EcoFlow DELTA + 110W Solar Panel
100% secure shopping
Reliable warranty
Free shipping
Regular price
£1,799.00
Sale
£1,799.00
Regular price
£1,937.00
Sold out
per
33 Reviews
As low as $88/mo or 0% APR.
Socket Type
  • UK (Compatible with UK sockets only)
Number of Solar Panels
  • 1
  • 2
  • 3
  • 4
View cart
Huge 1260Wh capacity for power outages. With a huge 1260Wh capacity and 4 AC outputs, the EcoFlow DELTA provides reliable home backup power during any emergency or power outage.
Charge from 0-80% within 1 hour. The EcoFlow DELTA charges from 0-80% within 1 hour, faster than any other battery generator on the market.
Charge up with 110W of solar power. If you’re going off-grid or looking for another backup power source, use EcoFlow 110W solar panels to fully charge the EcoFlow DELTA.
Power 11 devices at the same time. The EcoFlow DELTA can power up to 11 devices at the same time, giving you one convenient space to power your phones, laptops, and other devices.
Customer reviews
4.0 563 Reviews
  • 5 star
    75%
  • 4 star
    60%
  • 3 star
    10%
  • 2 star
    8%
  • 1 star
    1%
Reliable warranty
Free shipping
EcoFlow DELTA is a battery generator designed so you can take power anywhere. With a huge 1260Wh capacity you’ll be ready for blackouts, camping, or even DIY work with a hefty 1800W output.
1260Wh capacity
Fast charging
4 x AC Outlets (Pure Sine Wave)
Power 11 devices simultaneously
Stay in charge with a portable power station.
The EcoFlow DELTA + 110W Solar Panel gives you convenient power at any time of the day. From power outages to off-grid living, stay in charge of any situation with clean solar generation.
Charge up in one hour.
EcoFlow portable power stations are the fastest charging on the market. The EcoFlow DELTA charges up from 0-80% in one hour, reaching a full charge in just 1.6 hours.
Solar panels for home or away.
Connect up to 4x 110W solar panels to the EcoFlow DELTA to fully charge up in just 4 hours. Perfect for home backup, off-grid living, or if you fancy a cleaner way to stay powered on.
Portable solar power.
The EcoFlow 110W solar panel is portable, lightweight, and doubles up as a kickstand. It’s also waterproof and durable, perfect for your next camping trip.
Smart solar generation.
All EcoFlow solar panels come with premium monocrystalline silicon cells that provide a high efficiency rating of 22%. In other words, that’s more power and more efficient solar charging throughout the day.
Compare The Models
DELTA + 1x 110W Solar Panel
Charging time: 14-28 hours
DELTA + 2x 110W Solar Panel
Charging time: 7-14 hours
Learn more
DELTA + 3x 110W Solar Panel
Charging time: 5-10 hours
Learn more
Under perfect sunlight conditions, DELTA can be fully charged with the following solar panel setups: 1x 110W solar panel: 14h-28h; 2x 110W solar panel (in series): 7h-14h; 3x 110W solar panel (in series): 5h-10h; 4x 110W solar panel (Solar Parallel Connection Cable required): 4-8h
Use the MC4 to XT60 solar cable (comes with every DELTA purchase) to connect the solar panel to DELTA.
Approximately 4 kg.
DELTA can power essential devices whether you’re at home or outdoors. Devices include lights, microwave ovens, fridges, hairdyers, laptops, phones, electric frying pans, and more.
If you’re looking for more portable power options for home emergencies, off-grid adventures, or you prefer to generate clean power, this is a reliable solar generator bundle that will give you peace of mind in any situation.
Specs (DELTA)
Net Weight *
30.9 lbs (14 kg)
Dimension *
15.7 x 8.3 x 10.6 in (40 x 21 x 27 cm)
Charge Temperature
32 to 113°F ± 5°F (0 to 45°C ± 3°C)
Discharge Temperature
-4 to 113°F ± 5°F (-20 to 45°C ± 3°C)
1260Wh
800 Cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Full Recharge Time
1.6 Hours (AC) 13.5 Hours (12V Car Charger) 4-8 Hours (Using 4x 110W Solar Panels in parallel) 3.5-7 Hours (Using 3x 160W Solar Panels)
Charge Method
AC Wall Outlet, 12V/24V Car Charger, Solar Panel
AC Charge Input Power
X-Stream Charge 1200W Max
AC Charge Input Voltage
220-240Vac (50Hz/60Hz)
Solar Charge Input
400W 10-65V DC 10A max
Car Charger Input
12V/24V DC 8A max
AC Output (x2)
1800W (Surge 3300W) total, 230Vac (50Hz/60Hz)
USB-C Output (x2)
5V DC, 9V DC, 15V DC, 20V DC, 3A, 60W Max, per port
USB-A Output (x2)
5V DC,2.4A,12W Max, per port
USB-A Fast Charge (x2)
5V/2.4A,9V/2A,12V/1.5A 18W Max
Car Power Output (x1)
108.8W, 13.6V DC, 8A max
Cell Chemistry
Lithium-ion
Cell Type
18650
Shelf Life
1 year (after fully charging the device)
Testing and certification
UL CE FCC RoHS RCM PSE
24 months
Specs (110W Solar Panel)
Unfolded Dimensions
20.2 x 62.5 x 1.0 in (51.4 x 158 x 2.4 cm)
Folded Dimensions
20.2 x 16.5 x 1.0 in (51.4 x 42 x 2.4 cm)
Weight
13.2 lb (6 kg) Solar Panel 8.8 lb (4 kg)
12 months
Rated Power
110W (±5W)
Efficiency
21%–22%
Connector Type
MC4
Open Circuit Voltage
21.7V (Vmp 18.5V)
Short Circuit Current
6.3A (Imp 6.0A)
Operating & Storage Temperature
-4° F to 185° F (-20° C to 85° C)
Cell Type
Monocrystalline Silicon
