EcoFlow RIVER 3 Plus (Wireless) Portable Power Station - RIVER 3 Plus (Wireless) / / - EcoFlow UK
EcoFlow UK
12 payments of £20 75 at 0% interest with Splitit. Learn more
Pice Guarantee
Regular price £249.00
Sale price £249.00 Regular price £249.00
Save up to £20.00
Days
Hours
Minutes
Seconds
Up to 47% Off — The Biggest Sale of the Year! Buy Now
  • 286Wh power station + 5000mAh RAPID power bank
  • Highly versatile modular design, simply grab the power bank and go
  • 15W Qi2 wireless charging, 2× faster than Qi1
  • 286Wh capacity, 600W rated output, X-Boost up to 1200W
  • Up to 220W solar input, 0-100% in as fast as 1.5 hr
  • Lightweight, compact and travel-friendly
  • 2×runtime for light-wattage appliances
  • <10 ms UPS for uninterruptible backup
  • <30 dB whisper quiet for 24/7 use
  • Up to 25% solar conversion rate
  • Charge USB devices directly with solar panel
  • DC5521 to XT60i charging cable is included
Note: the power station comes with a 5-year warranty, while the power bank is covered for 2 years.
Model
Extra Battery
£249.00
Versatile, modular design for every situation
On-the-go or home backup—you're covered.
RIVER 3 Plus (Wireless) features a modular design with a detachable RAPID (5000mAh) power bank and expandable capacity with an Extra Battery, ensuring unmatched versatility for all your power needs. Take the power bank on your commute, fishing trips, or hikes, while keeping the power station at home or the campsite. Add the Extra Battery for extended backup, making RIVER 3 Plus (Wireless) your versatile power solution for any situation.
Snap-in charging with a steady hold
Using pogo pin technology, simply insert the power bank into RIVER 3 Plus (Wireless) for fast auto-charging. The secure connection keeps the power bank in place during transport.
Extra wireless charging option
Simply place your iPhone or AirPods on the pad for a hassle-free wireless charging experience while on the go or working remotely.
Revolutionise your magnetic charging experience with RAPID
Faster, easier and safer charging
RAPID uses patented X-Stream technology for flagship smartphone-level energy density and fast charging. Plus, it works with the PD3.0 protocol for flash charging and restoring energy. Paired with Qi2-certified wireless charging and a built-in cable design, RAPID ensures snap-on charging convenience with maximum charging speeds. With a built-in stand, magnetic connection, and temperature protection, RAPID ensures a safe and seamless charging experience.
Twice-as-fast wireless charging
Max-speed charging with a built-in cable
The ultimate fast-recharging power bank
Your reliable companion through outages or in the wild.
Up to 600W output
Expandable up to 858Wh with wireless connectivity
Level up your power with the RIVER 3 Plus (Wireless) and an Extra Battery. Handling either the EB300 (286Wh) or the EB600 (572Wh), just stack them to get up to 858Wh of pure energy.
286Wh
572Wh
858Wh
4 charging options, safely charge 0-100% in 1 hr
0-100% in 1.5 hr
0-100% in 1 hr
0-100% in 3.3 hr
0-100% in 1 hr
Solar Charging: Power up RIVER 3 Plus (Wireless) in as fast as 1.5 hours with 220W solar input. Go more portable with our 45W Portable Solar Panel (Type-C) and charge electronics directly.
AC Charging: RIVER 3 Plus (Wireless) fast-charges in 1 hour with X-Stream, without causing battery damage due to vehicle-grade cells and trickle charge technology.
Car Charging: Charge RIVER 3 Plus (Wireless) using your car battery while you drive, making it an ideal choice for on-the-go.
Generator Charging: Recharge in just 1 hour with a gas generator for a full day of quiet, safe, and efficient power.
Extremely compact and lightweight
Handy, convenient on-the-go power
RIVER 3 Plus (Wireless) minimises heat loss, requires less cooling space, and supports a compact design. It easily fits into small spaces like closets, a minivan, or a bag for easy storage and portability.
<10 ms pro-grade auto-switch
Seamless home office and gaming experience
The RIVER 3 Plus (Wireless) provides premium protection with a <10 ms switchover, safeguarding sensitive equipment for home office and gaming experiences against sudden power loss.
