EcoFlow DELTA 2 Max Solar Generator (PV220W) - EcoFlow UK
EcoFlow UK
Pice Guarantee
Bank Holiday🎵
Expandable capacity: 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit 6144Wh. Ideal for home backup, caravanning, outdoors or even everyday use.
Built to last 6× longer: Get 10 years of daily use until hitting 80% of its original capacity. That's down to its LFP battery chemistry giving you 3000 cycles.
Huge AC output: With X-Boost mode, get up to 3100W output power to run 99% of home appliances. Power 13 devices at once, including 4 AC outlets.
Fastest recharging: World's fastest AC recharging and X-Stream dual AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours.
Capture more energy: 99% MPPT efficiency maximises solar generation during the daytime.
High conversion efficiency rating: guarantees a faster solar charging speed. 0-100% in 2.3 hours (4 sets), 3.1 hours (3 sets).
Customised in-app energy management: Prioritise solar or AC charging, view input and output power, battery levels and more.
5-year warranty: 5 years for DELTA 2 Max, 24 months for 220W Solar Panel.
£1,897.00
PayPal
10-year long-lasting LFP battery
Durable, Safe, Lightweight
With its upgraded LFP battery chemistry, DELTA 2 Max has a lifespan of 3000 complete cycles until it reduces to 80% capacity. You'll get pretty much 10 years of power, even if you use it every day.
LFP Battery Chemistry
That's 6× longer than other power stations with a similar capacity and output.
Advanced BMS Protection
Robust Design
Upgraded Tech, Lighter Weight
Even with its upgraded LFP battery, DELTA 2 Max is still 30% lighter than similar 2kWh LFP power stations on the market.
Power pretty much anything with up to 3100W output.
DELTA 2 Max powers almost all the devices you need with a large 2400W AC output. Plus, with X-Boost proprietary technology, run appliances with an output of up to 3100W. Compared with other power stations, DELTA 2 Max can power more devices, while still preventing overloading and overheating.
Experience the world's fastest 43 minute recharge.
80% in 43 Min*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 53 mins.
*When combined solar and AC input is 2400W.
Solar Charging Times
880W Charge approx. 2.6 hours
800W Charge approx. 2.8 hours
Two in One Bifacial Design.
Capture more energy
With a 220W primary side, and a 155W side on the back for ambient light, you can capture up to 25% more solar energy and charge your portable power station even faster.
A conversion rate of up to 23% guarantees fast solar charging speeds: 0-100% in 2.9 hours (4 sets) 3.9 hours (3 sets) and 5.8 hours (2 sets).
The thin, one-piece tempered glass design of the 220W Bifacial Portable Solar Panel makes it five times tougher than comparable panels with half the thickness of traditional tempered glass. Capable of withstanding heat up to 149°C, it's safe to say it can resist the elements.
6kWh Expandable Design
Triple the Capacity
Take control of your power.
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Experience peace of mind during power cuts
With our all-new AC Always On Mode, the AC power button stays on, even during a power cut or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust power
Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings. Prioritise solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
Always power ready
Comprehensive warranties
With one of the most comprehensive warranties in the industry, we go the extra mile to give you peace of mind with 5 years for DELTA 2 Max and 24 months for 220W Solar Panel.
What's in the box - Delta 2 Max
1.DELTA 2 Max 2. AC Charging Cable 3. User manual & warranty card
What's in the box - 220W Bifacial Portable Solar Panel
1. 220W Bifacial Solar Panel 2. 220W Bifacial Solar Panel Protective Case (Kickstand) 3. Solar to XT60 Charging Cable 4. 220W Bifacial Solar Panel User Manual and Warranty Card 4. Snap Hooks
Thanks for subscribing!
Explore More
