EcoFlow STREAM Ultra X | EcoFlow UK - STREAM Ultra X High-Efficiency Solar Kit (5.76 kWh+2000 Wp) - EcoFlow UK
EcoFlow UK
12 payments of £199 91 at 0% interest with Splitit. Learn more
30 Days Price Guarantee
WN STREAM Ultra X Home Solar Battery
Regular price £2,399.00
Sale price £2,399.00 Regular price £3,356.00
Save up to £1,556.00
Days
Hours
Minutes
Seconds
Up to 47% Off — The Biggest Sale of the Year! Buy Now
  • Save up to £1,729 annually on your electricity bills.¹
  • Enjoy up to 2300W AC output, easily powering high-demand appliances.
  • Expandable capacity from 3.84 to 23kWh provides energy coverage throughout the day and night.
  • With a 2000W solar input, 4 MPPTs, and Low-Light Cells, this system captures more solar energy.
  • Features a 15-year lifespan, ensuring high safety and long-term reliability.
  • Set up is effortless and requires no electrician.
  • Compatible with third-party devices that use Tiber, Matter, and Shelly protocols.
    Plug-in solar regulation is expected to be introduced in the UK in the coming months.
    EcoFlow STREAM Series are equipped with open-end cables and fully comply with existing regulations. Once the new regulation comes into effect, plug-in cables will be available for purchase to enable easier installation.
Stay Tuned!
Plug-in solar regulation is expected to be introduced in the UK in the coming months. EcoFlow STREAM Series are equipped with open-end cables and fully comply with existing regulations. Once the new regulation comes into effect, plug-in cables will be available for purchase to enable easier installation.
£2,399.00 £3,356.00 -£957.00
Maximum Solar Utilisation, Maximum Savings
2300W Output for Peak Demand Moments
When you connect two units in parallel, you can boost the output to 2300W (on-grid), allowing you to power heavy-duty appliances 100% with solar energy.
The EcoFlow STREAM Ultra X provides a leading 2300W (on-grid) AC output, letting you power high-demand appliances through its AC socket using solar energy stored in the battery.
Two Units
Single Unit
Sunset to Sunrise Power: From 3.84kWh to 23kWh
EcoFlow STREAM Ultra X goes beyond industry standards, capturing surplus solar energy during the day to keep you powered through the night — and it scales easily to fit your energy needs.
2 Ways to Scale for Different Needs
Dual Units in Parallel
Connect two STREAM Series units, or pair a STREAM Ultra X with any STREAM Extra Batteries using a Parallel Cable. This setup lets you run heavy-duty appliances up to 2300W on-grid, all powered by solar energy.
Decentralised Solar Network
With multiple STREAM products, you can place one near your solar panels and the others anywhere in your home. Once the batteries are plugged into AC sockets, they automatically form a solar network, distributing energy to your devices in the laundry, kitchen, living room, and beyond.
* Both scaling methods require all devices to connect to the same Wi-Fi network. Even without cloud access, seamless operation over your local LAN keeps your energy flowing without interruption.
Capture Every Ray, Maximise Sunlight
Harness the sun's power faster than ever. With four advanced MPPTs and a massive 2000W solar input, the STREAM Battery captures and stores more solar energy, more efficiently.
Don't Let Clouds or Dusk Limit Your Solar Power
The STREAM Battery uses advanced low-light technology to capture energy from even muted skies, delivering up to one extra hour of solar harvest each day compared to industry averages.
Safety You Can Trust
Ready For Any Weather
AI-Driven Energy, Always Optimised
EcoFlow OASIS doesn’t just answer your energy management questions quickly—it also provides smart analysis and tailored optimisation tips to help you get the most from your system.
Learn More about the EcoFlow Oasis System
AI Mode: Smarter Energy for Dynamic Pricing²
EcoFlow’s AI Mode analyses huge amounts of data, including dynamic electricity tariffs, solar forecasts, consumption predictions, and battery status. It can boost your annual savings by up to 29%.
