EcoFlow STREAM Ultra X | EcoFlow UK - STREAM Ultra X (3.84kWh) / / - EcoFlow UK
EcoFlow UK
12 payments of £124 91 at 0% interest with Splitit. Learn more
30 Days Price Guarantee
EcoFlow STREAM Ultra X Home Solar Battery
Regular price £1,499.00
Sale price £1,499.00 Regular price £1,499.00
Save up to £1,556.00
Days
Hours
Minutes
Seconds
Up to 47% Off — The Biggest Sale of the Year! Buy Now
  • Save up to £1,729 annually on your electricity bills.¹
  • Enjoy up to 2300W AC output, easily powering high-demand appliances.
  • Expandable capacity from 3.84 to 23kWh provides energy coverage throughout the day and night.
  • With a 2000W solar input, 4 MPPTs, and Low-Light Cells, this system captures more solar energy.
  • Features a 15-year lifespan, ensuring high safety and long-term reliability.
  • Set up is effortless and requires no electrician.
  • Compatible with third-party devices that use Tiber, Matter, and Shelly protocols.
    Plug-in solar regulation is expected to be introduced in the UK in the coming months.
    EcoFlow STREAM Series are equipped with open-end cables and fully comply with existing regulations. Once the new regulation comes into effect, plug-in cables will be available for purchase to enable easier installation.
Stay Tuned!
Plug-in solar regulation is expected to be introduced in the UK in the coming months. EcoFlow STREAM Series are equipped with open-end cables and fully comply with existing regulations. Once the new regulation comes into effect, plug-in cables will be available for purchase to enable easier installation.
£1,499.00
Maximum Solar Utilisation, Maximum Savings
2300W Output for Peak Demand Moments
When you connect two units in parallel, you can boost the output to 2300W (on-grid), allowing you to power heavy-duty appliances 100% with solar energy.
The EcoFlow STREAM Ultra X provides a leading 2300W (on-grid) AC output, letting you power high-demand appliances through its AC socket using solar energy stored in the battery.
Two Units
Single Unit
Sunset to Sunrise Power: From 3.84kWh to 23kWh
EcoFlow STREAM Ultra X goes beyond industry standards, capturing surplus solar energy during the day to keep you powered through the night — and it scales easily to fit your energy needs.
2 Ways to Scale for Different Needs
Dual Units in Parallel
Connect two STREAM Series units, or pair a STREAM Ultra X with any STREAM Extra Batteries using a Parallel Cable. This setup lets you run heavy-duty appliances up to 2300W on-grid, all powered by solar energy.
Decentralised Solar Network
With multiple STREAM products, you can place one near your solar panels and the others anywhere in your home. Once the batteries are plugged into AC sockets, they automatically form a solar network, distributing energy to your devices in the laundry, kitchen, living room, and beyond.
* Both scaling methods require all devices to connect to the same Wi-Fi network. Even without cloud access, seamless operation over your local LAN keeps your energy flowing without interruption.
Capture Every Ray, Maximise Sunlight
Harness the sun's power faster than ever. With four advanced MPPTs and a massive 2000W solar input, the STREAM Battery captures and stores more solar energy, more efficiently.
Don't Let Clouds or Dusk Limit Your Solar Power
The STREAM Battery uses advanced low-light technology to capture energy from even muted skies, delivering up to one extra hour of solar harvest each day compared to industry averages.
Safety You Can Trust
Ready For Any Weather
AI-Driven Energy, Always Optimised
EcoFlow OASIS doesn’t just answer your energy management questions quickly—it also provides smart analysis and tailored optimisation tips to help you get the most from your system.
Learn More about the EcoFlow Oasis System
AI Mode: Smarter Energy for Dynamic Pricing²
EcoFlow’s AI Mode analyses huge amounts of data, including dynamic electricity tariffs, solar forecasts, consumption predictions, and battery status. It can boost your annual savings by up to 29%.
If the system predicts cloudy weather, it will automatically charge your battery during low-rate periods to ensure you have enough power for peak times in the evening—maximising your savings without you lifting a finger.
Self-Powered, Fully Customisable
Set your own preferences for battery level, time-of-use pricing, and scheduling. Store solar energy or power your home whenever your battery exceeds your chosen reserve—helping you cut down on grid electricity.
AI Mode
* For the best results, suggest pairing AI Mode with a Smart Meter.
* For best results, we recommend using a Smart Meter.
Total EcoFlow Energy Ecosystem Harmony
Compatible with EcoFlow Smart Meter and Smart Plug
Take full control with EcoFlow Smart Meters or Smart Plugs to ensure no power goes to waste. When you connect an EcoFlow Smart Meter with the STREAM Series, they communicate directly, even offline. This allows the STREAM Series to automatically adjust its output to your home grid in real time, with minimal delay.
Cross-Brand Ecosystem Harmony
EcoFlow OASIS brings together third-party devices that use Tiber, Matter, and Shelly protocols, all on one unified platform. Enjoy a simpler, more intuitive experience without the hassle of switching between multiple platforms and apps.
