EcoFlow DELTA Pro Solar Generator (Portable PV400W) - EcoFlow UK
EcoFlow UK
£2,848.00
🏆Member's Festival
Regular price £2,848.00
Sale price £2,848.00 Regular price £3,548.00
Save up to £700.00
Up to EcoCredits for cash deduction
• The BEST home backup solution that protects your home from power outages at all times.
• A 3600W AC output.
• Up to 23% conversion guarantees a fast solar charging speed: 0-100% in 3 hours (3 sets), 4.5 hours (2 sets), and 9 hours (1 set).
• IP68 dust and water resistance.
• Smart remote control with EcoFlow app.
• 5-year warranty for DELTA Pro and 24-month warranty for 400W Portable Solar Panel.
Availability
loading..
£2,848 £3,548 -£700
Introducing the world's first portable home battery with an expandable ecosystem for home backup, smart energy management, lower energy bills, and more. The EcoFlow DELTA Pro is the next leap in portable power technology, offering you power security and independence, wherever you are.
Next Level Capacity
Power Pretty Much Anything (3600W-7200W Output)
World's Fastest Charging (MultiCharge 6500W)
Home Integration
All the AC output you'll need.
A single DELTA Pro unit packs a 3600W AC output, which can be expanded up to 4500W with X-Boost technology. Power 99.99% heavy-duty devices at home, outdoors, or at work. You can even pair two units together to achieve 7200W with Smart Home Panel.
The world's fastest charging portable power station.
Go renewable with 1600W solar charging.
EcoFlow's suite of solar products give you a cost-effective renewable energy source to stay powered. You can use solar energy to charge DELTA Pro in just 2.8-5.6 hours. DELTA Pro has a wide voltage range from 11-150V, which makes it compatible with 90% of third-party solar panels with solar connectors. And when the weather gets unpredictable, the smart maximum power point tracking (MPPT) automatically adjusts, maximizing your solar generation at any time of the day.
Multiple ways to control & monitor.
Control DELTA Pro either on the unit itself, using the remote control accessory, or unlock a ton of customization via the EcoFlow app. On the app, you can access your power settings, such as charging and discharging levels, AC charge speeds, control the Smart Generator and a whole lot more.
What's in the box - DELTA Pro
1.DELTA Pro 2.AC Charging Cable 3.Car Charging Cable 4.DC5521 to DC5525 cable 5.Handle Cover 6.User Manual
What's in the box - 400W Solar Panel
1. 400W Solar Panel 2. Kickstand Case 3. Solar to XT60 Charging Cable 4. User Manual
When charging DELTA Pro and its extra battery together, you can reach 6500W max charging speeds by combining AC, solar and Smart Generator methods. For DELTA Pro single unit, you can recharge it at standard wall outlets (2900W max), at EV station (3400W max)/Smart Home Panel (3000W max).
It depends on the combined voltage and current of the solar panels you choose. It's fine as long as the solar panels use solar connectors and their combined voltage and current are within 11-150 volts and under 15 amps.
First of all, make sure your DELTA Pro is connected to the EcoFlow App using Internet mode. Secondly, go to the Firmware section in the Setting of the DELTA Pro you're looking to upgrade. Check for the latest firmware and follow the steps to finish the upgrade.
Specs of DELTA Pro
Approx. 99lbs/45kg
Dimension
3600Wh
Extra Battery
Full Recharge Time
1.9 Hours (AC)
37.5 Hours (12V Car Charger)
1 x 400W panel : 11-22 hrs
2 x 400W panels : 5.5-11 hrs
2 x 400W panels : 3.5-7 hrs
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
2900W Max, 230V~12.5A
Solar Charging Input
1600W Max, 11-150V, 15A
Car Charging Input
Support 12V/24V battery, 8A
Connection
Wi-Fi, Bluetooth, wired
Specs of 400W Solar Panel
Rated Power
400W
Cell Type
Monocrystalline silicon
Efficiency
22.60%
41.7*93.1*0.98 in (105.8*236.5*2.5cm)
Open Circuit Voltage
48V (Vmp 41V)
Short Circuit Current
11A (Imp 9.8A)
Weight(Solar Panel)
Approx. 35.3lbs (16.0Kg)
Weight (with Kickstand Case)
Approx. 41.9 (19kg)
Customer Reviews
Based on 2 reviews
100%
(2)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
S
Steven T.
First rate service.
A
Anonymous
They are the best pro-forming batteries on the market and meaning (pro).would recommend to anyone who wants quality
Ecocredits
EcoCredits Program
Become a member to earn EcoCredits and exclusive rewards every time you shop!
EcoCredits Appreciation Week
How to Earn EcoCredits
Register and Subscribe
Get 1000 EcoCredits
Shop
1 EcoCredit for every £1 spent
Earn every time you order.
Refer a Friend
Up to 3000 EcoCredits
1000 EcoCredits
Profile
1000 EcoCredits
Get Rewards
Coupons
£5
100 EcoCredits
£10
200 EcoCredits
£25
500 EcoCredits
£50
1000 EcoCredits
£100
2000 EcoCredits
£200
4000 EcoCredits
Gift
EcoFlow Badge
1199 EcoCredits
EcoFlow Camping Mat
5499 EcoCredits
EcoFlow Camping Light
4599 EcoCredits
EcoFlow Smart Plug
5999 EcoCredits
EcoFlow Flatbed Trolley
7449 EcoCredits
EcoCredits Week
Highlights of the EcoCredit Appreciation Week event:
7 days member-only discounts
Success!
* I agree to EcoFlow's Privacy Policy and Terms of Service.