If the system predicts cloudy weather, it will automatically charge your battery during low-rate periods to ensure you have enough power for peak times in the evening—maximising your savings without you lifting a finger.
Self-Powered, Fully Customisable
Set your own preferences for battery level, time-of-use pricing, and scheduling. Store solar energy or power your home whenever your battery exceeds your chosen reserve—helping you cut down on grid electricity.
AI Mode
* For the best results, suggest pairing AI Mode with a Smart Meter.
* For best results, we recommend using a Smart Meter.
Total EcoFlow Energy Ecosystem Harmony
Compatible with EcoFlow Smart Meter and Smart Plug
Take full control with EcoFlow Smart Meters or Smart Plugs to ensure no power goes to waste. When you connect an EcoFlow Smart Meter with the STREAM Series, they communicate directly, even offline. This allows the STREAM Series to automatically adjust its output to your home grid in real time, with minimal delay.
Cross-Brand Ecosystem Harmony
EcoFlow OASIS brings together third-party devices that use Tiber, Matter, and Shelly protocols, all on one unified platform. Enjoy a simpler, more intuitive experience without the hassle of switching between multiple platforms and apps.
Explore STREAM Ultra X Details
EcoFlow STREAM Pro
EcoFlow STREAM Max
3,84kWh
1,92kWh
1,92kWh
1,92kWh
3,84kWh
1,92kWh
1,92kWh
1,92kWh
4
4
3
2
4
4
3
2
2000W (500W × 4)
2000W (500W × 4)
1500W (500W × 3)
1000W (500W × 2)
2000W (500W × 4)
2000W (500W × 4)
1500W (500W × 3)
1000W (500W × 2)
1200W
1050W
1050W
1050W
1200W
1050W
1050W
1050W
1200W
1200W
1200W
1200W
1200W
1200W
1200W
1200W
Yes
Yes
Yes
No
Yes
Yes
Yes
No
2300W (10A)
2300W (10A)
2300W (10A)
2300W (10A)
2300W (10A)
2300W (10A)
2300W (10A)
2300W (10A)
38,8kg
23,1kg
22,8kg
22,0kg
38,8kg
23,1kg
22,8kg
22,0kg
420mm × 294mm × 460mm
284mm x 255mm x 458mm
What's in the box - STREAM Ultra X
STREAM Ultra X × 800W
STREAM Solar Panel Extension Cable (2.95m) × 8
STREAM AC Cable (1.5m) × 1
PV Wrench × 1
PV Wrench × 1
Mounting Bracket × 1
Locking Bracket × 1
Locking Bracket × 1
Safety Instructions × 1
Installation Guide × 1
Warranty Card × 1
Warranty Card × 1
Specs - EcoFlow STREAM Ultra X
3,84kWh
6000 cycles to 70% capacity
AC Charging Input
1200W
1200W
MPPT
4
PV Input Power
2000W (500W*4)
PV Input Voltage
Maximum 60V DC
AC Output-Grid Tied
800W
AC Charging Input
10A
Max Device Power Supported
2300W (10A)
Operating Temperature
-20~55°C
Battery Self-Heating
Connection
Wi-Fi/Bluetooth
Ingress Protection Rating
IP65
38,8kg
Acoustic Noise
<30 dB
10-Year
What are the differences between the STREAM Max and the STREAM Ultra/Pro?
1. In off-grid mode, the STREAM Max doesn't support discharging via the AC outlet, but it can be charged using the PV port.
2. When the STREAM Max and STREAM Max/AC are connected in parallel, they must be connected to the AC outlet of the STREAM Max using an AC cable. For more information, see the System Expansion Chapter of the STREAM Max User Manual.
*Note: After completing the installation and connection of the STREAM Max, you must configure the system wiring settings in the app before using the device.
