Portable RV & EV Power with EcoFlow DELTA Pro - RV Power Solution - Overlander Kit - EcoFlow UK
EcoFlow UK
12 payments of £323 91 at 0% interest with Splitit. Learn more
Secure Payments
Multi-channel Support
Pice Guarantee
Regular price £3,887.00
Sale price £3,887.00 Regular price £4,687.00
Save up to £800.00
This item is no longer for sale on EcoFlow official website. We recommend you to check out our DELTA Pro 3 and other promotional items.
· Travel without limits. - Stay powered for up to a week, powering your RV essentials even when boondocking.
· No noise, no fumes, maintenance-free - Experience a clean and silent power source with no noise or fumes.
· Fast charging anytime, anywhere - Fully recharge in 2 hours with MultiCharge.
· Extend EV Range - Go the extra mile even when caught short.
· Charge up at EV stations worldwide - Fully recharged in 1.7 hours(3400W) with industry’s first EV stations charging.
Note:
1. RV power solution: The shore power cable and 230V 16A adapter required to connect the RV power cable to DELTA Pro are not included.
2. EV Backup Charging Solution: Level-2 mobile EV charger not included.
RV&EV Power Solution
What's in the kit
RV Power Solution
Traveller Kit: DELTA Pro + Grounding Adapter
Overlander Kit: DELTA Pro + DELTA Pro Extra Battery + Grounding Adapter
DELTA Pro + Grounding Adapter + EV X-Stream Adapter
Accessories
EV X-Stream Adapter (EcoFlow DELTA Pro)
£89
£89
£89
£3,887.00 £4,687.00 -£800.00
Secure Payments
Escape the grid, embrace the wild without worrying about how much power you've used. With a whopping 3.6-7.2kWh of expandable power, experience the ultimate freedom of off-grid living while powering all of your RV essentials with a clean and quiet energy source. Plus, use DELTA Pro as a mobile EV charger when you're on the road. DELTA Pro is the ultimate, portable power solution for RV road trips and outdoor adventures.
A true adventurer always seeking the next thrill. Connect DELTA Pro with an Extra Battery for a huge capacity of 7.2kWh, and stay powered for up to a week*. Run daily essentials such as a fridge, laptop, coffee maker, and even the air conditioner. You'll have the power to experience all that nature has to offer.
Traveller Kit : 3.6kWh
Starlink Wi-Fi (50W): 72h
Fridge (20W) : 180h
Light (25W): 144h
Laptop (60W) : 60h
Air Conditioner (1200W) : 3h
*The data above is for reference only. Actual run times depends on the individual's RV electricity needs and may vary.
Overlander Kit : 7.2kWh
Starlink Wi-Fi (50W): 144h
Fridge(100W) : 72h
Light (25W): 288h
Laptop (60W) :120h
Coffee Maker(1000W): 7.2h
Air Conditioner (1200W) : 6h
Bid farewell to noisy, fume-filled gas generators and relish peaceful, green, maintenance-free power wherever your RV adventures take you. Charge your RV essentials, or plug into a shore power outlet to directly power your RV's electrical system.
Whether you're on the road, at a campsite, or in your backyard, you're never left without power. Topup using MultiCharge in the time it takes to watch a movie. Fully recharge in only 1.7 hours at an EV charging station (3400W), 1.9 hours with dual AC + solar charging (3000W), 2.7 hours from an AC outlet (1800W), and 3.5 hours using solar (1600W).
Relieve EV range anxiety.
*Miles per kWh for a TESLA MODEL Y: 3.3-3.8 mi/kWh, DELTA Pro (3.6kWh) can extend the range of a MODEL Y approximately 13.68 miles.
Thanks for subscribing!
Explore More
