EcoFlow DELTA 2 Max Solar Generator (PV400W) - 2*400W + DELTA 2 Max - EcoFlow UK
EcoFlow UK
12 payments of £191 41 at 0% interest with Splitit. Learn more
Pice Guarantee
Regular price £2,297.00
Sale price £2,297.00 Regular price £2,297.00
Days
Hours
Minutes
Seconds
Up to 47% Off — The Biggest Sale of the Year! Buy Now
Expandable capacity: 2-6kWh expandable capacity to fit your energy
storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit 6144Wh. Ideal for home backup, caravanning, outdoors or even everyday use.
Built to last 6× longer: Get 10 years of daily use until hitting 80% of its
original capacity. That's down to its LFP battery chemistry giving you
3000+ cycles.
Huge AC output: With X-Boost mode, get up to 3000W output power to
run 99% of home appliances. Power 13 devices at once, including 4 AC
outlets.
Fastest recharging: World's fastest AC recharging and X-Stream dual
AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours.
Capture more energy: 99% MPPT efficiency maximises solar generation
during the daytime.
High conversion efficiency rating - guarantees a faster solar charging speed. 0-100% in 3.2 hours (2 sets) or 6.4 hours (1 set).
Customised in-app energy management: Prioritise solar or AC charging, view input and output power, battery levels and more.
5-year warranty - 5 years for DELTA 2 Max, 24 months for 400W Solar Panel.
£2,297.00
EcoFlow DELTA 2 Max Solar Generator is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
Winner of Red Dot Design Award 2023. EcoFlow DELTA 2 Max Solar Generator
Fuel Up 80% in Only 43 Mins*
Experience the world's fastest 43 minute recharge
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 53 mins.
*When combined AC and solar input is 2400W using 1800W AC input and a maximum of 600W solar input. In only 43 min get an 80% charge.
DELTA 2 Max powers almost all the devices you need with a large 2400W AC output. Plus, with X-Boost proprietary technology, run appliances with an output of up to 3100W. Compared with other power stations, DELTA 2 Max can power more devices, while still preventing overloading and overheating.
Power for the entire family.
2048Wh Capacity
Take Control Of Your Power.
Take control of your power.
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Experience peace of mind during power cuts
With our all-new AC Always On Mode, the AC power button stays on, even during a power cut or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust power
Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings. Prioritise solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
Always power ready
What's in the box - DELTA 2 Max
1.DELTA 2 Max 2.AC Charging Cable 3.User manual & Warranty card
What's in the box - 400W Portable Solar Panel
1. 400W Solar Panel 2. Kickstand Case 3. Solar to XT60 Charging Cable 4. User Manual