3. When a STREAM Max is connected to a STREAM Ultra/Pro/AC Pro/Ultra X in parallel, only one device can be connected to the end of the connection chain.
What are the differences between the STREAM AC and the STREAM AC Pro?
1.The STREAM AC doesn't support discharging in off-grid mode. It can only work in on-grid mode.
2. The maximum charging/discharging power of the STREAM AC battery is 800W.
3. When the STREAM AC and STREAM Max are connected in parallel, they must be connected to the AC outlet of the STREAM Max using an AC cable. For more information, see the System
Expansion Chapter of the STREAM AC User Manual
*Note: After completing the installation and connection of the STREAM AC, you must configure the system wiring settings in the app before using the device.
4. When a STREAM Max is connected to a STREAM Ultra/Pro/AC Pro/Ultra X in parallel, only one device can be connected to the end of the connection chain.
What are the differences between the STREAM Ultra X and the STREAM Ultra?
1.The battery capacity of the STREAM Ultra X is 3.84kWh, which is twice the
battery capacity of the STREAM Ultra.
2. The battery of the STREAM Ultra X has a greater charging power. The maximum charging power is 1500W when using PV, 1200W when using the grid and 1500W when using both.
3. Replacing the DIY Front Case of the STREAM Ultra X is a different process.For more information, see the STREAM Ultra X User Manual.
Is the STREAM Solar Battery compatible with other products (including third-partyproducts)?
Please read the Product Compatibility List in the User Manual before purchasing and using the STREAM Solar Battery with other products (including third-party products).
In the UK, local regulations require the EcoFlow STREAM DIY Cable to be wired into the distribution board, which must be done by a certified installer or electrician.
STREAM Ultra X features a battery capacity around 40% higher than industry standards, helping to minimise solar energy waste. With support for up to 2300W AC output, it can power high-demand appliances, making it the most efficient balcony storage solution for solar energy use.
1. Estimated Electricity Cost Savings (Based on Germany)The estimated savings are calculated using the following formula:
- Annual Savings = Savings from self-consumed system generation + Savings from surplus energy utilisation
- Generation estimates: PVWatts Calculator
Self-consumption rate: Estimated using HTW Berlin's Independence Calculator (source)
- Electricity rate: €0.40/kWh
- Estimated surplus energy utilisation rate (AI Mode, Solar Forecast): 35%
Note: Savings will vary depending on geographic location, panel orientation, daily electricity prices, and other factors.
Example Calculations:
Configuration: Ultra X × 6 + 10 × 500W solar panels (5,000W total)
Annual savings: (5328kWh × 90% × €0.40/kWh) + (5328kWh × 10% × 35% × €0.40/kWh) = €1,993
2. Some AI features in the EcoFlow app require a premium subscription. Please refer to the app for details on plans and feature availability.
3. The EcoFlow app integrates weather data from Solcast, performing over 100 million data operations per hour to deliver forecasts with up to 94% accuracy and a three-day horizon. (source)
  • 5 stars: 61 (74%)
  • 4 stars: 18 (22%)
  • 3 stars: 1 (1%)
  • 2 stars: 0 (0%)
  • 1 star: 2 (2%)
Some of the reviews shown are from related products the merchant grouped with this one.
A
Ashley A.
Review for Ultra X Stream + 500w panels
Review for 2 x Ultra X Stream + 8 x 500w panels.
I ordered the bundle in August and everything delivered with a week or two. I'm not a DIY expert but had no problems getting the panels all mounted on a spare flat roof (using a flat roof mounting kit that, based on my research, keeps the install within UK permitted development). Cables run down to the garage and into the stream units.
I've been really impressed with the app and configuration options. We hardly use any peak rate electric now, and instead using off peak power to charge the batteries. I think we will be saving around £500 per year with the 8 panels and 2 Ultra X
Thanks Ecoflow!
