12 payments of £93 58 at 0% interest with Splitit. Learn more
1500W AC Input, Full Charge in 56 Minutes[1]
Solar Input with 1000 MPPT, Full Charge in 70 Minutes[2]
EcoFlow DELTA 3 Plus with 500W MPPT × 2 charges fully in 70 minutes, even with limited sunlight. Outdoors, it recharges during lunchtime. DELTA 3 with a 500W MPPT recharges in 2 hours.
On-the-Go with 800W Car Charge, Full Charge in 1.3 Hours[3]
Multi-Charging (AC + Solar), Full Charge in 56 Minutes with 1500W Input[4]
With 1500W max input, it takes 56 minutes to fully charge. During daily use, plug in both AC and solar to charge DELTA 3 Plus, prioritising solar to save money.
Hybrid Power with Generator, Full Charge in 56 Minutes with 1500W AC Input[5]
With 1500W input, it takes 56 minutes to fully charge. The EcoFlow Smart Generator 3000 (Dual Fuel) automatically replenishes power at night, ensuring constant backup without manual intervention (coming soon).
EcoFlow DELTA 3 Series supports 99% of household devices, including refrigerators, TVs, and computers. Plus, with X-Boost, continuously power appliances over 2400W, such as ovens (2150W), hair dryers (1800-2500W), and kettles (1200-3000W). Perfect for home usage, RV, and outdoor usage, this solar battery ensures you're never left in the dark.
30 dB ultra-quiet operation
Completely imperceptible under 600W, blending with natural ambient noise (30 dB).
Whether you're in a tent or at home, it won't disrupt sleep.
Peace of mind for backup power, convenient for daily use
Ensure reliable backup for specialized equipment with a 10 ms UPS.[6]
Third-gen LiFePO4 (LFP) cells offer fast charging without sacrificing longevity. With 4000 cycles to 80% capacity[7], enjoy up to 10 years of reliable use, 25% above the industry standard.
*EcoFlow DELTA 3 Series are compatible with Extra Battery of DELTA 3, DELTA Pro 3, DELTA 2 Max, DELTA 2.
Same power, more compact. Achieve 2kWh capacity with EcoFlow DELTA 3 Extra Battery (1kWh), making it 1/3 smaller and lighter than the DELTA 2 power pack.
When combined with the EcoFlow Ecosystem, it can be equipped with DELTA Pro 3 Extra Battery, allowing for a maximum expansion to 5kWh, which extends the backup power duration by 5 times.
Comparison of DELTA 3 Series and DELTA 2
Specs - DELTA 3 & DELTA 3 Plus
Colour/ID
DELTA 3 - Silver & Grey
DELTA 3 Plus - Silver
1024Wh
≤12.5 kg
398×200×284 mm
D3 EB Dimensions
398×200×198 mm
App
Supported (TOU/Storm warning)
Extra Battery
Expandable capacity to 5kWh)
DELTA 2 Max/DELTA 2/DELTA Pro 3/DELTA 3 Extra Battery Supported
Total Output Ports
11
AC × 4
4 × 1800W (Surge 3600W)
2400W
USB-A × 2 (Fast charging)
DELTA 3 - 2 × 18W Max
DELTA 3 Plus - 2 × 36W Max
USB-A × 2
USB-C × 2
DELTA 3 - 2 × 100W Max
DELTA 3 Plus - 2 × 140W Max
Car Power × 1
12.6V, 10A, 126W Max
DC5521 × 2
2 × 12.6V, 3A Max
AC
1500W (56 Min)
Solar
DELTA 3 - DC input 11V-60V1 × 500W Max (130 Min)
DELTA 3 Plus - DC input 11V-60V2 × 500W Max (70 Min)
Smart Generator
1500W (56 Min)
Car
800W (1.3 Hr)
AC+PV
1500W (56 Min)
Chemistry
DELTA 3 - 4000 Cycles to 80% Capacity
DELTA 3 Plus - 4000 Cycles to 80%
Waterproof level of battery pack
IP65
UPS
DELTA 3 - <10 ms
DELTA 3 Plus - <10 ms HID
Volume
600W <30 dB
1200W <40 dB
5 Years
Footnote:
[1-8] All the test results displayed on the page are based on our internal testing, subject to different conditions, including temperature variations, humidity levels, and equipment calibration standards. Please note that these results are provided for informational purposes only and should not be considered as conclusive evidence for all scenarios
I purchased a Delta 3 from Argos as backup power in case of a power outage. I did my research before purchase so I knew what to expect of it's capabilities. It surpassed my expectations by a big margin. I was so impressed, that 10 weeks later I purchased a Delta 3 1500 to add to my backup power.
Great bit of kit used it to run my conservatory and 1 fridge and on a good day a freezer as well on all the time saving me money
I bought the EcoFlow delta 3 for our motorhome ,it’s been amazing enabling us to go off grid , we have used this for two small breaks keeping it topped up with EcoFlow 100w solar panel .
Ideal for the Motorhome and works great with the 800 watt alternator charging effortlessly managing all that I could throw at it during out previous vacation
Great portable unit swaps easily between home and motorhome
