EcoFlow DELTA Pro Solar Generator (Rigid PV400W*2) - 2 / Without Extra Battery - EcoFlow UK
EcoFlow UK
£2,868.00
Regular price £2,868.00
Sale price £2,868.00 Regular price £3,038.00
Save up to £1,140.00
Secure your power supply with an EcoFlow DELTA Pro solar generator. Plug in 400W Rigid Solar Panels and get up to 1600W input to charge from anywhere in as fast as 1.5 hours.
The Portable & Expandable Home Battery - DELTA Pro supports a 3.6kWh capacity that can be expanded to 25kWh. The kicker? You can integrate it directly with your home circuits via the Smart Home Panel. Ideal for home backup.
Rapid Dual Charging - X-Stream tech means that DELTA Pro charges 7 times faster than the competition. That's 0–80% in just 50 minutes and 0-100% in 80 minutes with AC input. Plug in EcoFlow solar panels and charge in as fast as 2.8 hours with 4 x 400W rigid solar panels.
Fast Charging - With a high conversion efficiency rate of up to 23%, the 400W panel charges your LFP batteries faster than similar-sized solar panels.
Weatherproof & Durable - The rigid panel balances design with robust materials allowing the panel to weather any storm while offering the same excellent performance and aesthetics for years.
Off & On-grid Solution - This high-wattage panel works for both on-grid and off-grid solar-powered setups, storing energy for outages, reducing power bills, or powering an off-grid home.
Universally Compatible - The 400W solar panel includes a 300mm charging cable that gives you plenty of space, maximizing solar input. With an all-inclusive solar connector, the 400W rigid panel works with other 3rd party solar systems and power stations.
Number of 400W Rigid Solar Panel
Option of Extra Battery
£2,868 £3,038 -£170
Introducing the world's first portable home battery with an expandable ecosystem for home backup, smart energy management, lower energy bills, and more. The EcoFlow DELTA Pro is the next leap in portable power technology, offering you power security and independence, wherever you are.
Next Level Capacity
Power Pretty Much Anything (3600W-7200W Output)
World's Fastest Charging (MultiCharge 6500W)
Home Integration
All the AC output you'll need.
A single DELTA Pro unit packs a 3600W AC output, which can be expanded up to 4500W with X-Boost technology. Power 99.99% heavy-duty devices at home, outdoors, or at work. You can even pair two units together to achieve 7200W with Smart Home Panel.
The world's fastest charging portable power station.
Go renewable with 1600W solar charging.
EcoFlow's suite of solar products give you a cost-effective renewable energy source to stay powered. You can use solar energy to charge DELTA Pro in just 1.5 hours. DELTA Pro has a wide voltage range from 11-150V, which makes it compatible with 90% of third-party solar panels with solar connectors. And when the weather gets unpredictable, the smart maximum power point tracking (MPPT) automatically adjusts, maximizing your solar generation at any time of the day.
Multiple ways to control & monitor.
Control DELTA Pro either on the unit itself, using the remote control accessory, or unlock a ton of customization via the EcoFlow app. On the app, you can access your power settings, such as charging and discharging levels, AC charge speeds, control the Smart Generator and a whole lot more.
What's in the box - Without Extra Battery
1. DELTA Pro 2.AC Charging Cable 3. Car charging cable 4. DC5521 to DC5525 cable 5.User Manual and Warranty card 6. 400W Rigid Solar Panel* 7. Solar to XT60 Charging Cable 8. Support Brackets *The number of Solar Panels depends on the bundle you order.
What's in the box - With Extra Battery
1. DELTA Pro 2.AC Charging Cable 3. Car charging cable 4. DC5521 to DC5525 cable 5.User Manual and Warranty card 6. 400W Rigid Solar Panel* 7. Solar to XT60 Charging Cable 8. Support Brackets 9. DELTA Pro Smart Extra Battery *The number of Solar Panels depends on the bundle you order.
When charging DELTA Pro and its extra battery together, you can reach 6500W max charging speeds by combining AC, solar and Smart Generator methods. For DELTA Pro single unit, you can recharge it at standard wall outlets (2900W max), at EV station (3400W max)/Smart Home Panel (3000W max).
It depends on the combined voltage and current of the solar panels you choose. It's fine as long as the solar panels use solar connectors and their combined voltage and current are within 11-150 volts and under 15 amps.
First of all, make sure your DELTA Pro is connected to the EcoFlow App using Internet mode. Secondly, go to the Firmware section in the Setting of the DELTA Pro you're looking to upgrade. Check for the latest firmware and follow the steps to finish the upgrade.
Specs of DELTA Pro
Approx. 99lbs/45kg
Dimension
3600Wh
Extra Battery
Full Recharge Time
1.9 Hours (AC)
37.5 Hours (12V Car Charger)
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
2900W Max, 230V~12.5A
Solar Charging Input
1600W Max, 11-150V, 15A
Car Charging Input
Support 12V/24V battery, 8A
Connection
Wi-Fi, Bluetooth, wired
Customer Reviews
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