A
Anonymous
Great as a first time buyer
Easy set up self explanatory, app is a little fiddly to understand at the start but after a few days it becomes very easy to understand. Highly recommended the smart meter to go with this!
J
James M.
All the power
All the power.
Really good battery with enough power to cover the ordinary running of our house with one of us working from home.
The large amount of solar input is great. It is stylish enough to blend in in the living room.
All in all really impressed. i only wish it came with some solar extention cables of 10m+ rather than having to go 3rd party.
Paired with the Smart meter this thing is amazing.
G
Graham
Workshop roof installation
At the time of purchase, a set of 4 x 250W panels were offerred for just £1. No explanation of how to incorporate these extra panels was offerred, and eventually tech support gave a suggestion that did not make any sense.
I purchased an extra micro-inverter and connected the extra panels to that, with the output plugged into one of the battery AC i/o ports.
This is working perfectly with an average output in October with east facing panels of around 7kWh per day. In an ideal setup this would be considerably more, but this is adequate for the low installation cost and should break even within 2-3 years.
As I am retired, there is a constant power use in the home, so the battery has so far not gone past 50% charge, so this system is a good balance for my circumstances.
This relatively low cost method is a good introduction to using solar, compared to the high cost of a roof mounted traditional system.
Highly recommended.
S
Steve S.
Excellent battery system, easy to install
Excellent battery system, easy to install and set up, small footprint and stylish look. The app is user friendly after investing a small amount of time to learn how it works. Combined with solar and low overnight tariff this system is saving me significant money on my monthly electricity bill.
S
Steve S.
B
Ben
Great solution for small scale solar
I'm not interested in a large solar array at the moment so this has been great. Works perfectly with two panels and micro-inverter. I did plan on running solar cables straight to the battery but efficiency and charging has been fine via the existing micro-inverter so probably not going to go to the effort of running more cables.
Compact (but very heavy) battery. Looks really sleek. Mine is hidden away but could easily be on display.
Is completely covering my base load and taking a good chunk off high energy usage. Need more time to work out just how cost effective it is though.
App and setup was fairly easy. Had to reset a couple of time at the beginning but running smoothly now.
Tried the battery without a smart meter for a couple of weeks, wouldn't recommend that. It does function without one but is amazing how much energy is lost - smart meter (bought separately) is essential.
I
Ian L.
Worthy upgrade from the micro inverter only.
I started with the micro inverter but a month in i realized a battery was needed as well as extra panels to make the most of the solar generation.
I went from 2 panels mounted west to 2 more to the east on the summer house roof, the odd time i need to charge the battery due to little sun light but most days there is enough solar to feed the house and charge the battery, my next bill looks like one from the 1990's.
A
Anonymous
V impressive battery/inverter
This worked first time out of the box and delivers what it says, which is all you can ask for, really. Set it up in my office log cabin. Obviously takes longer to fill the battery and as my array is only 1280w max (4x Renogy 320w compact -- it was a self-install so I wanted to keep the weight down for easy handling) except on the sunniest days it was struggling to fill it fully thanks to tree shading after 2.30/3pm. But the upside is it lasts twice as long as the Ultra. I've since added an Ecoflow Stream Microinverter in a separate part of the house to cover the base load, which allows the ultra x to charge more quickly.
R
Raywant
Great bit of kit
Great bit of kit. Super easy to install. Instantly saving money straight out of the box! And the app is really great too. Would highly recommend.
J
Jamie L.
Amazing bit of kit
Amazing bit of kit. Works flawlessly and has reduced my bills by at least 60% for the last month. And if you have an EV day night tarrif it will still save money even during the winter without solar panels. The only regret I have is not waiting another couple of months for the new 5000 series which would have been alot more suitable for my needs
A
Anonymous
Happy with the system
Happy with the system. All works as I imagined it would
S
Shawn
I love the Ecoflow Stream Ultra X
I love the Ecoflow Stream Ultra X. I use it for load shifting for now, but it is making real savings already. I hope to connect it to my plugin solar panels next once they are set up.
