EcoFlow PowerInsight Home Energy Monitor - Default Title - EcoFlow UK
EcoFlow UK
12 payments of £25 75 at 0% interest with Splitit. Learn more
30 Days Price Guarantee
Regular price £309.00
Sale price £309.00 Regular price
Days
Hours
Minutes
Seconds
Up to 47% Off — The Biggest Sale of the Year! Buy Now
- 10-inch Touchscreen: clear visuals and intuitive control.
- Energy Data Tracking: an energy dashboard to view your home energy data in real-time, by day, month, and year.
- Home Device Control: control your home appliances with Smart Plug & Matter.
- Temperature Auto-adjustment: auto-adjust the temperature to a more appropriate level with a built-in sensor.
£309.00
The all-in-one home energy monitor
Discover your home's eco-friendly potential
Data monitoring
Curious about your home's eco-friendliness? You'll find all the answers here!
Solar power generation
Home energy consumption and sources
Remaining battery
PowerInsight is a comprehensive energy dashboard that lets you easily view your home energy data in real-time, by day, month, or even year.
Always find a better way to save energy and money
Energy optimization
Meet your smart energy optimizer and money saver!
EcoFlow Powerlnsight optimizes energy use and saves costs by smartly leveraging battery/solar power, grid feeding, battery timing, and device usage alerts.
Control your devices and run a smart, connected home
Smart device control
Whether you want to turn off all your lights when you leave or crank up the heating before you get home, do it all at the touch of a button.
Using Matter support and smart plugs, control all the connected appliances around your home.
See what works with EcoFlow PowerInsight
Wi-Fi | Matter
Smart Plugs & Meters
- Smart Plugs: Shelly, Tapo,Kasa EP10
- Smart Meters: Shelly 3EM,Shelly pro 3em//Powerfox/ Tibber Pulse IR
- Thermostats: Google Nest,Ecobee,Tado
*Supported appliances will be added in the future.
Matter
- Smart Lights
- Smart Plugs and Outlets
- Thermostats and Other Temperature Controllers
- More to come: Smart Locks, Contact Sensors
*Supported devices are determined by their compatibility with the Matter protocol.
Stay comfortable while saving energy
Temperature auto-adjustment
With a built-in indoor temperature sensor, PowerInsight adjusts your home's climate so it's always just right. By constantly monitoring the air temp, you're lowering energy use and your bills.
Why choose EcoFlow PowerInsight?
Wall bracket
Wall bracket
Power Cable (USB-C to USB-C)
Screw (4×30mm) & Anchor (Ø6×27mm)
Quick Start Guide & Warranty Card
Specifications
244.4mm*158.6mm*12.4mm (H*W*D)
Weight
Approx. 600g
Color
Black
Button
Power on/ off
Size
10.1 inch
Type
IPS
Resolution
1280 x 800 pixels
Screen
10-point multi touch
CPU
MT8168
ROM
16GB
RAM
2GB
Battery
3000mAh
Charging
5V/2A charging, Pogo Pin charger
WLAN
802.11 a/b/g/n/ac 2.4GHz, 5GHz
Bluetooth
Bluetooth 5.0
Sensor
Temperature and Humidity SensorsAmbient Light SensorProximity Sensor
