Powerful Yet Simple: DELTA Pro 3 | EcoFlow UK - DELTA Pro 3 + 220W Portable Solar Panel - EcoFlow UK
EcoFlow UK
12 payments of £233 25 at 0% interest with Splitit. Learn more
30 Days Price Guarantee
Regular price £2,799.00
Sale price £2,799.00 Regular price £3,148.00
Save up to £680.00
Days
Hours
Minutes
Seconds
Up to 47% Off — The Biggest Sale of the Year! Buy Now
  • Powerful for Families: 4000W output to power high‑demand appliances from washing machines to EV chargers. X‑Boost surges to 6000W when needed.
  • Expandable Up to 12kWh: Scales from 4 to 12kWh as your energy needs grow.
  • Whisper‑Quiet Comfort: 30 dB at 2000W—quieter than a running refrigerator.
  • Store Solar, Slash Bills: With up to 2600W solar input, store excess by day and power your EV overnight—save up to £1,314/year.*
  • Blackout Guardian: 10 ms switchover keeps fridge, lights, and essentials running.
  • 6‑Way Rapid Charging: 0–80% in one hour, or solar charge to 80% in 1.5 hours.
  • Easy Setup & Portability: Plug‑and‑play design for homes, RVs, and off‑grid cabins.
* See below for calculation details.
Note: The Solar Panel Mounting Feets are not included.
Important: The Manual Transfer Switch requires professional installation by a certified electrician. All associated installation costs are to be covered by the purchaser, who is responsible for securing a qualified electrician in their area. Click to read the Instruction Leaflet of the Manual Transfer Switch.
£329
Charge while you drive
Stay powered up on the road
£2,799.00 £3,148.00 -£349.00
The Most Portable Home Solar Battery¹
Energise Every Moment That Needs Electricity
Multiple Devices
ON‑site DIY Project
EV Charging
Whole‑home Use
Off‑grid Cabin
RV Use
Flexibly Connect EcoFlow DELTA Pro 3 to Your Home
Manual Transfer Switch*
The Manual Transfer Switch⁷ lets you easily switch between grid power and a portable power station anytime.
*The setup requires a licensed electrician or a qualified professional.
Instruction Leaflet
Seamless Whole-Home Backup
Connect EcoFlow DELTA Pro 3 directly to your home's circuits. Switch effortlessly between grid and battery power to reduce bills or stay powered during outages. Keep everything running — from the fridge to the Wi‑Fi — even when the grid goes down.
Expandable Capacity for Longer Runtime & Bigger Savings
Connect in parallel to expand capacity up to 12kWh. Run appliances longer, store more solar, and cut your energy bills. More capacity means more backup, more savings, and fewer disruptions.
Quiet Comfort for Your Family and Neighbours
Silent as a Whisper
Seamless Power Backup
With X-Quiet technology, it operates as low as 30 dB under 2000W — quiet enough to run beside your bed without disturbing your sleep.
Protect your data and devices with a rapid 10 ms switchover. Keep NAS systems, servers, and home entertainment running smoothly through any outage.
6 Unique Ways to Charge — Anytime, Anywhere³
Charge Fast, Everwhere³
Introducing EcoFlow's groundbreaking X-Stream fast charging technology, setting a new industry standard. Charge from 0-80% in just one hour.
With multi-charge combinations, enjoy up to 7000W of super-fast charging.
State-of-the-art LFP Tech
BMS powered by
ground-breaking X-Guard
Revolutionising Durable Construction
5 Years Warranty, Zero Worries
Crafted with automotive-grade LFP cells, the EcoFlow DELTA Pro 3 features the industry's first IP65-rated battery pack, ensuring resilience against impacts, water, dust, and fire risks. With 4000 cycles to 80%, that's power every day for 11 years*.
Experience dependable performance in any weather, ensuring peace of mind in every situation.
*Tested under controlled laboratory conditions with charging and discharging at 0.5C rate under 25℃ conditions
Trust the Battery Management System powered by X-Guard to monitor your battery's 40 safety indicators 24/7, providing warnings and active protection around the clock. Manage it all through the app for smart, secure energy.
