or any other cause of action at law or equity, arising out of or in any way connected to this campaign or the participant's entry into the campaign.
