EcoFlow Alternator Charger 600: Safe & Fast Charging | EcoFlow Europe - Alternator Charger 600 + DELTA 2 MAX - EcoFlow UK
EcoFlow UK
Pice Guarantee
Regular price £1,448.00
Sale price £1,448.00 Regular price £1,448.00
Save up to £150.00
- 6× Faster Charging – Charge 1kWh in just 1.9 hours*, so your power station is ready when you arrive.
- Charge While Driving – Keep your power station topped up on the road, no more outdoor power anxiety.
- 8 Safety Layers – 5 battery protections + 3 alternator protections for complete peace of mind.
- Universal Compatibility – Works with EcoFlow RIVER & DELTA series and most third-party power stations.
- Smart Control – Manage charging modes anytime via the EcoFlow app or your car’s infotainment system.
- 3 Charging Modes – Includes reverse charging via power station to protect your car battery.**
* Tested using a 12V car charging system at 25℃ ambient temperature. Actual results may vary by vehicle and environment.
** The Alternator Charger 600 includes one XT60 output cable in the box. An additional cable with communication (XT150 or 4+8) is required for reverse charging. See the compatibility chart at the bottom of the page for details.
£1,448.00
Faster – Top Up 1kWh in Just 1.9 Hours*
Charge as you drive – 6× faster than a traditional car cigarette lighter. Power up 1kWh in only 1.9 hours and arrive with a fully charged portable power station.
Charge While You Drive, Power Anywhere
Car Camping
Vehicle Conversions
Disaster Evacuation
For compact power stations (1kWh and below), the Alternator Charger keeps your unit topped up on the road. Enjoy worry-free power for every outdoor adventure.
Skip traditional hardwired 12V batteries and DC-to-DC chargers. With a power station + alternator charger setup, you get ultimate flexibility: power onboard systems while driving, then take your power outdoors for lighting, cooking, or tools.
When emergencies hit, restore your power station to full during the evacuation drive—even if it’s been sitting unused and partially discharged.
Safer – Enhanced Alternator & Starter Battery Protection
The Alternator Charger harnesses surplus alternator power without disrupting normal vehicle operation or adding extra load while driving.
Note: A vehicle alternator typically delivers ~50% more power than required for basic onboard systems during normal driving. The Alternator Charger safely utilizes this surplus. Combined with intelligent starter battery voltage detection, it automatically adapts output based on alternator model, driving conditions, and in-car power usage—always staying within safe operating limits.
Five Layers of Protection with Advanced Quality Standards
Designed for outdoor and off-road conditions, the Alternator Charger features an IP4X dust protection rating to guard against particles commonly found in vehicle cabins and engine bays. The fanless natural cooling design ensures a sealed structure that resists dust buildup, reducing the risk of short circuits and supporting long-term, reliable performance in harsh environments.
Reverse Charging for Car Battery Protection
With 3 charging modes, the Alternator Charger 600 supports reverse charging* to the starter battery via the power station. This helps maintain vehicle battery health and prevents draining.
*Requires an output cable with communication function (XT150 or 4+8 supported; XT60 not supported). The Alternator Charger 600 includes one XT60 output cable in the box. An additional cable is required for reverse charging.
With 3 charging modes, the Alternator Charger Plus 1000 supports reverse charging* to the starter battery via the power station or solar panels. This helps maintain vehicle battery health and prevents draining.
*Requires an output cable with communication function (XT150 or 4+8 supported; XT60 not supported). The Alternator Charger Plus 1000 includes one XT150 output cable in the box.
[Charging Mode] – up to 600W
[Reverse Charging Mode] – up to 600W
[Battery Maintenance Mode] – up to 100W
Use when battery voltage is healthy. Charges the power station while driving.
Use when multiple 12V loads are connected to the vehicle battery. Provides supplemental power from the power station through the alternator charger to keep the starter battery from draining.
