EcoFlow WAVE 2 + EcoFlow DELTA 2 Max - WAVE 2 + DELTA 2 Max + 400W Portable Solar Panel + XT150 - EcoFlow UK
EcoFlow UK
Secure Payments
Multi-channel Support
Pice Guarantee
Bank Holiday🎶
Regular price £3,497.00
Sale price £3,497.00 Regular price £3,497.00
Days
Hours
Minutes
Seconds
Top Deals | Ends 9 Aug | Get Ready for Bank Holiday Getaways
Learn More
WAVE 2:
• Fastest Cooling and Heating
• Installation-free! Fits Anywhere
• 8 Long Hours of Comfort
• 44dB: Perfect For Quiet Sleep
• Using R290: A Greener Way to Beat the Heat
• 4 Ways to Charge
DELTA 2 Max
•10-Year Long-Lasting LFP battery
•World's Fastest Recharging Speeds
•Power 99% of Appliances
•Industry's Lightest
•Expandable Capacity up to 6kWh
• Up to 23% conversion rate
*The included XT150 (1 meter) cable connects your EcoFlow WAVE 2 to DELTA 2 Max, giving you longer runtime for WAVE 2 without any extra cost.
Accessories
£3,497.00
Secure Payments
Pair your WAVE 2 with an EcoFlow DELTA 2 Max, and you'll get an astonishing 14 hr run time in WAVE 2 Eco Mode. Compared to using other portable power stations, it's 28% more efficient. Experience longer-lasting comfort in your tent, RV, or home with its powerful and portable design.
Fastest cooling and heating
The world's first wireless portable AC with a heater.
EcoFlow's tailor-made compressor enables WAVE 2 to provide 5100 BTUs of cooling and 6100 BTUs of heating.
Prepare for ultimate comfort with WAVE 2!
* Drop 10℃ from 30℃ for 10m³ in 5 min with 5100 BTUs of cooling,
and raise 10℃ from 20℃ in 5 minutes for 10m³ with 6100 BTUs of heating in optimal running performance.
Installation-free!
Fits anywhere
The perfect air conditioner for any compact space!
It is extremely simple to use, requiring no installation or drainage*.
There are air duct adapters to fit any space. Enjoy the convenience of cooling and heating without any fuss.
* No drainage is needed in cooling mode when humidity is below 70%, but it is still needed in heating mode.
Peaceful snooze, quiet & long
With EcoFlow's advanced software algorithm, the WAVE 2 offers multiple modes and app control.
It runs quietly (44 dB) in Sleep Mode and up to 8 hours in Eco Mode.
Eco Mode | 8 hours of runtime | Sleep Mode | As quiet as 44dB
10-year long-lasting LFP battery
Durable, Safe, Lightweight
Experience the industry's fastest AC outlet and solar recharging
80% in 43 Min*
With DELTA 2 Max's upgraded tech, AC charge to 80% in only 53 mins. Combine up to 1000W solar input with AC for a super-fast 43 min charge.
*When combined solar and AC input is 2400W.
400W Portable Solar Panels
Our 400W portable solar panel offers high solar output, conversion efficiency rating,
and a convenient folding design so it’s ready to grab and go at any time.
Charge faster,wherever you go.
A single solar panel with a unique folding design,our 400W solar panel combines powerful energy production with portability.
To achieve a highersolar conversion efficiency of up to 23%, we use multi busbar monocrystalline cells, so you get evenmore energy to recharge your portable power.
Specs of WAVE 2
Net weight
Approximately 14.5kg
Dimensions (L×W×H)
518×297×336 mm
Wi-Fi
This product supports 2.4G Wi-Fi only
AC Input
100-240V 50/60Hz, 820W max
Car Charging Input
12V/24V 8A, 200W max
Solar Input
11-60V 13A, 400W max
Add-on Battery Input
700W max
Specs of DELTA 2 Max
AC Input
X-Stream 2300W max
Solar Input
11V-60V, 15A Max,1000W Max
2400W (Surge 4800W), X-Boost 3100W
Cycle life
3000 cycles to 80%+ capacity
Dimension
49.7×24.2×30.5 cm
Weight
23 kg
2048Wh
5 years
Connection
Wi-Fi, Bluetooth
Specs of 400W portable solar panel
106.8*239.0*2.4 cm
Cell Type
Monocrystalline silicon
Open Circuit Voltage
48V (Vmp 41V)
Short Circuit Current
11A (Imp 9.8A)
Weight(Solar Panel)
Approx.35.3lbs (16.0Kg)
Weight (with Kickstand Case)
Approx. 41.9 (19kg)