Explore STREAM Ultra X Details
EcoFlow STREAM Pro
EcoFlow STREAM Max
3,84kWh
1,92kWh
1,92kWh
1,92kWh
3,84kWh
1,92kWh
1,92kWh
1,92kWh
4
4
3
2
4
4
3
2
2000W (500W × 4)
2000W (500W × 4)
1500W (500W × 3)
1000W (500W × 2)
2000W (500W × 4)
2000W (500W × 4)
1500W (500W × 3)
1000W (500W × 2)
1200W
1050W
1050W
1050W
1200W
1050W
1050W
1050W
1200W
1200W
1200W
1200W
1200W
1200W
1200W
1200W
Yes
Yes
Yes
No
Yes
Yes
Yes
No
2300W (10A)
2300W (10A)
2300W (10A)
2300W (10A)
2300W (10A)
2300W (10A)
2300W (10A)
2300W (10A)
38,8kg
23,1kg
22,8kg
22,0kg
38,8kg
23,1kg
22,8kg
22,0kg
420mm × 294mm × 460mm
284mm x 255mm x 458mm
What's in the box - STREAM Ultra X
STREAM Ultra X × 800W
STREAM Solar Panel Extension Cable (2.95m) × 8
STREAM AC Cable (1.5m) × 1
PV Wrench × 1
PV Wrench × 1
Mounting Bracket × 1
Locking Bracket × 1
Locking Bracket × 1
Safety Instructions × 1
Installation Guide × 1
Warranty Card × 1
Warranty Card × 1
Specs - EcoFlow STREAM Ultra X
3,84kWh
6000 cycles to 70% capacity
AC Charging Input
1200W
1200W
MPPT
4
PV Input Power
2000W (500W*4)
PV Input Voltage
Maximum 60V DC
AC Output-Grid Tied
800W
AC Charging Input
10A
Max Device Power Supported
2300W (10A)
Operating Temperature
-20~55°C
Battery Self-Heating
Connection
Wi-Fi/Bluetooth
Ingress Protection Rating
IP65
38,8kg
Acoustic Noise
<30 dB
10-Year
What are the differences between the STREAM Max and the STREAM Ultra/Pro?
1. In off-grid mode, the STREAM Max doesn't support discharging via the AC outlet, but it can be charged using the PV port.
2. When the STREAM Max and STREAM Max/AC are connected in parallel, they must be connected to the AC outlet of the STREAM Max using an AC cable. For more information, see the System Expansion Chapter of the STREAM Max User Manual.
*Note: After completing the installation and connection of the STREAM Max, you must configure the system wiring settings in the app before using the device.
3. When a STREAM Max is connected to a STREAM Ultra/Pro/AC Pro/Ultra X in parallel, only one device can be connected to the end of the connection chain.
What are the differences between the STREAM AC and the STREAM AC Pro?
1.The STREAM AC doesn't support discharging in off-grid mode. It can only work in on-grid mode.
2. The maximum charging/discharging power of the STREAM AC battery is 800W.
3. When the STREAM AC and STREAM Max are connected in parallel, they must be connected to the AC outlet of the STREAM Max using an AC cable. For more information, see the System
Expansion Chapter of the STREAM AC User Manual
*Note: After completing the installation and connection of the STREAM AC, you must configure the system wiring settings in the app before using the device.
4. When a STREAM Max is connected to a STREAM Ultra/Pro/AC Pro/Ultra X in parallel, only one device can be connected to the end of the connection chain.
What are the differences between the STREAM Ultra X and the STREAM Ultra?
1.The battery capacity of the STREAM Ultra X is 3.84kWh, which is twice the
battery capacity of the STREAM Ultra.
2. The battery of the STREAM Ultra X has a greater charging power. The maximum charging power is 1500W when using PV, 1200W when using the grid and 1500W when using both.
3. Replacing the DIY Front Case of the STREAM Ultra X is a different process.For more information, see the STREAM Ultra X User Manual.
Is the STREAM Solar Battery compatible with other products (including third-partyproducts)?
Please read the Product Compatibility List in the User Manual before purchasing and using the STREAM Solar Battery with other products (including third-party products).
In the UK, local regulations require the EcoFlow STREAM DIY Cable to be wired into the distribution board, which must be done by a certified installer or electrician.
STREAM Ultra X features a battery capacity around 40% higher than industry standards, helping to minimise solar energy waste. With support for up to 2300W AC output, it can power high-demand appliances, making it the most efficient balcony storage solution for solar energy use.
1. Estimated Electricity Cost Savings (Based on Germany)The estimated savings are calculated using the following formula:
- Annual Savings = Savings from self-consumed system generation + Savings from surplus energy utilisation
- Generation estimates: PVWatts Calculator
Self-consumption rate: Estimated using HTW Berlin's Independence Calculator (source)
- Electricity rate: €0.40/kWh
- Estimated surplus energy utilisation rate (AI Mode, Solar Forecast): 35%
Note: Savings will vary depending on geographic location, panel orientation, daily electricity prices, and other factors.
Example Calculations:
Configuration: Ultra X × 6 + 10 × 500W solar panels (5,000W total)
Annual savings: (5328kWh × 90% × €0.40/kWh) + (5328kWh × 10% × 35% × €0.40/kWh) = €1,993
2. Some AI features in the EcoFlow app require a premium subscription. Please refer to the app for details on plans and feature availability.
3. The EcoFlow app integrates weather data from Solcast, performing over 100 million data operations per hour to deliver forecasts with up to 94% accuracy and a three-day horizon. (source)
12 payments of £1 99 at 0% interest with Splitit. Learn more
