EcoFlow GLACIER + EcoFlow RIVER 2 Pro - GLACIER + RIVER 2 Pro - EcoFlow UK
EcoFlow UK
12 payments of £141 50 at 0% interest with Splitit. Learn more
Secure Payments
Multi-channel Support
30 Days Price Guarantee
Regular price £1,698
Sale price £1,698 Regular price £1,698
Days
Hours
Minutes
Seconds
Up to 47% Off — The Biggest Sale of the Year! Buy Now
GLACIER:
• Dual zone, dual control
• 38L large capacity
• Detachable suitcase design
• Smart app control
RIVER 2 Pro:
• Fastest Recharge 0-100% in only 70 min.
• Provide up to 1.8kWh a day with solar charging.
• Safest LFP battery provides 10 years of use.
• X-Boost output to 1600W and run 80% of high-wattage appliances.
Accessories
£1,698
Secure Payments
An astonishing 98-hour run time under GLACIER's Eco mode with
EcoFlow RIVER 2 Pro and the Plug-in Battery connected!
Fresh food and cold sodas within reach for more than 4 days.
Whether you're in an SUV, pick-up truck, RV, or tent, you can never get hangry!
Industry's first integrated ice maker.
120W compressor
Equipped with a powerful 120W compressor, it brings you 18 solid ice cubes in 12 minutes*. For all the spine-tingling moments along your journey, spice them up with chilled sodas.
* The test result was gained with the ambient temperature of 25°C and water temperature of 15°C. The first round of ice making might take longer than 12 minutes.
A fridge-freezer at its best.
Dual zone, dual control.
Equipped with a removable divider separating it into two zones, and independent temperature control,
both sections can refrigerate and freeze from 10°C to -25°C.
Steak, cheese, or soft drinks......whatever you want to stock up on, it shape-shifts to meet your needs.
The fastest cooling in the industry.
Cooling at the optimum speed when empty, GLACIER rapidly refrigerates from 30°C to 0°C in around 15 minutes.
Cooling for up to 40 hours wire-free.
298Wh plug-in battery
Designed for absolute portability, GLACIER can be powered by the Plug-in Battery* and free from messy, limiting cables.
With a large battery capacity of 298Wh, savor up to 40 hours* of easy access to frozen meals, fresh fruit, and ice-cold beverages.
* Plug-in Battery is sold separately.
* The test result was gained with the fridge empty, its temperature set to 39℉ (4°C), and the ambient temperature of 25°C.
Charge laptops and more on the go.
100W max USB-C
With 100W max USB-C charging, it even powers up your phones and laptops so you'll never lose touch with your loved ones.
Fastest charging speeds ever.
Charge 0-100% in 70 min
RIVER 2 Pro beats the industry charging speed standard, fully charging in only 70 minutes.
That's 5x faster than other portable power stations on the market and 27% quicker than previous generations.
Fully charge RIVER 2 Pro while you pack your bags, so you'll always be ready for a last-minute trip.
LiFePO4 Battery Chemistry
With upgraded long-lasting LFP battery chemistry at its core, charge and empty RIVER 2 Series over 3000 times.
That's pretty much 10 years of everyday use* and 6x longer than the industry average.
With LFP cells, the RIVER 2 Series is safe, durable, and highly efficient, even in warm temperatures.
*Using RIVER 2 Pro six times a week, 3000 full 100% cycles will last 9.6 years until it drops to 80%.
Small size. Big power.
X-Boost Up to 1600W
RIVER 2 Pro has an AC output of up to 800W.
Need to power a hair dryer, microwave or electric kettle?
Crank it up to 1600W with X-Boost mode to run up to 80% of high-wattage appliances.
Charge Anywhere.
Take Charge With Solar
RIVER 2 Pro Solar Generator produces up to 1.8kWh daily, which means sufficient power to run your essential appliances smoothly for almost half a day.
Sudden power outages? You'll always be ready.
Using RIVER 2 Pro Solar Generator every day decreases your whole-year
carbon emissions by about 143kg. That's like planting 8 trees in a year!*
*Based on an average carbon emission of 0.371kg/kWh and an average sunshine duration of 6 hours/day.
Specs of GLACIER
AC Input
100-240V, 50/60Hz, 180W
Solar Charging Input
240W (11-60V, 13A Max)
Car Charging Input
192W (12/24V, 8A Max)
Battery Pack Power
100W (USB-C)
Operational Volume
Single zone: 38L (40 qt.); Dual zone: 36L (38 qt.)
23 kg
Dimensions (wheels and handles not included)
776 × 385 × 445 mm
IP Rating
IPX4
Refrigeration Temperature Range
–25°C to 10°C (–13°F-50°F) (ambient temperature at 25°C)
Noise Level (stable operation)
Ice making: <52dB; Refrigeration: <42dB
Refrigerant type/Amount
R600a, 32 g
Quick Freezing Mode (30℃ to 0℃)
15 minutes
Refrigeration Power Rating
120W
Bluetooth
Wi-Fi
This product supports 2.4G Wi-Fi only
Specs of RIVER 2 Pro
768Wh
Approximately 7.8 kg
Dimensions (L × W × H)
270 mm × 260 mm x 226 mm
AC Input
220-240V ~50Hz/60Hz, 870W Max
Solar Input
11-50V 13A, 220W Max
USB-C Input/Output
5/9/12/15/20V 5A, 100W Max
DC Output
12.6V, 10A/3A/3A, 126W Max
5V, 2.4A, 12W Max
Pure Sine Wave, 800W total (surge 1600W), 230V ~50Hz/60Hz
Charge Temperature
0°C to 45°C
Storage Temperature
-10°C to 45°C (ideally 20°C to 30°C)
DC5521 Output
12.6V, 3A, 36W Max
Cell Chemistry
Discharge Temperature
-10°C to 45°C
Optimal Operating Temperature
20°C to 30°C
Car Input
12V/24V, 8A, 100W Max
App Control
Wi-Fi, Bluetooth
