RAPID Power Bank: 25,000 mAh + retractable cables | EcoFlow UK - Silver - EcoFlow UK
EcoFlow UK
12 payments of £4 83 at 0% interest with Splitit. Learn more
Pice Guarantee
EcoFlow RAPID Power Bank (25,000mAh, 170W, 100W Built-In and Retractable Cables)
Regular price £57.99
Sale price £57.99 Regular price £109.99
Save up to £52.00
Days
Hours
Minutes
Seconds
Up to 47% Off — The Biggest Sale of the Year! Buy Now
  • 170W Fast Charge: Simultaneous multi-port output up to 170W, supports charging up to four devices at the same time. 100W max for single-port charging.
  • 100W Max Input Power: The power bank can be recharged up to 50% in 26 minutes.
  • 25,000mAh Capacity, Air-Travel-Friendly*: Can fully charge a MacBook, meeting remote work needs for 1-2 days. Can charge your phone 4-5 times, eliminating battery anxiety.
  • Multi-Device Power Bank: 2 × USB-C ports, 1 × 67cm retractable USB-C cable, 1 × 26cm lanyard USB-C cable
  • Smart TFT Screen, Clear and Dynamic Display
* Airline regulations vary by region and carrier. Please confirm battery restrictions with your airline before travel.
Colour
Black
Silver
£57.99 £109.99 -£52.00
Multi-Functional Fast Charging for Everyday Convenience
Premium Fast Charging
Fast Recharging
Multi-Function Power
Premium and Compact Design
Charging with EcoFlow X-Stream Tech
When devices need power, it gets a maximum 100W boost through the USB-C port. With smart distribution, it can deliver power across your laptop, phone, tablet, and earbuds—four devices all at the same time.
100W Recharge in a Flash
Low on power before your commute or flight? This power bank recharges up to 50% in just 26 minutes—perfect for two full phone charges or a quick laptop top-up to last the day.
With 100W USB-C port or cable input:
- Recharge from 0% to 80% capacity (20,000mAh) in 53 minutes
- Recharge from 0% to 100% capacity (25,000mAh) in 80 minutes
Built-in Design, Ready When You Are
No more lost cables—the 100W built-in USB-C retractable and lanyard cables are always there, tucked neatly into the power bank's sleek design, with a retractable mechanism that lets you access power in seconds.
Massive 25,000mAh Capacity in a Compact Size
90Wh air-travel-friendly*, while high-density cells maximise capacity in a travel-ready design.
- Charge a MacBook Pro 1 time, extending battery life by 24 hours
- Charge an iPhone 16 4.6 times, extending battery life by 115 hours
- Charge a Steam Deck 1.75 times, extending battery life by 10 hours
Superior Safety
Smart Screen Display
Universal Compatibility
Advanced Protection, Maximum Performance
Protected by EcoFlow's X-Guard
Features pro-grade battery technology found in electric car batteries. EcoFlow RAPID's Battery Management System continuously monitors the charging process with quadruple protection to prevent overcharging, over-discharging, overheating, and short circuiting, ensuring safe and stable operation.
Smart TFT Screen with a Dynamic Display
Enhance your charging experience with an intelligent power display. You can view your real-time capacity, port power, battery health, temperature, charging cycles,emojis, and more. The crystal-clear TFT display screen lets you check your data at any angle, in any lighting condition.
Compatible with 99% of Daily-use Electronic Devices
Fits in anywhere you go.
Remote Work
Travel
Office Work
Remote Work
Remote Work
Remote Work
Remote Work
Travel
Travel
Travel
Travel
Office Work
Office Work
Office Work
Office Work
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Multi-Port Charging
Single-Port Charging
Two-Port Charging
Three-Port Charging
Four-Port Charging
Specs - EcoFlow RAPID Power Bank (25,000mAh, 170W, 100W Built-In and Retractable Cables)
Total Cell Capacity
25000mAh
Battery Capacity
14500mAh (5V/3A discharge)
157 × 53.8 × 48.8 mm, dimensional tolerance ± 0.5 mm
580 g (approx.)
Appearance
Housing material: black, silver grey
Integrated built-in cable material: braided
Ternary Lithium
300 cycles to 80% capacity
Total Output Ports
1 USB-C port: 100W
1 Retractable cable (USB-C port): 100W
1 Built-in cable (USB-C port): 100W
1 USB-A port: 18W
Total 170W
Built-In Cable Output
Bulit-in C Cable (two-way fast charging 100W): 26 cm
Built-in C retractable cable (two-way fast charging 100W): 67 cm
1 USB-A port: 18W
1 USB-C port: 100W
Input
100W
USB-C Recharge
Multi-port input is not supported, the maximum power of a single port input can reach 100W.
USB-C port/built-in cable/retractable cable: 100W input
USB-A Recharge
APP
Not compatible
Screen
TFT
Drop-resistant
1 m
Fireproof
Housing V0 Fireproof
2 Years
Charge Temperature
20℃–30℃ (68℉–86℉)
Discharge Temperature
0℃–45℃ (32℉–113℉)
Storage Temperature
–10℃–45℃ (14℉–113℉)
Wich devices are compatible?
Compatible devices are laptops, phones, tablets, headphones, smartwatches, game consoles and other devices with USB-C ports such as MacBook Pro/Air, iPhone,iPad, Dell XPS and Samsung Galaxy.
BC1.2/Apple2.4A/QC3.0/FCP/SCP/AFC/UFCS/PD3.0/PPS
How to keep the power bank charging and discharging quickly?
To ensure fast and stable charging and discharging performance when using the power bank, we recommend the following.
1. Choose the Right Charger:
Use a charger that supports fast charging protocols and has a high output power (such as PD 65W or 100W). Avoid using low-power chargers (such as 5V/1A).
2. Use a Good Charging Cable:
Select original or high-quality fast charging cables. Keep connectors clean and secure, and avoid excessively long cables.
3. Device Compatibility:
Make sure the connected devices support fast charging protocols; otherwise, fast charging will not be achieved.
Battery life and temperature FAQs
The power bank retains over 80% of its battery capacity after 300 charge cycles. It supports charging and discharging at altitudes below 3000 meters and in environments with temperatures between 0°C and 40°C. If not used for an extended period, it is recommended to store the power bank in an environment between -20°C and 40°C and to recharge it at least once every three months.
Can the RAPID Pro power bank be taken on the plane?
Yes, according to regulations by the International Civil Aviation Organization (ICAO) and most airlines, carrying a power bank with a capacity under 100Wh is allowed. The RAPID Pro, with a capacity of 25000mAh (90Wh), meets this requirement and can be carried on board without concern.
Why is there a difference rated capacity and nominal capacity?
Nominal capacity refers to the total capacity of the battery cells inside the power bank, while rated capacity refers to the actual amount of power the power bank can deliver under standard output conditions (such as 5V/3A). Nominal capacity is a theoretical value, whereas rated capacity accounts for energy conversion efficiency, circuit losses, and other factors, and is therefore lower than the nominal capacity.
Does it support multi-port charging and discharging at the same time?
Yes. When charging through the USB-C port, output is supported from another USB-C port or one USB-C + USB-A port simultaneously, but not from two USB-C ports simultaneously.
12 payments of £133 25 at 0% interest with Splitit. Learn more
