EcoFlow DELTA 2 Max + Smart Extra Battery - 2 - EcoFlow UK
EcoFlow UK
Pice Guarantee
Expandable capacity: 2-6kWh expandable capacity to fit your energy
storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit 6144Wh. Ideal for home backup, caravanning, outdoors or even everyday use.
Built to last 6× longer: Get 10 years of daily use until hitting 80% of its
original capacity. That's down to its LFP battery chemistry giving you
3000 cycles.
Huge AC output: With X-Boost mode, get up to 3100W output power to
run 99% of home appliances. Power 13 devices at once, including 4 AC
outlets.
Fastest recharging: World's fastest AC recharging and X-Stream dual
AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours
Capture more energy: 99% MPPT efficiency maximises solar generation
during the daytime.
Customised in-app energy management: Prioritise solar or AC charging, view input and output power, battery levels and more.
5-year warranty
Number of battery
£2,597.00 £3,197.00 -£600.00
PayPal
Expandable up to 6kWh
Triple the power.
10-Year LFP Battery,
Built To Last 6× Longer.
Durable, Safe, Lightweight
With its upgraded LFP battery chemistry, DELTA 2 Max has a lifespan of 3000 complete cycles until it reduces to 80% capacity. You'll get pretty much 10 years of power, even if you use it every day.
LFP Battery Chemistry
That's 6x Longer Than Other Power Stations With A Similar Capacity And Output.
Advanced BMS Protection
Protective Layers Inside And Out
Robust Design
Upgraded Tech, Lighter
Weight
Even with its upgraded LFP battery, DELTA 2 Max is still 30% lighter than similar 2kWh LFP power stations on the market.
DELTA 2 Max powers almost all the devices you need with a large 2400W AC output. Plus, with X-Boost proprietary technology, run appliances with an output of up to 3100W. Compared with other power stations, DELTA 2 Max can power more devices, while still preventing overloading and overheating.
Fuel Up 80% In Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 53 mins.
99% MPPT Efficiency
Maximise solar generation during daylight hours.
EcoFlow's smart (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day, even during cold and cloudy days.
With a solar input of 1000W, connect up to 2 EcoFlow 400W Portable Solar Panels or 4 sets of 220W Bifacial Solar Panels.
Take Control Of Your Power.
Take control of your power.
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Experience peace of mind during power cuts
With our all-new AC Always On Mode, the AC power button stays on, even during a power cut or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust power
Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings. Prioritise solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
Always power ready
Extensive 5-Year
Specs of DELTA 2 Max
2048 Wh
Extra Battery
X-Boost 3100W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-stream Fast Charge 2300W, 10A
AC Input Voltage
Car Charging
Support 12V/24V battery, 8A
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
50 lbs
Net weight (kg)
23 kg
Specs of DELTA 2 Max Smart Extra Battery
2048Wh
Input Port
51.2V, 2000W Max
Output Port
51.2V, 3200W Max
Battery
LFP chemistry, 3000 cycles to >80% capacity
Dimension
464 × 235 × 283 mm (18 × 9 × 11 in.)
Weight
19kg(42lbs)
What’s in the box
EcoFlow DELTA 2 Max Smart Extra Battery, Extra Battery Cable, User Manual, Warranty Card
Compatible with
Thanks for subscribing!
Explore More