Upgraded smart control
Convenient, intelligent, customised power control
Product Details
RIVER 3 Max (Wireless)
RIVER 3 Max Plus (Wireless)
Specs - RIVER 3 Plus (Wireless)
286Wh
234×232×156 mm
4.7 kg
UPS
<10 ms
Noise Volume
<30 dB
2 ports, 5V⎓2.4A, 12W max per port, total 24W
1 port, 5/9/12/15=3A max, 20V=5A max, 100W max
Car Output
AC Input
200-240V, 6A, 50/60Hz, 360W, 0-100% in 60 min
Solar Input
220W, 11-55V, 13A, 0-100% in as fast as 1.5 hr
Car Input
11-55V, 8A, 220W, 0-100% in 3.3 hr
Generator Input
360W, 200-240V, 6A, 50/60Hz, 0-100% in 60 min
Optimal Operating Temperature
20℃-30℃
Charge Temperature
0℃-45℃
Discharge Temperature
-10℃-45℃
Storage Temperature
-10°C-45°C
5 years
Specs - Power bank
5000mAh
108×70×14.4 mm
180 g
Wireless Charging Output
15W
Wired Charging Output
30W
Recharge Input
30W
2 years
Footnote:
All the test results displayed on the page are based on our internal testing and are subject to different conditions, including temperature variations, humidity levels, and equipment calibration standards. Please note that these results are provided for informational purposes only and should not be considered conclusive evidence for all scenarios. Data was tested in a controlled laboratory environment, and actual user experience may vary.
3. The IP54 waterproof rating applies only to the battery pack, not the entire package. It does not prevent water immersion but can prevent fire or explosion in the event of a short circuit if the battery is splashed with water or rain, ensuring user safety and property protection.
RIVER 3 Plus (Wireless) Portable Power Station Launch Campaign Terms & Conditions
Campaign Duration
RIVER 3 Plus (Wireless) Portable Power Station Launch Campaign runs from 10 June 2025, 8 AM (BST) to 9 July 2025, 8 AM (BST). EcoFlow reserves the right to shorten or extend the campaign period at its sole discretion without prior notice.
Eligibility
The campaign is open to all European citizens aged 18 years old and above as of 10 June 2025, 8 AM (BST).
Availablity
This campaign, including promotions, gifts, and discounts, is exclusively available on uk.ecoflow.com. Purchases made on other platforms or website will not be eligible for campaign offers.
Campaign Details
1. The EcoFlow RIVER 3 Plus (Wireless) Portable Power Station and bundle orders placed between 8 AM (BST) on 10 June 2025 and 8 AM (BST) on 9 July 2025 will receive a free EcoFlow RIVER Series Bag worth €69.
2. Each order is limited to one EcoFlow RIVER Series Bag. When the promotional period ends, the special offer will automatically end without further notice on the website.
3. If a customer wishes to return an order or item that qualified for a gift with purchase, the transaction can only be refunded if the gift with purchase is also returned.No need to proofread or translate this part. We'll reuse the copy from the preheat page.
General:
1. If you encounter any problems during the promotion, please contact support.eu@ecoflow.com for assistance.
2. To the extent permitted by applicable law, we may decide to modify these rules or cancel the promotion at any time. If there is any fraud or abuse related to the promotion, we reserve the right to exclude any customer from the promotion.
3. Participants in the Sale agree to be bound by the terms and conditions set forth herein and understand that EcoFlow's decisions are final and binding. No correspondence or appeals will be entertained. EcoFlow reserves the right to make the final and ultimate interpretation of this campaign.
4. All orders must comply with EcoFlow's purchase agreement and return policy during the sale promotion.
5. The sale promotion does not apply to wholesale or distributor orders.
6. Any unauthorized or fraudulent behaviour will result in the disqualification of participants.
7. Participants must comply with all applicable laws and regulations.
8. EcoFlow reserves the right to stop, cancel, or change the promotion at any time during the promotion. Any changes will be announced on the EcoFlow official website.
9. All prizes in this promotion are limited in quantity and are available on a first-come, first-served basis. Any matters not covered herein will be handled according to EcoFlow's final interpretation.
10. EcoFlow will assume no responsibility for late entries, which may occur for any reason, including but not limited to network transmission failure.
11. EcoFlow will not be responsible for any direct or indirect losses or damages incurred by any party, including the participants, in connection with or arising from acts or omissions or any way related to this campaign.
12. Participants agree to release and discharge EcoFlow from any liabilities and claims, including breach of contract, tort, negligence, or any other cause of action at law or equity, arising out of or in any way connected to this campaign or the participant's entry into the campaign.
13. All productsand free gifts (if applicable) related to this promotion will be shipped in accordance with EcoFlow's Shipping Policy (https://eu.ecoflow.com/policies/shipping-policy).
14. There may be certain orders that we are either unable to accept or must cancel. We reserve the right, at our sole discretion, to refuse or cancel any order for any reason. We are not responsible for inaccuracies or errors.
g-policy).
