EcoFlow STREAM Balcony Kit | EcoFlow UK - Lattice Balcony / (800Wp) 2 × 400W Rigid Solar Panel + STREAM Microinverter / Bracket: Lattice Balcony - EcoFlow UK
EcoFlow UK
£499.00
Regular price £499.00
Sale price £499.00 Regular price £599.00
Save up to £330.00
  • Saves you up to £115 on electricity bills
  • Compatible with 99% of solar panels on the market
  • Performs exceptionally even in low-light conditions
  • AI-powered experience with the EcoFlow app for smart monitoring and control
Balcony Type You Want to Install It on
Bundle You Would Like to Choose
Your Bracket Options:
EcoFlow STREAM AC Pro/AC
£699 £799
EcoFlow Smart Meter
£99
Precise energy allocation
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£699 £799
EcoFlow Smart Meter
£99
£499 £599 -£100
Cut Bills up to £115
The EcoFlow STREAM Solar System seamlessly integrates solar panels with a microinverter, converting sunlight into ready-to-use electricity for your home.It can power your Wi-Fi router, refrigerator, TV, and radio during the day. Capable of generating up to 858 kWh annually, this system can help you save up to £115 per year on energy costs.
Power Your Home Even in Low Light
Dawn to Dusk, Rain or Shine
The EcoFlow STREAM Balcony Solar System excels even in low light. The microinverter activates with just 3W of solar input, ensuring a steady power supply to your home, even during early morning or dusk hours.*
Control Energy Efficiently to Achieve 0 Electricity Bill
EcoFlow App – Now Smarter with Eco-AI
Powered by Al, the EcoFlow app offers smart energy management like never before when EcoFlow STREAM Series Solar Plant is connected. Al-TOU Mode maximises bill savings by analysing grid and solar data, while the Al Assistant gives you 24/7 control with one tap. Customise energy routines and control appliances remotely, whether you're home or away.
Seamless Smart Home Integration
Effortlessly connect with multiple third-party smart meters and digital energy platforms for real-time monitoring of your home’s energy usage via the EcoFlow app.
Your 24/7 AI Energy Assistant: Smarter, Simpler Power
One-step Portal for Total Control.
Flexible DIY Solar Panels to Capture Every Watt
Multiple Solar Brackets for Easy Balcony Installation
Specs - Input
MPPT Channels:
2
Max Input Power per Channel:
600W
Max Input Voltage:
65V DC
Start-up Voltage:
20V
MPPT Voltage Range:
16-60V DC
Max Current per MPPT:
16A
Short-Circuit Current per MPPT
16A
Specs - Output
Rated Grid Output Power:
800VA
Max Grid Output Current:
3.48A
Rated Voltage:
230VAC
Voltage Range:
183-276VAC
Frequency Range:
45-55 Hz / 55-65 Hz
Specs - General
Operating Temperature:
-40°C to 65°C
Weight:
3.2 kg
Dimensions:
252 × 180 × 35 mm
Protection Rating:
IP67
Warranty:
10 years
Is elevated temperature during operation normal?
A moderate temperature increase during operation is normal and will not impact product longevity. The system undergoes rigorous testing and incorporates a multi-stage thermal management system. For safety and performance, install the unit in a well-ventilated, non-sun-exposed area, away from children/pets.
How to monitor the electricity generated by the STREAM Microinverter in real time?
Can I use third-party solar panels?
Yes, third-party solar panels are compatible if they meet the PV input specifications and use MC4 connectors. The input range per PV port is:Operating Voltage: 16-60VOperating Current: ≤16A
How should I connect multiple solar panels to my STREAM Microinverter?
When connecting multiple solar panels in series or parallel, ensure that the maximum operating voltage (V) and maximum operating current (I) of each panel group do not exceed the limits of a single PV port on the STREAM Microinverter:Maximum Operating Voltage: 60VMaximum Operating Current: 16AIf you require extension or parallel cables for solar panels, they can be purchased separately from EcoFlow.Additionally, each group of solar panels connected in series or parallel must have consistent Maximum Operating Voltage (V) and Maximum Operating Current (I).Typical compatible solar panel specifications per PV port group: 200W-600W.
Can EcoFlow’s Portable Power Stations be used in a system with the STREAM Microinverter?
The STREAM Microinverter is exclusively compatible with products from the STREAM series. For a more intelligent and higher-yield system experience, we recommend purchasing additional STREAM series products.
Will excess power generated by the STREAM Microinverter (when PV generation exceeds household grid consumption) be fed into the grid?
If your system consists solely of the STREAM Microinverter, excess solar power will be fed into the grid.
Does the STREAM Microinverter require separate grounding?
EcoFlow provides AC cables with an equipment grounding conductor/grounding plug. If the cable is plugged into a socket that is properly installed and grounded according to all local codes and regulations, the device will be correctly grounded.If you are unsure about the socket’s grounding status or if local regulations mandate specific grounding standards, contact a qualified electrician to establish proper grounding via the product’s grounding terminal. For detailed procedures, contact EcoFlow technical support.
Can I install the STREAM Microinverter myself?
The system can be installed and maintained by users themselves. However, if you are in the UK, due to local regulations, the BKW DIY cable used with the Stream Microinverter must be connected to the distribution board. This operation requires a professional installer or electrician.
Can I install the STREAM Microinverter on a solar panel instead of a wall?
Yes. You can purchase the PV Clamp Holder to install the STREAM Microinverter on rigid solar panels with a thickness of 30mm-35mm.
How does the system continue supplying power during a blackout?
For safety reasons, the STREAM Microinverter will automatically detect grid power anomalies and stop power output during a blackout.
Can the AC output cable plug be connected to a power strip?
Due to safety regulations, this is not recommended.
Can multiple STREAM Microinverters be used simultaneously?
It is advised to purchase or use them in compliance with local laws and regulations.
Is the STREAM Microinverter waterproof and dustproof?
The STREAM Microinverter has an IP67 rating and can be used indoors/outdoors. We recommend installing it in a well-ventilated, shaded, and cool location.
Can the STREAM Microinverter connect to 5G WiFi?
Currently, it only supports 2.4GHz WiFi.
Can the maximum output power of the STREAM Microinverter be adjusted?
Yes, it can be configured via the EcoFlow app. Path: Space > Settings > Maximum Output Power.
Why is there no power output after connecting solar panels and AC output cables to the STREAM Microinverter?
Please scan the app QR code in the Quick Start Guide or click to download the EcoFlow app to activate and bind the device. [Download]
*The warranty for the STREAM Microinverter lasts for 10 years.
*EcoFlow STREAM Solar System generates 858kWh of solar energy annually. Based on Germany's average household consumption (3,113kWh/year) and the electricity price of £ 0.33/kWh, this results in annual savings of £115. Actual savings may vary depending on consumption patterns and local energy rates.
source :https://pvwatts.nrel.gov/pvwatts.php
*Certain AI features in the EcoFlow app require a premium subscription. Please refer to the EcoFlow APP for details on subscription plans and feature availability.
*The AI-TOU and AI Power Prediction features require connectivity to the EcoFlow STREAM Series Solar Plant. Certain AI functionalities are available through premium subscriptions. For detailed specifications and pricing, please visit the EcoFlow APP.
Customer Reviews
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