A
Anonymous
Unreal - so easy and works a dream
Unreal - I set this system up in less than half an hour. Plug and play by definition! Running perfectly and the solar is powering the house for half the day, with the ultra X covering time before and after sunlight. Thrilled with the purchase!
j
julian p.
Ecoflow Balcony solar system and solar panels
This is an honest review, I am not sponsored or affiliated with Ecoflow ,
all Steam batterys I have bought by myself and like most of you I had to wait for delivery as they are so popular but are worth it.
After seeing a video on YouTube with Mr steve jones DIY that the uk was getting Plug in solar I order a Ecoflow Stream Ultra and an ecoflow smart meter and I ordered 4 solar panels from The Plum Centre that Mr steve jones DIY had recommended and I ordered a drum of 50 meters of 4mm solar cable and mc4 plugs from the plum centre.
I had a local Electrician install the solar panels run the cables, hard wire the power cable into the consumer box (at the moment it has not been passed just to plug in) and the smart meter and he also changed the consumer boxes the one in the workshop and the one in the house as they all needed changing as they were too old.
And put in the BI direction RCD, he also did the g98 form and all other certificates.
I have bought an stream Ultra X and a parallel lead so that they can be daisy chained Together and work as one just under 6 kWh. I am so impressed that I’m thinking of ordering another Ulta X as I find that just under 9.2kWh would work great in running our house and especially over the winter months with the 9p per kW overnight charge that at the moment I don’t need as I’m generating 10 kWh per day with just 4 solar panels.
Im going to be ordering some more panels next year.
Now to Ecoflow customer service which in fair have emailed me back next day and have been very helpful on the phone sorting out some small issue I had.
Now the ecoflow app I know that there will be a new one coming out in the next few months but as Mr steve Jones DIY says sits very well made and it gives you all the stats you need, but it does have a little niggle like it shows that the batterys have been disconnected for a few seconds and them come back on, this only happens on my iphone and it works perfectly on my ipad, so work that out.
There are new ecoflow battery’s coming out in the next few months, but I’m happy with what I have as I don’t have room vertical and maybe they might bring down the prices to reflect this.
There are plenty of videos on YouTube with plenty of advice on installation.
These ecoflow batterys come with 10year warranty, so what you waiting for !!
J
John
Just starting on this journey
Just starting on this journey and so far it has been great. Delivery of my complete order took 6 weeks which was a bit of a disappointment.
The equipment is working perfectly and saving me a lot more than I had imagined on my electricity bill.
I’m waiting on the upcoming release of the 5kwh battery and hoping it is not too expensive.
P
Piers C.
The Ultra X is a great unit - it works quietly and is saving 50% of my bills.
The Ultra X is a great unit - it works fantastically with solar charging and my garden setup. Setup was simple, and I'm already making great savings!
However I would note that if you are aiming to earn through solar excess this system isnt great for that. Get this system if you aim to use all of generation you make.
There is a bug in the system where the battery is not bypassed when full so that solar MUST go through the battery before going to the grid. Example: Battery reaches 100% charge -> solar will stop -> battery will discharge till there is room -> Battery charges back up. It's not ideal but if you aim to use all your generation its not a big deal.
D
Daveb
Ordered without any problems
Ordered without any problems. Slight 1 day delay from the courier company. Everything worked exactly as it should after plugging in 4 x 475 watt panels and connecting to a plug. Now saving money every day.
A
Al M.
So far great
There were a few problems receiving the unit but the company were good in getting it resolved.
They also sent me a different cable for installation to comply with uk regulations.
The unit is really easy to install although final connection to the consumer unit should only be done by an electrician.
Overall I’m very happy with it, it’s like the apple of micro inverters. Nicely packaged & a smart looking device. The app is good & there’s nothing not to like.
12 payments of £224 83 at 0% interest with Splitit. Learn more