- Emergency Charging Mode – approx. 15AUse when the vehicle battery is depleted and the engine won’t start. Functions as an alternative to a jump starter by slowly restoring the battery to normal voltage.
Note: 12V battery minimum starting voltage: 5.5V; 24V battery minimum starting voltage: 10V
Use when starter battery voltage is low. Works as a battery maintainer, delivering steady current to extend starter battery lifespan.
Fully Utilize 3 Charging Modes Across Scenarios
Car Camping
Overlanding & Van Conversions
Long-Term Storage
Simpler – Smart Control via App or Infotainment
An industry first: supports car infotainment connectivity, compatible with Apple CarPlay and Android Auto interfaces*.
Monitor real-time starter battery voltage, portable power station SOC, and remaining charging time directly on your vehicle’s infotainment screen. Adjust charging modes on the go to manage power station status—everything at your fingertips.
*Apple CarPlay and Android Auto are trademarks of Apple Inc. and Google LLC. Compatibility may vary by vehicle model and system version.
Universal Compatibility with Vehicle Batteries & Power Stations
Compatible with Power Stations
Works with 24V/48V portable power stations via XT60 cable (included). Supports EcoFlow RIVER & DELTA series plus most third-party models*.
* DELTA Pro Ultra is not included. Requires the correct output cables or adapters based on the power station’s port type. Actual charging power is limited by the maximum input capacity of the connected power station.
Plug-and-Play Design for Easy Installation
Braided Input Cable – Easy Routing
Direct Plug-In Terminals – Quick Transfers
Ignition Start – Automatic Power-On
A braided-sleeve input cable reduces friction for smoother firewall passage during installation. Its abrasion-resistant design prevents sheath damage and meets automotive industry standards for long-term durability.
No screws, no tools. The charger’s direct plug-in terminals make it easy to connect or disconnect your portable power station—perfect for owners who use multiple vehicles.
Once the ignition cable is connected, the alternator charger powers on automatically with the engine. No need to press a button or activate it in the app each time.
Specifications
Model
EF-AC-002
Approx. 1.1 kg
Dimensions (W x D x H)
224×153×38 mm
Wi-Fi
Supported
Bluetooth
Supported
Charging Mode
Input: 12V/24V⎓(11V-31V⎓), 45A Max.
Output: 24V⎓/40V-60V⎓, 12A Max, 600W Max
Input: 40V-60V⎓, 3A Max.
Output: 13.8V/27.6V⎓, 100W Max.
Input: 40V-60V⎓, 12A Max.
Output: 13.8V/27.6V⎓, 45A Max.
Protection Type
Reverse polarity protection
Overcurrent protection
Short circuit protection
Overvoltage and undervoltage protection
Fuse's Rated Current
125A
Operating Temperature
–10℃ to 45℃ (14℉ to 113℉)
Storage Temperature
–30℃ to 70℃ (–22℉ to 158℉)
Operating Humidity
≤95%
Storage Humidity
≤95%
Is the EcoFlow Alternator Charger compatible with third-party power stations, and how are they charged?
The Alternator Charger can charge third-party portable power stations if the following conditions are met:
1. Connected via an XT60 cable.
2. The battery type is configured in the settings.
3. The vehicle battery voltage (12V/24V) is selected based on the actual voltage level of the vehicle battery connected to the EcoFlow Alternator Charger.
4. The portable power station type is selected as a third-party 24V battery.
Why can't the maximum power be reached when using the XT60 cable?
1. The maximum power is limited to 500W for both the 800W and 500W Alternator Charger when using an XT60 cable.
2. When the portable power station type is set to 48V, the maximum power is 500W. When set to 24V, the maximum power is 360W.
3. The actual charging power depends on the power station's current input capability. The 800W/500W/360W ratings refer to the Alternator Charger's rated output power, but the actual input power is determined by the power station's rated input capacity.
Why do I need to set the cable length?