Our pioneering Cell-to-Chassis (CTC) integration fortifies the EcoFlow DELTA Pro 3. This design, combined with a UL-certified 5VA grade fireproof shell, redefines industry standards for resilience and protection.
Outlasting and outperforming, we offer a 5-year warranty across the board, surpassing traditional gas generators and aligning with the elite in portable power. Experience streamlined support from our customer service, ensuring swift solutions and minimal downtime. It's our commitment to quality, redefined.
Effortless All-in-One Command with the EcoFlow App
What's in the box - EcoFlow DELTA Pro 3
EcoFlow AC Charging Cable
Grip Protector
Grip Protector
Quick Start Guide
Quick Start Guide
Safety Guide
Safety Guide
Warranty Card
Warranty Card
What's in the box - EcoFlow DELTA Pro 3 Smart Extra Battery
EcoFlow Extra Battery Flat Link Cable (0.85 m)
Quick Start Guide
Quick Start Guide
Safety Guide
Safety Guide
Warranty Card
Warranty Card
Specs - EcoFlow DELTA Pro 3
4096Wh
5 outlets, 4000W max. (Surge 8000W)
USB-A Fast Charge
USB-A×2, 5V 2.4A 9V 2A 12V 1.5A 18W max
12V DC Output
12.6V/30A 378W total
DC5521 × 1, 5A max.
Anderson Port × 1, 30A max.
Solar Charging Input
2600W, 2 ports:
HPV: 30-150V/15A, 1600W max.
LPV: 11-60V/20A, 1000W max.
Connection
Wi-Fi 2.4GHz/Bluetooth/CAN
693×341×410 mm
4000W, 6000W (X-Boost)
Supports up to two DELTA Pro 3 Smart Extra Batteries / DELTA Pro Smart Extra Batteries
6000W
USB-C × 2, 5/9/12/15/20V 5A 100W max.
AC Charging Input
200-240V~12.5A,50/60HZ
2900W max.
Car Charging Input
12V 8A max.
48V 20A max.
4000 cycles to 80% capacity
51.5 kg (113.54 lb)
Specs - EcoFlow DELTA Pro 3 Smart Extra Battery
4096Wh
Output Port
40V-58.4V=100A Max
Weight
33 kg
Compatible with
EcoFlow DELTA Pro 3
Discharge Temperature
-10°C ~ 45°C
Storage Temperature
-10°C ~ 45°C
Input Port
40V-58.4V=80A Max
Dimension
694mm×295mm×215mm
What’s in the box
1. EcoFlow Delta Pro 3 Smart Extra Battery
2. Quick Start Guide
3. Safety Guide
4. Warranty Card
5. EcoFlow Extra Battery Cable
Dispaly
LED Array
Charge Temperature
0°C ~ 45°C
DELTA Pro vs. DELTA Pro 3
Compared to the DELTA Pro, the DELTA Pro 3 is much quieter, has more capacity, higher charging efficiency, greater portability, and a space-saving Extra Battery design.
EcoFlow DELTA Pro 3 has two PV input ports, which are for high-voltage PV port and low-voltage PV, respectively.
High-voltage PV: 30-150V, 15A Max, 1600W Max. Low-voltage PV: 11-60V, 20A Max, 1000W Max.
Can EcoFlow DELTA Pro 3 be used with an EV charger?
Yes, it supports Level 1/2 EV chargers. You will need to purchase a dedicated EcoFlow adapter, the EV X-Stream Adapter (DELTA Pro Ultra).
Typyically, the grid charging port on the US model only supports AC 120V 2000W charging (Level 1). However, by using the AC POWER IN/OUT port along with the EV X-Stream Adapter (DELTA Pro Ultra), you can connect a 240V EV charger, increasing the charging rate to 4000W (Level 2).
If connected to solar panels, will EcoFlow DELTA Pro 3 automatically turn on while turned off?
Yes, however, there are specific requirements for the light conditions.
In weak lighting environments, it might not trigger the device to power on.
