12 payments of £14 08 at 0% interest with Splitit. Learn more
Capture More Energy with a Bifacial Design
With primary and rear-side panels for ambient light, output power reaches up to 177W under BNPI test conditions, generating more power from the same amount of sunlight compared to traditional monofacial panels. With industry-leading TOPCon solar technology, the portable solar panel achieves a top-level conversion rate of up to 25%, recharging your power station even faster.
Ultra-Portable Design
Engineered with advanced lightweight materials, this next-gen solar panel weighs 1.8kg lighter than previous models for effortless transport and compact storage.
Built-in XT60
The integrated XT60 cable makes it easier to store and connect to portable power stations for a faster setup.
Suitable for Various Environments
The folding integrated bracket offers a convenient and compact design. Adjustable from 30°-60°, it's ideal even for most high-latitude areas.
* If you need to hang solar panels for extended periods, please use rigid solar panels. Lightweight portable solar panels are not recommended for this scenario.
Integrated Solar Angle Guide
Keep sunlight at a 90° angle and concentrate the sun's rays onto the surface of your solar panel to get the most light at all times.
Durable and Water-Resistant
5-Year Warranty
Rated Power
STC 160W (±5W) / BNPI 177W (±5W)
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
≥25%
Weight (Solar Panel)
3.8kg±0.3kg
Unfolded: 1677mm*598mm*26mm (handle incl.)
Folded: 609mm*598mm*26mm (handle incl.)
Connector Type
XT60I-F
5 years
Open Circuit Voltage
21.4V(Vmp18.8V)
Short Circuit Current
STC 9.2A
BNPI 10.2A(Imp STC 8.7A BNPI 9.6A)
Waterproof & Dustproof
1. EcoFlow 160W Lightweight Portable Solar Panel
2. Quick Start Guide, Safety Instructions, and Warranty Card