The cable length setting digitally compensates for voltage drop caused by long cable connections to the vehicle battery, ensuring a more accurate voltage display.
Recommendation: Set it based on the actual measured length of the input circuit.
Why can't I select the portable power station type as 24V (24V unit: RIVER 2/3/mini/Max/Pro, WAVE, & third-party 24V batteries) when the vehicle battery is set to 24V?
The Alternator Charger uses a boost circuit design, which requires the input voltage to be lower than the output voltage to ensure optimal performance and electrical safety.
Will the Alternator Charger consume more fuel (i.e. affect gas mileage) when being used?
The product uses the power generated by the vehicle's alternator. Even if all the electrical devices inside the car are turned off, the alternator still generates power while the vehicle is running. The Alternator Charger harnesses the surplus power generated by the car's alternator and stores it in a portable power station through the charger. The impact on fuel consumption is very minimal.
No drilling is required for the installation. Wiring to the vehicle's front alternator does not require drilling and will not damage the vehicle. Simply route the wiring through the firewall near the driver's seat. The Alternator Charger can also be placed using a no-drill method.
Is the Alternator Charger suitable for DIY installation?
The installation of the Alternator Charger is fairly straightforward, and it is feasible for some users with some hands-on experience to install it themselves. However, it is still recommended to contact professional personnel from related workshops for installation.
Installation advice: When wiring, avoid high temperatures and sharp and friction-prone areas, and securely fasten the cables to avoid cable wear or loose connections caused by cable movement. The Alternator Charger may generate relatively high temperatures, so avoid covering the product. After use, avoid immediate direct contact to prevent the risk of scalds.
What advantages does the 500W Alternator Charger offer compared to charging via the cigarette lighter?
The charging power is significantly increased. The charging power of a cigarette lighter is about 100W. In contrast, the Alternator Charger can support charging portable power stations continuously at a high power of 500W while driving, which is 5 times the power of a cigarette lighter.
What types of vehicles are suitable for installation? Can all of them reach maximum power?
Technically, the Alternator Charger is not limited by vehicle power sources (fuel, electric, etc.), but it is best suited for fuel-powered vehicles. It is also compatible with hybrid and range-extended vehicles.
The actual charging power depends on the alternator’s surplus power and may fluctuate. Additionally, some older or specialized vehicles with consistently low voltage may not function properly with the Alternator Charger.
How does the Alternator Charger automatically start and stop?
According to voltage recognition, the starting voltage is adjustable, and the adjustment range is 11V-30V.
If the vehicle battery is low on power, can the vehicle battery be charged by the alternator charger?
Reverse charging is supported. Please manually switch the working mode in the EcoFlow APP. (Requires XT150 cable and must be used with the EcoFlow DELTA series products.)
How long does it take to fully charge a RIVER Series / DELTA Series product using the 500W Alternator Charger?
RIVER 2 - 2.4 hr
RIVER 2 Pro - 3.6 hr
RIVER 2 Max - 2.5 hr
RIVER 3 - 2.3 hr
DELTA 2 (1kWh) - 2.1 hr
DELTA 3 (1kWh) - 2.1 hr
DELTA 3 Plus (1kWh) - 2.1 hr
How to determine whether my car is compatible with the Alternator Charger?
The Alternator Charger supports an input voltage range of 11V-31V, making it theoretically compatible with vehicles using 12V or 24V starter batteries.
How many working modes does the Alternator Charger have?
1. Charging Mode: The vehicle's alternator charges the portable power station, while the car battery acts as a load to conduct current.
2. Reverse Charging Mode: The portable power station charges the starter battery or RV house battery with relatively high current. (Requires the XT150 cable and must be used with EcoFlow DELTA Series products.)
3. Battery Maintenance Mode: Similar to reverse charging, but with lower current and a maximum working power of 100W. (Requires the XT150 cable and must be used with EcoFlow DELTA Series products.)
