Power Every Day For 10 Years
EcoFlow DELTA 2 Max
10-Year LFP Battery,
Built To Last 6× Longer.
Durable, Safe, Lightweight
LFP Battery Chemistry
That's 6x Longer Than Other Power Stations With A Similar Capacity And Output.
Advanced BMS Protection
Protective Layers Inside And Out
Robust Design
Upgraded Tech, Lighter
Weight
Industry's Lightest 2400W LFP Solar Generator. Even with its upgraded LFP battery, DELTA 2 Max is still 30% lighter than similar power stations on the market.
DELTA 2 Max powers almost all the devices you need with a large 2400W AC output. Plus, with X-Boost proprietary technology, run appliances with an output of up to 3100W. Compared with other power stations, DELTA 2 Max can power more devices, while still preventing overloading and overheating.
Compatible with the EcoFlow PowerStream Balcony Solar System
You can turn your DELTA 2 Max into a Balcony Solar System at minimal cost. With the grid-tied inverter, PowerStream microinverter, connect to your DELTA 2 Max and plug into an AC wall outlet in minutes to achieve a grid-tied connection for a whole-home power supply. Works with up to 800W solar input, removing energy waste and reducing energy bills.
Expandable up to 6kWh
Triple the power.
Fuel Up 80% In Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 53 mins.
Up to 1000W Solar Input
Solar Charging Times
880W Charge approx. 2.6 hours
800W Charge approx. 2.8 hours
Extensive 5-Year
As Quiet as 30 dB
Peaceful charging.
*From a distance of approximately 20 in., noise level is 30 dB (with low input and 500W output) vs. other power stations with 55 dB or higher.
DELTA 2 Series
Expendable LFP Battery Power Solution
DELTA 2 offers capacities of 1-3kWh, while DELTA 2 Max provides energy storage from 2-6kWh. Get 10 years of daily use before hitting 80% of its original capacity. That’s down to its LiFePO4 battery chemistry, giving you 3000+ full cycles for a 6× longer life.
DELTA 2 Max
AC Charging cable
User manual & warranty card
The solar to XT60i charging cable is not included in 175W Rigid Solar Panel bundle.
Click here to get a solar to XT60i charging cable.
2048 Wh
Extra Battery
X-Boost 3100W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-stream Fast Charge 2300W, 10A
AC Input Voltage
220- 240 V~ max. 10A 50/60 Hz
Car Charging
Support 12V/24V battery, 8A
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
50 lbs
Net weight (kg)
23 kg