EcoFlow Smart Generator (Dual Fuel)
EcoFlow DELTA Pro to Smart Generator Adapter
EcoFlow PowerInsight Home Energy Manager
EcoFlow WAVE 2
Which EcoFlow products are compatible with EcoFlow DELTA Pro 3? (EcoFlow DELTA Pro Series)
How long is the cycle life of EcoFlow DELTA Pro 3?
4000 cycles. After 4000 cycles at a rate of 0.5C/0.5C at 25°C, the battery maintains over 80% of its state of health (SoH).
Optimal operating temperature: 20°C-30°C
Charging temperature range: 0℃-45℃
Discharge temperature range: –10℃-45℃
Recommended long-term storage temperature: 20℃-30℃
As the core component of the device, the safety and protection level of the battery pack is crucial. To better protect the battery pack and reduce the risk of short circuits and fires caused by water ingress, the EcoFlow DELTA Pro 3 battery pack is sealed. It has reached an IP65 waterproof and dustproof rating, effectively preventing dust from entering and resisting water spray.
However, the EcoFlow DELTA Pro 3 main unit does not have a waterproof and dustproof rating (IP20). The device is suitable for use in well-ventilated indoor environments or sheltered outdoor environments to avoid the impact of rain and dust on the device.
Please ensure that the surrounding environment is dry and clean during installation and use to ensure the device's normal operation and longevity.
EcoFlow DELTA Pro 3 is equipped with an internal GFCI ground circuit. Users can connect an external GFCI protector according to their needs.
When an external GFCI protector is connected to EcoFlow DELTA Pro 3, the GFCI support switch must be turned on in the app for the external GFCI protector to function properly.
Is the EcoFlow DELTA Pro 3 Extra Battery compatible with the EcoFlow DELTA Pro?
No, it is not supported.
Is the EcoFlow DELTA Pro Smart Extra Battery compatible with the EcoFlow DELTA Pro 3?
Yes, it is supported. Please note that all devices need to be upgraded to the latest firmware version to ensure compatibility.
Can the EcoFlow DELTA Pro 3 main unit be used with the EcoFlow DELTA Pro main unit?
Can the EcoFlow DELTA Pro 3 Smart Extra Battery and the EcoFlow DELTA Pro Smart Extra Battery be mixed and plugged into the EcoFlow DELTA Pro 3?
Supported. However, due to the different capacities of the EcoFlow DELTA Pro Extra Battery and the EcoFlow DELTA Pro 3 Extra Battery, there will be some SOC imbalance.
What is a Manual Transfer Switch?
A Manual Transfer Switch allows you to safely connect a portable power station to your home's electrical system at any time.
Can I install a Manual Transfer Switch myself?
Installation should be done by a licensed electrician or a qualified professional.
What is the warranty for the Manual Transfer Switch?
1 year.
How do I test the Manual Transfer Switch to make sure it is working properly?
You should consult with a licensed electrician to perform a load test to ensure it is working properly and all circuits are properly connected.
EcoFlow DELTA Pro 3 Compatiblity*
*Please note that EcoFlow DELTA Pro 3 is not compatible with EcoFlow DELTA Pro.
*Annual Energy Savings = Daily Energy Savings x 365 days
**Annual electricity savings = Annual Energy Savings x €0.35 per kWh
Note: This calculation assumes solar energy is sufficient to fully charge the DELTA Pro 3 (or DELTA Pro 3 with additional battery pack) each day. Actual savings may vary based on local solar irradiation levels. A regiona analysis is recommended for a more accurate estimate.
1. Unless stated, claims compare EcoFlow product series.
2. Availability is limited to official direct channels and authorised distributors.
3. Actual availability may vary depending on local laws and regulations, environmental conditions, network or service availability, and device compatibility.
4. Time to charge up to 80%.
5. Time to charge up to 100%.
6. Microinverter: 800W, DELTA Pro 3: 4000W output.
7. Installation requires a licensed electrician or qualified professional. Instruction Leaflet
8. Tested under controlled laboratory conditions with charging and discharging at 0.5C rate under 25°C conditions
